06-28-2005, 02:58 AM | #1 |
S13 momo hub install woes
Yeah yeah, I know your thinking, how could something so simple go wrong. Mine did. As soon as I try to tighten the hub to the center console, the horn goes.. and it just keeps going. I had nothing else connected to the hub at the time. Does this signify a faulty hub? How would such a simple piece be faulty. :[ Is there something I'm supposed to modify regarding the 3 pins in the center console?
06-28-2005, 03:04 AM | #2 |
I really doubt you have a faulty hub. I think you have a bad ground somewhere; so when you install your hub, it closes the circuit and sounds off your horn. I suggest removing the steering wheel column and looking for loose wires and anything else out of the ordinary.
Trust and I don't mean GReddy. |
06-28-2005, 03:14 AM | #3 | |
Actually come to think of it. My horn doesn't work with my stock wheel on. Wow, what a pain this will be. I don't know what to check for in the center console. But, could it be the horn relay? I'll go pick up a new one and see if that makes my horn on the stock wheel work. |
06-28-2005, 07:47 AM | #4 |
I need to figure out how to get my horn to work too... How much did you pay for your Momo hub? I can get them for about $45 if you're planning on getting another one....
Ben |
06-28-2005, 10:14 AM | #5 |
the 2 wire one is using a positive (12v) as signal to the horn.
the 1 wire one is using the ground to close the loop. Its not THAT complicated.
92 FastBack - Project 98 SE - Daily Driver |
06-28-2005, 11:58 AM | #6 | |
06-28-2005, 12:06 PM | #7 | |
06-28-2005, 01:00 PM | #8 |
OMG you guys are making this too complicated.
Its a circut, with a switch. 1 wire - Switch is on the ground side 2 wire - Switch is on the +12v side. ITS SIMPLE!!!!!!!! If you have problems hooking up something this simple, got to BestBuy and ask the 16yr old guy in the install bay to show you how to do it. P.S. If you still can't figure out, buy a test light. they are under 10bucks for a pretty good one. Or get a Fluke DMM
06-29-2005, 02:41 AM | #9 |
Even on the momo site it says there's only one hub for the S13.. But anyways.. I just took off the horn fuse and put it on so my horn doesn't go crazy again.
06-29-2005, 03:13 AM | #10 | |
o well, gotta pay for good parts i suppose. besides, a wheel hub is the last place you want o skimp on becuase ur a cheap fucker like me. countersteering+wheel pops off = wrecked car + suicidle driver :P |
06-29-2005, 10:19 AM | #11 | |
06-29-2005, 11:37 AM | #13 | |
I said there's several that will FIT. if u got it off ebay or somewhere, you may not have what u think you have. My friend was running a hub for another nissan (I forget which) for over a year before he realized it was the wrong one. Just cuz it sez S13 on the box, doesn't necessarily mean that's what's in it. My friend experienced just that, dunno if it was the seller, or a boxing error at the manufacturing plant or a mislabel or what. But he DID order a S13 hub, and it said that on the box, but that wasn't what was inside. |
06-29-2005, 01:38 PM | #15 | |
06-30-2005, 09:49 AM | #17 |
SR is in, yep. But the brakes in the rear were making noise so I just finished the 5lug (rear) at 11PM.
I would take it for a spin, but still need to bleed the brakes and I got no plates on it yet But if you want I can stop by after work and we can drive down to my house, it by gale street inn.
