06-12-2008, 06:03 PM | #1 |
s14 foglights (OEM how to!)
ok guys heres a write up on the s14 fog lights ive searched for this on here and found a few threads on what is needed and such sooooo.....
parts needed for OE install switch assy brackets relay part # sheet ok start by locating the mounting holes (4 of them one is for a pin on the bracket) then find the plug for the foglights.(it will be taped up behind the turn signal area) use three ten mm bolts to mount the bracket remove side cover on the foglight by pressing in the top tab ( to expose the hole on the foglight housing) bolt the foglight to the bracket. it has room for adjustment snap side cover back on and plug harness in.(repeat for other side) find relay box in engine bay plug in relay according to diagram on cover remove steering column cover(six screws on the bottom half) then remove two screws from light switch find the black plug taped to the switch harness. and unplug the switch plug in black plug and the other to plugs to the switch screw switch and cover back on and......... btw the jdm brackets dont work on usdm 240's thanks for viewing hope ive been helpful P.S. if ne one has the factory lip plz PM me Last edited by KasperSlide; 06-12-2008 at 09:23 PM.. |
06-12-2008, 07:20 PM | #2 |
Trader Rating: (50)
Feedback Score: 50 reviews
yeah good write up i was thinkin of using 92lexus fog lights really yellow and great visibility but not sure to do it oe syle of just wire it up o well great job btw.
06-12-2008, 08:11 PM | #5 |
There's actually three detailed writeups with pics already on here.
06-12-2008, 08:57 PM | #7 |
projectRDM:next time ill make sure i run every thing by you b4 i post then how bout that......oh yeah i think you put your 2cents on all of them too. what would we do without you.
Thanks |
06-12-2008, 09:34 PM | #9 |
thanks man
brackets were $30.60 a piece and the relay was $15.29. im sure you can get the relay for cheaper. i buy from nissan cuz i used to work there so i still get a lil bit of a discount. i think list price on the brackets were around $40 sooooo....... |
06-12-2008, 09:41 PM | #10 | |
mine had to come out and are for sale tho
97 240sx se Last edited by 0wn3r; 06-13-2008 at 08:05 AM.. |
06-12-2008, 09:47 PM | #11 | |
As for this: next time ill make sure i run every thing by you b4 i post then how bout that......oh yeah i think you put your 2cents on all of them too. what would we do without you. Don't get all butthurt skippy. If we had nothing but the same shit on here every day someone would get tired of it. Oh wait, we do.
06-12-2008, 10:12 PM | #12 |
^^^^yea thanks again. As you can see I've been on here for 4 yrs and currently have 92 posts. Sooooo, I think I know how to use the fancy search button. Not quite the post whore like some people. If I didn't think people could use it(and as you can see they do appreciate the write up) then I wouldn't post it.
Thanks |
06-12-2008, 11:00 PM | #13 |
hmmm, u know i got kouki fog lights
they look like that it already has some brackets, but when i looked under my car today i saw the bolts you were talking about. but, none of the brackets i had worked. and i bought these from another guy with a s14 kouki like me too =(. so, i probably need another bracket or something huh? thanks for your help =D |
06-12-2008, 11:28 PM | #14 |
yea those are kouki foglights with brackets which would not fit a zenki front. this is a write up for a 95-96 zenki. I dont quite understand what you're saying. what year is your car? if you have a 95-96 with the the kouki front end then you will have to make your own brackets.
06-12-2008, 11:34 PM | #15 |
oh, i got a 97 kouki as well. but i saw that you needed bracket for yours. so i was wondering if i need a bracket on top like yours. cuz i looked around and there are no holes for the brackets i currently have to bolt into.
so, that's where i derived my conclusion that i may need an additional bracket also. or maybe i'm just not looking hard enough. |
06-12-2008, 11:52 PM | #16 |
When I've seen the kouki foglights sold w/ brackets they come like the pic shown. So I would assume you have the right brackets. Maybe your foglights fasten to the actual bumper. Is that a possibility????
06-13-2008, 07:19 AM | #18 |
The Kouki foglights bolt to the bumper cover, not the reinforcement. Put them in from behind where they belong and you'll see where they line up.
06-13-2008, 07:28 AM | #19 | |
06-13-2008, 08:55 AM | #22 |
^^^ yea there was now way that they would work......although Im sure some crazy A$$ has made it work
\/\/\/\/ ok RDM have the last words Last edited by KasperSlide; 06-13-2008 at 07:52 PM.. |
06-13-2008, 02:06 PM | #23 |
They work fine with the JDM bumper reinforcement.
03-02-2010, 12:13 PM | #24 |
I have a 96 nissan 240sx with a 97-98 JDM front end conversion. So I understand that the fog lights line up behind the front cover of the bumper. I'm guessing i will need a relay as well but no brackets as the JDM fogs come prebracketed?
-Uh247KiCkYnG |
03-02-2010, 06:48 PM | #26 |
Haha i just actually winged it and installed mine this morning!!! Wish i would of seen this earlier would of made it a bit easier lol.... Any who sick right up!
02-14-2012, 01:24 PM | #30 |
that is kinda odd, the base models will have the harness for the fogs and the fog light stalk in the steering column..sometimes it's a little difficult to find when they are and tucked away from the factory.
for anyone doing the fogs on a base model kouki, you will need 2 relays: one (black i think?) in the fuse box under the hood and one blue one near the fusebox in the driver's side kick panel. **and I have fogs with a FMIC, it's really close but it will fit |
