03-23-2013, 01:40 PM | #91 | |
95 240sx RB20 415whp 91 Nx2000 VVL yo |
03-23-2013, 01:56 PM | #92 | |
03-27-2013, 04:11 PM | #96 |
yes! beauty
http://youtu.be/vUX0nHidB08 now.... My vacuum is only about -15hg... coolant leaks.. oil leaks.. exhaust leaks.. wiring needs tucking... SO I just pulled it into my garage and i'm doing a Full tear down lol. Now I know it runs 100% starts right up, so Tear down, clean up, tuck, beautify, and have it 100%. |
03-29-2013, 05:08 PM | #97 |
GOT MY FIRST DRIVE TODAY
and almost crashed at the same time. No powersteering = SUCK. This turbo.... is just freaking amazing on all levels. 5psi before 3k rpm ( only took it to 3k rpm ) turbo spools so damn loud but still got issues to settle. |
03-29-2013, 08:27 PM | #99 |
oh yeah definitely. I only took it to 3k rpm and probably like 1/4 mile total distance.. I almost crashed into the sidewalk because of the no power steering.. Trying to take a U- turn with no powersteering sucks.
03-31-2013, 04:45 PM | #100 |
Got my first real test drive! lol wasn't much. just logging my AFR's mostly. but took it up to 5psi! and about 5k rpm.
sounds amazing, and the turbo is pretty loud. video on the way |
04-01-2013, 05:24 PM | #102 |
RB20det drive by Big turbo - YouTube
I think I'm maxing my MAF before I even hit full boost .. getting cut at like 4500RPM / 7-8psi. Blowthrough setup |
04-01-2013, 07:05 PM | #105 |
Unless the paint on the body, wheels, and bay was terrible why did you have to spray everything in pesant black? And judging buy the white specs on the bay did you even prep or prime it for that matter?
04-01-2013, 07:18 PM | #106 |
The body was disgusting, and still looks disgusting. The wheels I didn't do.
The bay no. I'm not trying to make it a beauty queen just yet. also I don't know why everyone hates the RB20 soooo much.. it cruises out of boost just fine like any normal car, yes it doesn't have any kick out of boost. but as soon as the turbo spools it goes crazy.( assuming your not on stock turbo ) btw I'm seeing 12psi by 4500rpm on this thing. ( farthest I've taken it because my intercooler pipes keep blowing off ) so tightening everything down. and the RB20 sounds pure awesome. |
04-01-2013, 09:06 PM | #107 |
OK guys everyone that has been following me I need some suspension opinions.
My stock suspension is crap, the back end bounces around and my car is kinda lop sided hah ( probably from tires ) anyway's whats a decent STREETable suspension setup. NOT for scraping/hellaflush/ crazy camber/ drifting. just something that I can lower the car an inch or so, and have a good ride that won't feel dangerous on the high way |
04-01-2013, 10:50 PM | #108 |
Fortune Auto 500's. Tell them you don't want the hella flush rears and you can keep your car at a good ride height.
04-02-2013, 03:30 PM | #109 |
get these clamps my friend, or something similar.
T-Bolt Clamp for 4.0" Intercooler Hoses welcome to the rb20 |
04-02-2013, 09:32 PM | #111 |
Actually gonna pick up some KYB struts and lowering springs. 1.5 front 1.2 back drop I think ( or maybe reversed )
should do the trick. I just want stock or better drive-ability. Last edited by OrangeVirus1; 04-04-2013 at 03:47 PM.. |
04-04-2013, 03:41 PM | #116 |
Why? It only makes wrouting an intake harder. I have it setup and tuned with my AEM and I am only using the Maf to keep the ecu happy.
I am not TUNING off the maf at all. The ecu is not correcting off the maf at all. I am Clamping the maf voltages and sending the ecu whatever Voltage I tell it. I have it setup where the maf tells the ECU what I want it to at what RPM I want it to. and I have 100% control over fuel trims. The maf isn't Doing anything except Feeding a signal to the AEm and the AEM is feeding the Voltages I TELL IT to the ecu so it doesn't put it in limp mode. |
04-04-2013, 03:44 PM | #117 | |
The STAGG struts have good reviews everywhere and are fine with drops at 2 inches or less. |
04-04-2013, 04:36 PM | #118 |
That's good to here. I just hope you'll be happy with not being able to hight adjust.
04-04-2013, 04:40 PM | #119 |
I'm only dropping an inch I think I'll be fine. If it's too low I'll use stock springs. too high.. well that's ok.
Also having some issues that I need to tune out.. breaking up at high boost and and running too rich @ high boost.. more tuning tuning.. I'm getting the break up at 24.9 psi on it. Which I think is kinda excessive amount of boost already.. but I'm shooting for 25 on 91, and 30-32 on E85 ( later ) Last edited by OrangeVirus1; 04-08-2013 at 10:54 AM.. |
