Old 05-18-2012, 01:22 PM   #1921
Stanced
Stanced's Avatar
Stanced is an unknown quantity at this point
my buddy chris' RHD Silvia....thought id put my wee lil input...lol
90'/wingless/no sunroof/no hud/5 speed(i THINK it was originally auto/NC...well...japan...but nc for now...lol
WHAT WHEEL GAP??
Stanced is offline   Reply With Quote
Old 05-19-2012, 03:54 AM   #1922
Pink Slut
Pink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud ofPink Slut has much to be proud of
fix that saggy lip tho, i HATE that
Pink Slut is offline   Reply With Quote
Old 05-21-2012, 11:08 AM   #1923
axiomatik
axiomatik's Avatar
yeah, would look way better without any lip.
Old 05-21-2012, 11:53 AM   #1924
Wake
Wake's Avatar
Im really considering NOT putting a piggy lip on my silvia front.
Im also not talking about my 2tone so I guess ill shut up.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 05-21-2012, 03:35 PM   #1925
!Zar!
!Zar!'s Avatar
I hate the way it looks.
Maybe because kids are always using the lip as a snow plow.
Old 05-21-2012, 04:48 PM   #1926
240sxdriftin
Trader Rating: (25)
240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of240sxdriftin has much to be proud of
Feedback Score: 25 reviews
I don't get it.... Why can't they mount it correctly? Does it not fit over the ridge on silvia front bumpers like it does stock?
IG: @bwagg88
240sxdriftin is offline   Reply With Quote
Old 05-21-2012, 07:49 PM   #1927
Wake
Wake's Avatar
I have all the OEM mounting hardware from the original lip and a bunch of spare shit siting around that I was planning on using, But I dunno. If i do it and it doesnt look like complete ass i might stick with it.
I guess I cant really hold my breath for a silvia lip. 2tone is getting a aero bumper asap so its not a situation i have to worry about.
S.P.P.S. Member #00
Old 05-22-2012, 10:44 AM   #1928
!Zar!
!Zar!'s Avatar
I need to find a spot that repairs urethane in the bay. My aero bumper is still sad after a car hit it during tandem.
Old 05-27-2012, 03:32 PM   #1929
s13Kurt
s13Kurt is an unknown quantity at this point
Originally Posted by vw203 View Post
I can play, 91 silvia K aero (all factory) my first S chassis car got it basically stock about a month ago parts arrive daily for my build. I will say I own a e46 M3 as well and have had a TON of euro cars, I absolutely love my s13 and I may never be able to part with it. Not many cars I can say that for
Color of car: tan/grey
Build date: 91
original transmission: 5sp
sunroof: no
HUD: no
wing: factory yes, now no
State: CT
black/grey interior
couple changes since these pics, have a few little nismo items shift knob braces ect and a c pillar bar as well
Can I get a paint code on this. Fuck platinum blue my car has to get repainted this color. Much more classy in my opinion.
s13Kurt is offline   Reply With Quote
Old 05-27-2012, 04:33 PM   #1930
spray2020
spray2020's Avatar
spray2020 is an unknown quantity at this point
I have repaired two damaged aero bumpers recently. And yes, since they are urethane you cant plastic weld them- but any urethane glue (I used selleys usethane glue) works very well. A very strong bond if the urethane is sanded before the glue is applied.
The best method i've found to work is: get a hot glue gun and from the front- use the hot glue to hold the cracks in the right position- then from the back, use a dremel to scuff up the crack and create a gulley/groove and sand all around the crack with 60/80 grit, at least 25mm on both sides of the crack. Then after the front side is all sealed up (since the urethane glue can run), apply the urethane glue and let it sit over night. then once cured, pull the hot glue off the front, and use a dremel to bevel/groove the crack on the front side. Then, if you really want a right bond- go get a 1mm drill bit and drill a bunch of holes right along either side of the crack- very tight to the crack- then run hobby wire through the holes and criss cross it and pull very tight. Then you can finish up with fiberglass filler on the front and block sand smooth. I usually only use the hobby wire if I can bevel the crack low enough so that the hobby wire wont show though the filler once it is sanded. After that, you will have a very strong repair. The urethane glue is great stuff. I can post photos if you would like?
spray2020 is offline   Reply With Quote
Old 05-28-2012, 08:05 AM   #1931
Johny5
Johny5's Avatar
http://www.cartype.com/pics/305/full/volvoc3008_08.jpg
anybody seen this color in real life? its amazing! would look fantastic on a coupe imo, the white is filled with metallic
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 05-28-2012, 08:19 AM   #1932
Bluejayde
Bluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond repute
I've considered downgrading to an S13 just so I can have a two-tone coupe. I love these things!
Bluejayde is offline   Reply With Quote
Old 05-28-2012, 08:38 AM   #1933
EhrikETFG
EhrikETFG's Avatar
EhrikETFG is an unknown quantity at this point
yup it is that cool
EhrikETFG is offline   Reply With Quote
Old 05-28-2012, 09:28 AM   #1934
gearhead55
gearhead55's Avatar
s13 ain't a downgrade from nothing.
I'm offended.
especially if you have an s14
gearhead55 is offline   Reply With Quote
Old 05-28-2012, 12:40 PM   #1935
!Zar!
!Zar!'s Avatar
I've gone from s13 to s14, back to s13.
It's a downgrade.
And my car is two tone.
Fuck me.
I would trade it for an s14 in a heartbeat.
Old 05-28-2012, 12:55 PM   #1936
Wake
Wake's Avatar
i have been considering buying a zenki for DD duties. However it will NOT be 2tone.
S.P.P.S. Member #00
Old 05-28-2012, 05:40 PM   #1937
s13Kurt
Anybody? Mssglegnth
Old 05-28-2012, 05:49 PM   #1938
gearhead55
gearhead55's Avatar
It's a downgrade.
Fuck me.
obviously, I'm joking.
Old 05-28-2012, 05:59 PM   #1939
240sxdriftin
Trader Rating: (25)
IG: @bwagg88
Old 05-28-2012, 06:20 PM   #1940
ericcastro
ericcastro's Avatar
Im always bummed to come here and not see the stock purple two tone coupe.
Its the only 240sx i think is worth saving.
Old 05-28-2012, 06:41 PM   #1941
spray2020
spray2020's Avatar
^example photo?
edit: this one?
Old 05-28-2012, 07:17 PM   #1942
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
everytime i look at this thread it makes me want another two tone lol
pic of my two tone before i sold it
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 05-28-2012, 07:29 PM   #1943
s13Kurt
My twoe.
89
Platinum blue with blue interior
Hud
Power windows
No wing
5 speed
File Type: jpg ImageUploadedByTapatalk1338254914.442703.jpg (248.5 KB, 31 views)
File Type: jpg ImageUploadedByTapatalk1338254954.080043.jpg (203.5 KB, 27 views)
Old 05-28-2012, 07:35 PM   #1944
s13Kurt
Couple more
File Type: jpg ImageUploadedByTapatalk1338255295.490001.jpg (184.7 KB, 21 views)
File Type: jpg ImageUploadedByTapatalk1338255316.959326.jpg (252.9 KB, 23 views)
Old 05-28-2012, 10:29 PM   #1945
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
There is no such thing as a "stock purple two-tone 240SX." You will forever be bummed out.
Please do.
-Kyle
Old 05-28-2012, 11:06 PM   #1946
ericcastro
ericcastro's Avatar
I always thought it was 2tone, but its just a single color.
Think its the rarest of them all though, right?
Think Ive only ever seen 1 picture of a car this color and it was for sale but in bad shape.
Lavender Metallic
Medium Lavender Metallic Clearcoat (2-tone) LG1 Touch Up Paint for 1989 Nissan 240SX
All the 1989 colors
1989 Nissan 240SX Touch Up Paint - Colors for 1989 Nissan 240SX
EDIT
Originally Posted by Yuri View Post
Lavender frost. This color was offered in the US only in 1989. In Japan it was offered on the Silvia as a two-tone scheme, and was still offered on the SR-powered S13's
http://zilvia.net/f/chat/101705-s-ch...-egg-hunt.html
Old 05-28-2012, 11:46 PM   #1947
soreballz
soreballz's Avatar
Trader Rating: (22)
^That particular color was never offered in a two-tone scheme. We debunked that claim some time back in this very thread. But yeah, it is the rarest US S13 color, and it would look rad as a two-tone.
-Kyle
Old 05-29-2012, 08:33 AM   #1948
Wake
Wake's Avatar
Yes to that mans statement.
S.P.P.S. Member #00
Old 05-30-2012, 04:17 PM   #1949
ladylike
ladylike's Avatar
ladylike is an unknown quantity at this point
Color of car:blue and grey
Build date:88
original transmission:auto
sunroof:yes
HUD:yes
wing:no
State:Fl
ladylike is offline   Reply With Quote
Old 05-30-2012, 04:20 PM   #1950
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
now thats classy^^
jdm2191 is offline   Reply With Quote
