01-27-2002, 10:29 PM | #1 |
I want to get a 2 way KAAZ lsd where can I get one for a good price. Do you guys know if the HKS Carbon-Titanium hiper exhaust is a cat back system or not. I have a ka24de and this exhaust id for the sr will it work fine? Your knowledge is much appreciated.
Thank you. |
01-27-2002, 11:06 PM | #3 |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
Not only are Kaaz LSD 's $800 but you have to get output shafts for them to bolt them in our car because the pumplin Kaaz sells you is late model 180sx type x pumpkin which means it has 5 bolt output shafts. instead of 6 like ours now those are going to to cost $260 then you have to have a mechanic install your ring and pinion because they sell them to you without ring and pinion. thats like another 5 hours of bench labor to do the swap of ring and pinion and get your end lash right so yu don't blow your ring gear. So its more like $1200-$1300 for a setup Kaaz LSD.
runs into the night mumbling its a Kaaz conspiracy |
01-27-2002, 11:25 PM | #4 |
Don't know if your set on the Kaaz, but JIC makes 1.5 and 2 way LSDs for 240's.
http://www.zielmotorsports.com/lsd/lsdindex.html Not sure how much they are, but JIC makes some nice stuff for our cars. Just someting to look into. |
01-27-2002, 11:28 PM | #5 |
I assume you have an s14, if so, you could try to find an SE in a junk yard, and take the factory LSD off of it. It would probably be cheaper to get, and cheaper to install. I don't have the stock one (or anyone at all <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('> ), but I hear its pretty good.
(Edited by Archangel at 1:28 am on Jan. 28, 2002) |
01-28-2002, 12:23 AM | #7 |
AutoX Junkie
A torsen (KAAZ) lsd locks the shafts up before one tire brakes loose. A viscous lsd locks the shafts up after one tire starts to lose traction. As a result tlsd's get a bit faster hookup than vlsd's.
01-28-2002, 10:49 AM | #9 |
I figured that was probably the case. I think that's probably what i'm going for. The only thing that really bothers me is breaking it in. I think i'd be quite sick after 20 minutes of figure 8's.
