04-18-2015, 08:29 PM | #5161 |
Fug... Well that won't do for me. I'm already making 370tq and I plan to move way up. Just blew my R154 tonight. Lost gears 1-3
04-18-2015, 08:33 PM | #5162 | |
Yeah you need like a v160, T56 or CD009 sounds like
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
04-19-2015, 07:01 AM | #5163 |
Has anyone made any more progress with putting a 4 speed richmond style trans behind a jz? I just have my w58 but its going behind a stock vvti 1j. Planned on doing the 4 speed when the w58 let go after upping the power on the 1j.
04-19-2015, 07:10 AM | #5164 |
Ok so just want a clear answer, are the 2j aristo motors front or rear? And if they are front then I won't need to Change it to drop in my s13 correct?
04-19-2015, 07:48 AM | #5165 |
Yes the aristo is a front sump engine and thats what you need for an s chassis. But you can buy a rear sump engine and swap the upper/lower pan and pickup from a rear to a front.
04-19-2015, 07:49 AM | #5166 | |
They can come with either... But yes you need front sump
04-20-2015, 10:34 PM | #5168 |
Does anyone have a side by side comparison of the Old Vs. New 2JZ-GTE starter plug? i'm having my harness done and can't quite figure out what mine is and i'm away from the car for a few days.
04-20-2015, 10:48 PM | #5169 |
04-22-2015, 05:18 AM | #5171 | |
so since you guys are putting out quality harnesses and making a good name for your self, when are you gonna do a harness for VVTI? |
04-22-2015, 05:35 AM | #5172 | ||
04-22-2015, 10:25 AM | #5173 |
Yes as bmaddock stated we are making them. We have already made them for the 1JZ VVTI set up and currently have a 2JZ VVTI engine here at the office for testing and production. So both the 1JZ and 2JZ harnesses will support the VTTI.
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram |
04-22-2015, 10:50 AM | #5174 | |
AWSOME! well I know where I will be buying in the future. |
04-22-2015, 11:50 AM | #5175 |
We will keep everyone posted on an ETA for the release of the 2JZ VVTI harness. If there is anything we can do to assist or answer any questions always feel free to reach out.
thanks
04-22-2015, 09:02 PM | #5176 |
I was wondering with stock twins, could you pull the heater core and trim the inlet/outlet and have coolant hose be connected inside the car and it have a 90* bend out of the fire wall. That way the hose is up against the firewall.
Similar to how Broadfield trimmed his (although his is I think for quick releases): |
04-22-2015, 09:07 PM | #5177 |
Was totally thinking about doing something like that. Got the 1jz In tonight and was looking at the heater hoses
~755whp 1jz.~ Proefi 128, e85, 1200cc, 6265, 39psi |
04-22-2015, 09:28 PM | #5178 | |
Gosh that sounds like a great idea... Quote:
04-23-2015, 07:48 AM | #5179 |
Moar alternator complications:
Here's the 2007 tundra alternator. You can see the mockup for how much needs to be milled off. Here's a pic off it after the top ear has been milled down for fitment on aristo 2jzgte. It's a little over 5mm to be safe - and I'm adding a couple thin washers to shim it up top when installing - for belt alignment. You can also see the new 4-pin denso pigtail. I tried to keep the pn visible in the photo: 27060-0f070 * rated at 130 amps Now here's the strange thing - the janky wiring that I have on the old 3-pin connector was done by someone I paid for wiring - well that all feeds together into a single bundle and into one wire leading to who knows where in my harness. Now that I'm putting the 4-pin pigtail on, where should it be connecting into? I want to do this correctly. (The markings on the sticker for the 4 pins are IG, S, L, M respectively.)
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
04-23-2015, 08:17 AM | #5182 |
I'd only assume it had more amps. But how much more. Why not just buy a direct bolt on unit?
04-23-2015, 08:38 AM | #5184 |
The aristo alts are 90-100 amp.
The tundra one I purchased is 130 amp. I feel this helps with the drain from the walbro fuel pump and extra gauges, etc. The sequoia 4.7L has a 150 amp alternator that can be modded the same way. But I got this for $80 on eBay, so it was a cheap upgrade IMO.
04-23-2015, 08:41 AM | #5185 |
Yeah just seems like a lot of work vs a bolt on. And I'm a machinist lol. Never had issues with my 100amp and i use 2 large bosch pumps, gauges, fans, radio, ac, 750whp.
Datalog everything too and voltage is spot on.
04-24-2015, 09:02 AM | #5188 | ||
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
04-26-2015, 05:56 PM | #5190 |
I know it dépends on the mount you have but usually, how much do you extend the shifter on the r154 ??? I might do it before I drop the engine in the car so info on this could be helpful.
