05-02-2013, 01:14 PM | #1953 |
Ok everyone, so here's what happened. I have a 245/40/18 on an 18x11. Hasn't given me any trouble over the year + that I've had them mounted. I go out Monday night, checked my PSI and all tires were around 40-42 psi. Everything was fine. I wake up the next morning and the tire bead unseated on the front of the wheel. I was like wtf?? Took it to a tire shop today and had a buddy refill it with air and the tire beaded right back up. Checked for leaks, none.
So, has this happened to anyone else before? Should I up the psi a little more to make sure it doesn't happen again? |
05-02-2013, 03:49 PM | #1955 |
Haha you know what? As crazy as that sounds, it may have happened. I have those silly Fatlace dice valve stem caps and the little o-rings in there fall out and maybe it got seated incorrectly when I tightened it down putting enough pressure on the valve stem to slowly leak out air.
I didn't even think of that. |
05-07-2013, 06:30 PM | #1961 | |
Here are my 265/35 on a 12.5 wheel. |
05-07-2013, 07:09 PM | #1963 | |
06-08-2013, 06:29 PM | #1967 |
Look in my recently started threads and I have a thread where I stretched Michelin pss, those tires make any nitto feel like a bicycle tire.
07-15-2013, 08:20 AM | #1969 |
Wish we had some tire stretching experts here in AZ. I can't find anyone to stretch a 245/35 on an 11.5 & 225/35 on an 10.5...had to go with a 235 on the 10.5 and 255 on the 11.5
07-29-2013, 01:31 PM | #1978 |
it seems like the sidewalls dont want to flexxxx.
there has been a 255/35 feds on 12.5 vsxx but they have diff style drop centers. any tips to get the sidewalls to flex a bit more. i also tried the starter fluid/fire trick. idk if im doing it right or using enough but it ends up as a bail of fire and no air explosion/pop. btw i have went to 5 tire shops and all of em are pussies either turning it down, or can't do it. They have used a cheetah-5, cheetah-10. idk i want to get this stretch so badly lol |
07-30-2013, 08:38 PM | #1980 |
I almost had it to bead on the inner barrel side, I think im not using enough starter fluid lol if I cant get it to work ill get some 265/35s.. which would be better to stretch 265 Achilles or 265 federals
