12-20-2010, 12:21 AM | #3721 | |
This is how I have it ran. But instead of the black hose on bottom, it would be on top coming from the intake.
12-20-2010, 12:46 AM | #3722 | |
I honestly don't think it's used. I have looked at many pictures of the front of Sr's and see no bolt in there.
12-20-2010, 01:22 AM | #3724 |
i have a bone stock 95 s14. the engine and car shakes when i first turn on the car. what seems to be the problem? is it cuz of the really cold weather? vacuum leak?
12-20-2010, 07:33 AM | #3725 | |
Trader Rating: (31)
Feedback Score: 31 reviews
so i'm trying to decide which extended studs to get for the front, i have ichiba hubs up front, i've read that they are 14mm so i was wondering which ones will work with the knurl on the hubs.
Slip Gypsies Blog Quote:
12-20-2010, 01:19 PM | #3727 |
Everything bolts right on other than the headlights. Door panels are different though, the trim is probably a different design.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
12-20-2010, 02:27 PM | #3728 | |
AFC #1
12-20-2010, 03:49 PM | #3729 |
What fastener holds the handles on for the windows? I took this appart two years ago and they are long gone.
C-clips, Lynch Pins? Does it go thru the small holes or around the plastic part? |
12-20-2010, 04:34 PM | #3730 |
i went to the track this past weekend and it was raining and because of the condensation i had to leave my driver window down. now JUST my head lights wont turn off, they are dim and when i turn the lights on they still go back to normal brightness they just never turn off. i disconnected the battery for now but i was seeing if this had every happened to anyone else on here and if there was an easy fix to it or a wire i have to check and where its located?
thanks guys.
12-20-2010, 04:56 PM | #3731 |
Trader Rating: (26)
Feedback Score: 26 reviews
Trying to get my kade to tdc.
have the motor on a stand and of course have the plugs out but my problem is that the crank doesn't want to turn, even with a breaker bar.. am i doing something wrong?
12-20-2010, 07:16 PM | #3733 |
Is the wiper motor connector different on 97-98 than 95-96? Thought my engine harness was missing the connector, but looking at the 97-98 FSM, it looks like they possibly used a different style connector. (I think the harness I'm using might be from a 97-98.)
12-20-2010, 07:52 PM | #3735 |
Yeah, just compared the FSM's and realized that. Luckily the defrost button plug is the same as the 95-96 wiper connector and I have an extra one of those laying around haha
12-21-2010, 12:01 AM | #3739 |
What wheels are these???
And if anyone has specs that would be great, owner of this car is a zilvia member. I just can't remember who it is.THANX
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
12-21-2010, 12:30 AM | #3740 | |
zilvia is magical and knows when people join only to post for sale - they might also ban you for spamming post count. Theres a waiting period
street dancer. GLEAM |
12-21-2010, 04:21 AM | #3741 |
If i have a s14 base model but it has SE drivers door harness and my passenger side window cant roll down from master switch, if i swap the passenger door harness to an SE harness will it work ?
One day ill actually finish building my s14 ! |
12-21-2010, 07:33 AM | #3744 | |
Another thing to consider is if you ran a 225, I *think* youd want a 45 series tire, which would provide a lot more cushion on you 17" rim than my 225/40 on an 18". My best advice would be to look in the stretch/flush thread, and the maximum rubber thread (both stickied in the chat forum), and use those as a reference to choose your tire size. Your wheels have a fairly mellow offset, so if max rubber is your style, you can fit a good amount of rubber in there. If stretch/flush is your style, you can put stretched tires on there and space the wheels out so they dont look goofy. If your offset is too high, or your car isnt low enough, it will look very silly with stretched tires. Depending on how the wheels sit on your car (and how you WANT them to sit) will determine what tire sizes you should run. I assume you mean for the KA? If so, no- there is no difference. |
12-21-2010, 08:13 AM | #3745 |
12-21-2010, 11:31 AM | #3746 |
12-21-2010, 02:29 PM | #3749 | |
Trader Rating: (31)
any input?
12-21-2010, 05:24 PM | #3750 |
Trader Rating: (43)
Feedback Score: 43 reviews
I'm looking to get an AFPR, preferably one with a gauge. The guys at Phase2 recommended the Circuit Sports model as it has everything I need at an affordable price. They said the quality of the piece is better than the Megan, but I'm wondering if I should spend a little more for the Tomei or SARD models? Anyone have experience with any of these AFPR's?
