02-06-2015, 08:12 PM | #4921 | |
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
02-07-2015, 01:50 PM | #4923 |
Trader Rating: (18)
Feedback Score: 18 reviews
I have the divided t4 ilovetacotaco manifold and I had to do some crazy shit to get it to fit and not leak. Not only trimming exhaust studs but I had to bore out the holes to move it down and back a few mm. The front three runners sat too far back and the back three runners sat too far forward so it would leak like crazy because the opening of the runners were so big and would go past the exhaust gaskets. I then had to dremel the exhaust stud holes on the gaskets and move them around until didn't leak. I put permatex copper gasket on everything and so far it hasn't leaked again.
I hope I can save someone from the bullshit I went through. You get what you pay for I guess or maybe I'm just really fcking unlucky and the 5 year old that built it in Taiwan didn't give a shit that day.
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
02-07-2015, 08:34 PM | #4924 |
As240 I think everyone gets the same quality on those manifolds you are just the only one that pays attention to details that most people look past and/or ignore.
02-09-2015, 10:38 AM | #4926 |
Trader Rating: (18)
I'll have to check my invoice tonight but I got the harness, r154 shifter extension, fuel pressure regulator bracket and swap mounts from him at the same time. I'll check when I get off work tonight but I think it came out to be somewhere in the $6-700 range
02-09-2015, 01:02 PM | #4927 |
Seems like a fair price. Im thinking about running a honda aem ems on my 2jzgte vvti too now, because aem ems for a 2jz are way too expense lol.
kuv yoj hmong ey koj ney??? |
02-10-2015, 09:28 AM | #4933 |
Trader Rating: (18)
Freed made my harness so that it plugs directly into a Honda aem v2 which I also got from him. I totally forgot about checking my receipts. I'll do that tonight.
02-10-2015, 01:13 PM | #4935 |
How/Where is everyone mounting/laying/stashing/hiding/etc their ecu? I was able to wedge mine in right under the glove box and then zip tie it. But now I have proefi and...it just lays on the floor lol
02-10-2015, 01:18 PM | #4936 |
Interested to see this as well. ProEFI is basically the size of an amp so maybe under the seat? I haven't gotten to the point of looking for a mounting point for my 128 yet. Definitely won't fit under the glove box without being touched by feet haha.
02-10-2015, 06:22 PM | #4937 |
Trader Rating: (18)
Would it be possible to notch out the back of the glove box for the harness and mount it inside? That's what I plan on doing with my aem if it won't fit in the stock ecu location. Proefi would be a little more difficult because of how the harness plugs in.
02-10-2015, 08:09 PM | #4939 |
I made a stand for mine that puts it right behind the glove box. I dont have A/C though, lots of space.
I would have put it in the glove box but, damn chasebays harness is short as balls. Sorry for the huge pics. |
02-13-2015, 02:41 PM | #4942 |
So i've been off Zilvia for a few weeks, trying to catch up on some personal stuff, i read back through the last few pages and saw there was a bunch of talk about the 1JZ-VVTI swap stuff,
I was under the impression that if you bought an Early 1JZ-GTE VVTI engine with the throttle cable you were fine, and if you got the newer one a TB switch and a ECU switch to the early ones was all you needed to do? Anyone ever try to get a DBW pedal hooked up in a S-Chassis? I thought i saw some LS guy's doing it with GTO swaps.
02-13-2015, 04:10 PM | #4943 | |
Your other hangup will be the IACV which only comes on first gen 1jz vvti.. you will also need to swap out the intake manifold or drill out the port for it and install some studs if you want to use it On a second gen 1jz vvti. You can also use a 1jzgtte intake manifold which will also conveniently give you a map sensor port, since 1jz vvti only uses MAF. I've never heard of people swapping over the DBW system for the 1jz vvti (but have on swaps like vq35 etc.), most likely because the dual butterfly TB piggybacking the ecu tends to slow down performance for sake of fuel management. |
02-13-2015, 09:00 PM | #4944 |
That's actually very relevant to what I'm dealing with now. Long story short I'm going to pick up a JZZ30 soarer 1JZ VVTI tomorrow in exhange for my JZX110 Crown engine. (sorry for all the acronyms, trying to make this easy to search for).
Anyways you don't need a special pedal for the X110 drive by wire in the late model 1JZ VVTI's. Instead a mechanical cable like the early models have is attached to the throttle body but instead of turning the throttle body plate when actuated, it instead spins a potentiometer that tells the ECU what the input was, the ECU then accomodates and sends a signal over to the DBW gears and actuates the plate. So there is no fancy pedal involved, just electronics at work. There's a few options for remedying this. 1. Swap to earlier throttle body, ECU and MAF (x110 uses a different MAF) OR 2. Drive by Wire 'delete' kit by Premium Japan http://global.rakuten.com/en/store/p.../item/kit-001/ Here's Toyota's ETCS-I explanation: |
02-15-2015, 08:39 PM | #4946 |
I've seen a few people retain AC with JZ swaps but not much info on how it's done. Is there a kit available for this like with the LS? I assume the stock JZ AC compressor is used...?
02-16-2015, 06:38 AM | #4948 |
Just adding some more information to this thread. Did a mid sump (Soarer) to front sump (Crown) conversion this weekend and it's super easy.
1. Pull the Pan 2. Pull the oil pickup and baffle plate 3. Unbolt the sump. 4. Remove oil dipstick and any oil level sensors that may be present (midsump had one). 5. Disconnect turbo oil drain line. 6. Look for the slots at all four corners of the sump that have a cutout for a screwdriver and pry gently. 7. Should come off no problem, clean your mating surfaces and reapply Toyota FIPG or Permatex equivalent. 8. Make sure to transfer over all associated parts including the dipstick tube. The CT15B turbo does have two different oil drain lines for midsump and front sump but the bends aren't difficult to remedy. If I find part numbers for prebent lines I'll post them. I could have swapped turbo lines over but the Crown was a pain due to engine mount location and I was short on time.. Last edited by bmaddock; 02-16-2015 at 11:32 AM.. Reason: Thanks ATLspeed |
02-16-2015, 08:21 PM | #4950 |
Hey guys quick question, glanced through this entire thread to look for Cross-flow radiators
In need for a very efficient cooling system, as the jz swap im doing into my brothers s14 will have A/C and be in Arizona used as a daily. Already ceramic coated all the exhaust stuff to keep temps under control. Was thinking a drop in? if they make it or custom is not an issue, with SPAL extreme 12" fans.
~755whp 1jz.~ Proefi 128, e85, 1200cc, 6265, 39psi |
