07-16-2005, 03:08 PM | #1 |
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
IC piping, SS vs Aluminum
would there be any benfits from using stainless steel piping or aluminum piping?
just curious
89 240 SR powered... ummm i promise its stock |
07-16-2005, 03:22 PM | #2 |
Aluminum Piping
PROS Lightweight Dissipates heat better Looks badass when professionally welded CONS More difficult to weld and will cost more if you don't do it yourself Difficult to find aluminum bungs for vacuum lines and such. I just made mine in aluminum recently because my dad is a welder and he does pro status work. I found a vacuum line fitting at home depot for my wastegate. I got my my IACV fitting from a shaved cast piece off of my S15 turbo inlet for the crankcase ventilator. You could always weld extra plate onto the piping and tap a copper fitting for the IACV but it wouldn't look as pimp. I'd post pics but I don't have a digital camera. |
07-16-2005, 03:23 PM | #3 |
looks mainly and stainless won't rust other than that, no.
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels. |
07-16-2005, 03:32 PM | #4 |
If you are like me and would like to make your intake temps even lower, get one of these intake manifold gaskets.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW When I have the time I'm going to get one and install it. I noticed that the heat from my engine travels and heats my intake mani, TB, and about 8 inches of my cold pipe. |
07-16-2005, 03:39 PM | #5 | |
92 FastBack - Project 98 SE - Daily Driver |
07-16-2005, 03:45 PM | #6 | |
edit: aluminum oxidizes though. was what i was meaning anyways.
07-16-2005, 04:11 PM | #7 | |
They sometimes use aluminized steel... which is crap.... others use galvanized, which is equally crap. But then if you go to a place like that looking for something quality and performance enhancing, you're stupid anyhow LOL |
07-16-2005, 04:14 PM | #8 | |
07-16-2005, 04:14 PM | #9 |
Stainless is heavier that aluminum by quite a bit, its easier to weld and its stronger.
Aluminum is light, harder to weld and is softer than stainless, if you hit it with something it can dent. Id much rather have aluminum though.
Kick Ass 2.4Liter Engine! |
07-16-2005, 05:34 PM | #10 |
hmmmmm so since there is no significant imbalance, i think i will go ahead and go with stainless since it's cheaper and get it welded a lot easier... any objections ?
07-16-2005, 05:57 PM | #11 | |
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink. |
07-17-2005, 01:31 AM | #12 |
I've welded stainless before, i used regular 75/25 gas and didnt use any filler rod, once you get a pool, you can just pull material off the pipe to make your weld. Welded fine.
