11-18-2001, 11:50 AM | #2 |
Personally, i ended up having to drill through the firewall. It's a bit of a pain, but it works. Make sure you have the right size drillbit and a grommet to put in there though... that's where I ran into a problem. I didn't have the right size bit, so the grommet didn't fit. I've still got to fix it somehow.
11-18-2001, 11:36 PM | #4 |
Well, on the S13, there's what looks like some sort of drainage thing on the passenger side. I went a little below that and drilled the hole. I doubt your car will be the same though... Basically just try to find a place that's out of the way and away from engine heat.
11-19-2001, 09:20 AM | #5 |
You found the hole, but didnt know what to do with it, tsk tsk tsk...
personal problems should stay personal... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> |
11-19-2001, 11:22 AM | #7 |
OMNOMNOMNOM
Its ez to see in the engine bay, just look where your passenger side is and you should see a black rubber peice that will allow for wires to be droped through. I ran my fogs through there a long time ago. You can get to it also by the passenger seat where your feet go you should be able to see if you pull back the carpet. Stick a screw driver threw and you will be able to see where it is in the engine bay.
