08-01-2013, 02:35 AM | #1 |
Electrical fan wiring problem
Hey guys, I just got my first 240 over the weekend and the guy before me wired 3 fans into 1 switch and it's getting extremely hot and im afraid it's going to burn out soon. I was going to run 2 fans on 1 relay and the third on another. Since this is my first wiring gig I was curious if anybody could help me. I drew up how I THINK it should be, but correct me if i'm wrong, I don't want to screw up. I'm running 12 gauge wire on 30a switches.
08-01-2013, 03:04 AM | #3 |
I keep seeing people interchange 85 and 86 as grounds, As far as what i've been able to read and what you've told me it should look a little bit more like this. Should I put fuses going to the switches as well? Sorry for the crude MSpaint getup
08-01-2013, 10:51 AM | #5 |
You only need 2 fans and 2 relays. Make sure the source power wire is 12 AWG all the way through, those cheap eBay sockets that plug into bosch style relays are usually only 16 or 18 AWG so you will have issues. Your grounds also need to be 12 AWG or bigger. Since you are tapping directly from battery you will need 30A fuses for each fan relay power source, about 1 foot from the battery.
08-01-2013, 01:49 PM | #6 |
Sweet,when I got the car it came with 3,ill probably take the push fan off and do just the 2 pulling, I have 12 awg wire and 2 30a fuses, 30a switches, and some 30a relays. I'm just trying to get an idea of how to wire this, if anyone can draw sonething out
08-02-2013, 12:08 PM | #9 |
I don't agree with that diagram! A relay wired like that makes little sense. Will it work???? isn't my question. Why use a relay for that? Is the question.
08-02-2013, 12:13 PM | #10 | |
edit: If you don't want to use relays, and you have a switch that is rated for 30A...
08-02-2013, 12:24 PM | #11 |
I know, me too.
edit: That new diagram would be more simple for anyone that needed to wire up fans, that didn't want or understand relays.
