03-10-2008, 04:49 PM | #961 |
ive ran a 225/40 on 11.5 as it was all i had laying around at home on the day and needed to drive to the workshop
shit fell off first slide i did... |
03-10-2008, 05:06 PM | #962 |
i was skeptical at first but ive been running a 225/45 on a 10.5j at -4.5 camber for like 6 months (been going through different tires but kept the same size). and they have been just fine.
03-10-2008, 05:06 PM | #963 |
03-10-2008, 06:27 PM | #965 | |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
Have you checked your toe?
03-10-2008, 06:42 PM | #966 |
www.SonicMotor.com
Trader Rating: (113)
Feedback Score: 113 reviews
what kit is that??? Hella nice..
Sonicmotor.com | Zach @ Sonic Motor | 626.363.9036 | [email protected]
Check out our website! ( CLICK ) |
03-10-2008, 07:36 PM | #969 |
www.SonicMotor.com
03-11-2008, 08:29 AM | #974 |
Let chatter and less hate for stretched tires for wheel fitment please.
If you want to bitch at stretched tires, do it via PMs or don't type at all. If you want to bitch about toe settings or camber killing tires, please do it over PM or don't type at all. If you want to ask what kit Johny5 has on his S14, please do it via the "Identify this" thread. Honestly, these topics didn't just get created last night, they've been here for MONTHS as stickies at the top, and unless all you idiots failed 2nd grade reading comprehension, I'm pretty sure the thread titles are pretty self explanatory. The "wheel fitment thread" is exactly that, for wheel fitments, not for you to bitch about people's stretches and shit. If you don't have anything constructive to add, please reevaluate your post before you hit that post button. |
03-11-2008, 09:09 AM | #975 |
hmmmm guess u stretch too , r we in cuba?
TRUE thing: True ////OFFSET\\\\ is acheived without spacers Running on E85 570whp Precision 5862....laggy as fuck. hate it |
03-11-2008, 10:14 AM | #976 |
03-11-2008, 01:15 PM | #977 |
Im not sure if this is up to this threads standards but here goes..........
18*9 +20 24540 rear/ 18*8 +20 225/40 front......minor pull int the rear w/ about 2mm clearance with fender when i hit a bump
Girlfriend or car, which is more work???? |
03-11-2008, 01:21 PM | #978 | |
03-11-2008, 01:40 PM | #979 |
i wanted to ask... you guys think a 17x10 +18 would fit up front on my s13 with camber and rolled/lightly pulled fenders,please dont bash on me for asking.figuered since this is the fitment thread.
03-12-2008, 06:52 AM | #985 |
It should. I've got 18x10 +20 up front with a 15mm spacer, and it looks like I've got about 10ish mm up front to play with. Either a 5 or 8mm spacer should clear it fine.
03-12-2008, 09:05 PM | #988 |
18x9 +17. 225-40-18 Stock fender Camber : unknown, but slotted holes on bottom bracket maxed outwards (positive), camber plates maxed inwards (negative). I'll fix that later on to get a bit more camber
613DriftWerks.ca |
03-12-2008, 09:58 PM | #989 |
Chucked on my rear pair of 18x10 +24 SSR Vienna's on the front to see if they would fit, surprisingly they did.
They sit a little Mexican but with not that much camber. I think with a smaller tire (keep in mind they are 245 on a 10")(225/40/18? 235/40/18?), camber, guard work and a little lower they should sit fine. I tested it lock to lock and no rubbing (obviously will be a lot different once driving). Here are the photos:
Garagesokudo.com.au - JDM tyt wheels. Sokudostyle.com - Sokudo Lifestylin' |
03-13-2008, 06:02 PM | #990 |
FRONT: 17x9 +0 235/40/17; st115s; -3.2/5 camber; roll/crappy 30mm pull that shouldn't have been attempted
REAR: 18x10.5 +15 245/40/18; st115s; -2.7 camber; roll/slight pull
v-mount ftmfw. |
