09-30-2013, 12:20 PM | #1 |
Godspeed Project RS-Series Wastegates!!! SALE!
38mm RS-Series Wastegate
- Includes a 5psi & 10 psi wastegate spring (combine both springs for 15 psi) - Dual port = accurate boost - Ultra durable diaphram - Includes all hardware (bolts, gasket etc) - High quality appearance - Quick and simple one step process for removal or installation of a different wastegate spring - 1 year warranty with professional installation This wastegate is 4.00" inches tall. 5 psi spring : outer diameter 29mm / length : 36mm 10 psi spring : outer diameter 44mm / length : 68mm You can use the 5 PSI or 10 PSI spring alone or combine them together for a total of 15 PSI. $75 Shipped to the Inner 48 States (CA Customers pay sales tax) 44mm RS-Series Wastegate - Includes 5 psi & 10 psi wastegate spring ( combine both springs for 15 psi ) - Dual port. accurate boost - Ultra durable diagram (diaphram) - Includes with all the hardware (bolts, gasket etc) - Accurate boost pressure - High quality appearance - Simple one step process for removing or installing different wastegate springs - 1 year warranty ( if installed by professional) This wastegate is 4.10" inches tall. 5 psi spring : outer diameter 29mm / length : 36mm 10 psi spring : outer diameter 44mm / length : 68mm You can use the 5 PSI and 10 PSI spring alone or combine them together for a total of 15 PSI. $95 Shipped to the Inner 48 States (CA Customers pay sales tax) 50mm RS-Series Wastegate - Includes 2 x 7psi spring, 1 x 14 psi spring (can be combined up to 28 psi) - Dual port. accurate boost - Ultra durable diagram (diaphram) - Comes with all the hardware (bolts, gasket etc) - Accurate boost pressure - High quality appearance - Simple one step process for removing or installing different wastegate springs - 1 year warranty ( if installed by professional) This wastegate is 5" inches tall. 7 psi spring : outer diameter : 36.5mm / length : 93mm 7 psi spring : outer diameter : 59mm / length : 85 mm 14 psi spring : outer diameter : 49mm / length : 113mm You can use the 7 and 14 psi spring alone or combine them up together for 21psi. By using all three springs together, will get you up to 28 psi max. $120 Shipped to the Inner 48 States (CA Customers pay sales tax) 60mm RS-Series Wastegate - Includes 5 psi, 12 psi, and 14 psi springs (combination of 31 psi) - Dual port = accurate boost - Ultra durable diagram (diaphram) - Includes all hardware (bolts, gasket etc) - High quality appearance - Simple one step process for removal or installation of different wastegate springs - 1 year warranty with professional installation This wastegate is 5.5" inches tall. 5 psi spring : outer diameter : 36.5mm / length : 75mm12 psi spring : outer diameter : 59mm / length : 121mm 14 psi spring : outer diameter : 49mm / length : 108 mm You can use the 5 PSI / 12 PSI / 14 PSI spring alone or combine them together. By using the 5 PSI & 14 PSI spring, you will get 19 PSI . By using all three springs together, you will result in 31 PSI. $140 Shipped to the Inner 48 States (CA Customers pay sales tax) For any orders please contact Chris @ Godspeed Project. (EMAIL) [email protected] (Phone) Chris (626) 442 - 3988 Monday to Friday 9AM to 6PM
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
10-02-2013, 10:35 AM | #3 |
Yes Mace! Let me know when you are ready!
10-07-2013, 10:15 AM | #5 |
Pm sent!!!!!!
10-10-2013, 12:35 PM | #6 |
bump for the wastegates! in stock and ready to go!
10-14-2013, 12:46 PM | #7 |
Columbus day bump!!!
10-22-2013, 01:34 PM | #8 |
all wastegates in stock!!!
10-28-2013, 11:45 AM | #9 |
bump for the wastegates!!!
11-04-2013, 12:05 PM | #10 |
11-22-2013, 02:15 PM | #11 |
wastegates in stock and ready to go out
12-19-2013, 12:06 PM | #12 |
wastegate bump!
12-23-2013, 11:11 AM | #13 |
Almost Christmas Monday Bump!
