10-27-2016, 02:20 PM | #20401 |
Sup dudes, so upon some investigation the previous owner stripped the balls out of the threads on the 3 holes located on top of my valve cover!!!! Yay! So yea i redrill and tap them but what bolts should i use? Just seeing if anyone here has come upon this before i start trying a bunch of different bolt sizes and shit. Any spoon feeding would be greatly appreciated!!! Sent from my iPhone using Tapatalk
https://www.instagram.com/jdpowersport_/ |
10-27-2016, 02:30 PM | #20402 | |
10-27-2016, 09:13 PM | #20405 |
I have a MAJOR LEAK coming from just behind my crank pulley, the right side (if you were in your vehicle) of your motor. Any suggestion on what my be causing the leak?
10-28-2016, 12:52 AM | #20408 |
10-28-2016, 10:20 PM | #20409 |
Can I get a price check.
these parts are used. Grade A+ NISSAN JDM K's Aero Front - S14 KOUKI HOOD FENDERS (PAIR) FRONT BUMPER HEADLIGHTS (PAIR) CORNER LIGHTS (PAIR) FRONT GRILLE SIGNAL LIGHTS (PAIR) RADIATOR SUPPORT BUMPER FILLER
10-30-2016, 12:54 PM | #20411 |
Hi everyone, trying to find any info about " * " in the end of TE37, see pic
What does it mean?
"konstbug" & "rare.wheels" at Instagram, Facebook and other sources |
10-30-2016, 01:08 PM | #20412 |
Any idea why soon as I manual switch on my fans with a switch my car bogs and dies out? Ground, alt or battery? Happens whenever my fan controller hits its temp.
10-30-2016, 08:45 PM | #20413 |
Trader Rating: (22)
Feedback Score: 22 reviews
White Smoke is coming from o2 sensor/upper down pipe area. It looks like the smoke comes from the o2. My car idles from 900 to 500 vice versa. And also the exhaust (straight pipe) back fires seems like the car is running rich. Any ideas what cause white smoke to appear?
Oil is good, coolant is good, no overheating |
10-30-2016, 10:36 PM | #20414 | |
The oil leak goes all the way to the bottom of my tranny. I'm leaning towards the the main seal. The oil leak goes all the way to the bottom of my tranny. Oil |
10-30-2016, 11:03 PM | #20416 |
The area around the main seal on the timing cover has oil build up, and as well as the side of the engine. Also, the right side of the car like the tension rod, tierod, and etc is covered in a layer of oil sludge. I'll thoroughly clean the area and try to source the oil leak. I'm hoping it's the main seal or oil pan.
11-01-2016, 02:08 PM | #20418 |
Any suggestions for tires? I have 16/18k spring rates and dont like smoke. I need suggestions for front and rear dont mind running two different treads thanks guys.
11-02-2016, 04:30 AM | #20419 | |
You could go 245 in back, but there is something really nice about being able to rotate tires for even wear because saving tire money for car parts is way better
11-02-2016, 12:31 PM | #20420 |
Would anyone know what would cause lots of play on the drivers side rear wheel when it's jacked up? It's an s13, suspension is all stock, also has a lot of wheel hop whenever I hit a bump and I'm giving it gas. I already replaced the wheel bearing but it still has the same exact play.
11-02-2016, 01:03 PM | #20424 | ||
Keep in mind that I have coilovers and the stock plastic inner fenders. So you could try that tire size along with Redline's suggestions for a little more grip.
11-02-2016, 02:19 PM | #20428 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
do NOT sand clear plastics!!! would you sand scratches out of a CD or a headlight? NOPE! the only time plastics should be sanded AT ALL is if you plan on painting over them!
as i said before, extremely fine buffing compound and a soft cloth! circular motions, takes about 2-3 minutes if you put effort into it. you can pick up a headlight fog repair kit and use the buffing compound they give you in the kit (its the white liquid crap, same thing thats distributed in CD repair kits). |
11-03-2016, 01:04 AM | #20429 |
S14 Kouki Wing Trunk
I recently installed a Silvia Ks wing or Kouki wing whatever you wanna call it on my trunk. Originally it was a wingless trunk, now the problem I have is that my trunk wont open now cause of the weight of the wing unless I have a second person lifting it as soon as I pull on the release latch from the side of the seat. Anybody know how to calibrate the release force of the trunk or have any suggestions on how to handle this? I searched on here but everyone has issues related to the cable that releases the trunk. My trunk opens fine but it now requires two people to open it. Thanks
11-03-2016, 01:13 AM | #20430 | |
