Old 11-03-2011, 12:22 AM   #8401
mowgli 240sx
mowgli 240sx's Avatar
mowgli 240sx is an unknown quantity at this point
for a 25mm bolt on spacer
to replace a stud on them can they use regular wheel studs as replacements??
sorry if this is a dumb question just need an answer asap
mowgli 240sx is offline   Reply With Quote
Old 11-03-2011, 01:00 AM   #8402
chiboy002
chiboy002 is an unknown quantity at this point
it all depends on the company that makes it
some, such as Ichiba, use larger studs so you have to buy from them. Same goes for their hubs
Call whoever you bought it from and ask, or call them direct. Or take the spacer to a shop that sells the lugs and have one already out for reference
Old 11-03-2011, 02:17 AM   #8403
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
Hello im having trouble with my e-brake locking up my passenger side. i thought i had a stretched out cable but i replaced it with a good passenger one. i even rerouted it on the underside of the subframe so the subframe wouldnt pinch it "pbm solid risers" and its still not engaging. i tightened halfway at the nut under ebrake handle so it was tight on drivers but still easilly spinable on passengers side.....
i looked at where the two cables connect to the e-brake T bracket and ones pulling more than the other so its lopsided kinds like an =/-- < thats where the two connect to the T bracket one one sides pulling more than the other..... ill upload pictures if needed.
can someone give me some help on fixing this... is my passenger caliper just done or what?
you could kind of see how the bracket that connects the two cables is crooked..
Renelovesnike is offline   Reply With Quote
Old 11-03-2011, 12:17 PM   #8404
pandapoo503
pandapoo503's Avatar
pandapoo503 is an unknown quantity at this point
Send a message via AIM to pandapoo503
anyone know what size/thread pitch bolt is used to hold up the drive shaft support?
pandapoo503 is offline   Reply With Quote
Old 11-03-2011, 02:45 PM   #8405
xislander
xislander is an unknown quantity at this point
Does anyone know a good place to buy a OBD2 to OBD1 step down harness? or is anyone selling one here?
xislander is offline   Reply With Quote
Old 11-03-2011, 03:23 PM   #8406
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by Origin View Post
I apologize for my incredible stupidity.
Haha no worries dude, it's not like any of us grew up/woke up knowing this stuff either
Originally Posted by chiboy002 View Post
i know i know, you told me this a while ago too
i already have em, not sure if i wanna put em on or not. Endless is dicking me about exchanging them for the ones i want. vividracing fucked me over the first time, and now doing it again
FS: JDM Endless CC pads
That would be the way to go.
Either that or just run them. Any pad worth it's salt is going to dust dust dust.
Originally Posted by memphis180sx View Post
hey has anybody ever ran the pbm under rad support front mount with ac
To my knowledge no, as where the pipes go are where the AC lines come through the rad support
Wiring Specialities
WiringSpecialities.com
Old 11-03-2011, 03:48 PM   #8407
xislander
sorry but i couldnt find it on wiringspecialities.com or maybe im just retarted
Old 11-03-2011, 03:49 PM   #8408
Wake
Wake's Avatar
maybe you should email and ask them instead of asking here over and over.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 11-03-2011, 04:02 PM   #8409
dontxploitme
dontxploitme's Avatar
dontxploitme is an unknown quantity at this point
i upgraded the bulbs in my climate control and the buttons around the steering column to led's and they look great! but.... they turn on when the car is on and they turn off when i turn the headlights on. so...
headlights off = climate control lights on
headlights on = climate control lights off
is that normal?
dontxploitme is offline   Reply With Quote
Old 11-03-2011, 04:12 PM   #8410
Wake
Wake's Avatar
Maybe you have the polarity reversed. A lot of LEDs can only be put in one way.
S.P.P.S. Member #00
Old 11-03-2011, 04:53 PM   #8411
dontxploitme
each one though? that was my first thought also but then i thought what the chances were of me getting them all backwards lol
Old 11-03-2011, 04:59 PM   #8412
chiboy002
stupid question, but!
is it possible to "reclock" a shift knob?
like on oem shift knobs, if the pattern is facing the wrong way - how can i fix? Just grind off the shifter so the thread stops at a different spot?
already tried loosening it then using threadlock, didnt work
Old 11-03-2011, 07:09 PM   #8413
NissanSean
NissanSean's Avatar
NissanSean is an unknown quantity at this point
i dont know if anyone posted this question yet
my rear taillights(brake only) on my coupe stay on...
how do i fix that?
thanks in advance
NissanSean is offline   Reply With Quote
Old 11-03-2011, 07:25 PM   #8414
lalo167
lalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the rough
Are Isis, Godspeed, and Megan Racing arms made from the same company?
lalo167 is offline   Reply With Quote
Old 11-03-2011, 09:27 PM   #8415
memphis180sx
memphis180sx is an unknown quantity at this point
how do i fix that?
thanks in advance
brake light switch its under the brake pedal assembally and the part is only like 10 bucks but its a pain to get it perfectly adjusted right
memphis180sx is offline   Reply With Quote
Old 11-03-2011, 09:28 PM   #8416
memphis180sx
no there all made buy diffrent people
Old 11-03-2011, 10:07 PM   #8417
codyace
codyace's Avatar
Trader Rating: (58)
I'm actually limited, and can't spell
Nissan/Datsun Wiring Harnesses
Retighten it more until it's straight.
Same junk, same block, different check writers.
Old 11-04-2011, 01:36 AM   #8418
boyou2
boyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura about
does anyone knows where to find s13 CF ashtray for an LHD?
I've found a lot done for RHD, but they don't wanna do for LHD :/
THX.
boyou2 is offline   Reply With Quote
Old 11-04-2011, 03:39 AM   #8419
NoPistons!
NoPistons!'s Avatar
NoPistons! is an unknown quantity at this point
because i'm too drunk to find the "engine" section...(ka-t???)
Wanting to run blow thru maf but NO bov.
Is this going to throw my afr's off like woah or am i gucci?
I searched and it seems most are runnign their mafs pre-turbo no bov.
Here's why i DONT want to run a bov.
1. They waste boost
2. They sound like you're beating a cat while drowning it while firecrackers are exploding deep in it's anus. I love animals. I do not abuse animals but i'd assume that's how it would sound.
3. They draw too much attention and everyone wants to race because OMG TURBO BOV OMG JDM!
4. I dont care about the bearings in my turbo. If you can't rebuild a turbo you are a retard and have no business owning a turbo car let alone giving advice on one.
5. Flutter sounds like birds chirping while the Beijing cocktail is coursing through your veins. THAT sounds cool to me. Personal preference.
Here's why i'm asking:
I AM NEVER BUYING FORGED INTERNALS FOR A KA EVER. There is no need for my goals. Hell, at 400hp and under there's no need. BUT the key here is that perfect tune that keeps detonation from happening.
Detonation does 2 things. Causes stress on the rods and causes stress on the ringlands. We all know what happens when either of those parts can't take anymore.....
I've read that chances are low for something bad to happen on decel but you never know.
Thanks!
Just another broke ass drifter
NoPistons! is offline   Reply With Quote
Old 11-04-2011, 07:56 AM   #8420
Origin
Origin is an unknown quantity at this point
On the premise of that, I have oil coming out of my pan and I didn't fill it with oil yet. It's obviously leakdown from the head but I thought I sealed it real good. I REALLY don't want to take it off again. What do?
Origin is offline   Reply With Quote
Old 11-04-2011, 08:18 AM   #8421
cotbu
cotbu's Avatar
1. They waste boost
Thanks!
All you have to do is move it and verify voltage and afr.
Ideally yes it's going to screw with the afr because the air is cooler and that's how a hot wire mafs works. "the denser air will remove more heat from the wire indicating a higher mass airflow." So even at idle, you should see a difference.
The reason you are contemplating this is because you are able to tune the ecu, correct?
You will be able to compensate for this minor but major(oxy) change if you have control over the ecu. How well it will work depends on your ability to tune a mafs based systems.
You didn't fill it with oil yet.... so how do you know it's leaking?
Is it seeping from the pan gasket area or the drain hole? If it's coming from the head to the pan, out the drain. Then that's normal. Always clean the area and you'll know for sure. That lil bit of oil left in the head should not seep out from the pan gasket, Fill and verify or pan gasket redux!
Old 11-04-2011, 10:41 AM   #8422
Origin
Well it was very strange, two sets of eyes couldn't find oil on the front cover, which is where it should have come from. It was leaking only under the crank pulley. It seemed to have appeared from no where. But, I took it off and resealed it none the less. Hopefully it will stay.
Old 11-04-2011, 11:44 AM   #8423
NoPistons!
NoPistons!'s Avatar
Thank you sir. And i am working towards msII but might have to settle for an safc/emanage to get me by til then. I'm a fan of map based systems actually.
Old 11-04-2011, 12:45 PM   #8424
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
does anybody have any info on these supermade S13.5 fenders? i tried searching but i cant find anything and i already sent an email to supermade but didnt get a reply yet. i would like to cop a pair.
0showdown2008_017 by d_2jzgte, on Flickr
killer240 is offline   Reply With Quote
Old 11-04-2011, 03:19 PM   #8425
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
So at the last track event I jumped over a rumble strip and caught air. Didn't think anything of it, until I looked under my car. My frame rail has a huge bend in it. I'm not too concerned with it, but I'm just wondering if it'll affect anything too much...
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 11-04-2011, 03:56 PM   #8426
mowgli 240sx
anyone know a good place to get my wheel wells tubbed out?
im located in socal 909 area so any shop local would be great
Old 11-04-2011, 06:16 PM   #8427
chiboy002
i know that, but its like the oem shift knob, once you tighten it to a certain point it just starts to twist the shifter.
I don't want to shim it yet, that seems like it could potentially rattle and annoy me
Old 11-04-2011, 07:53 PM   #8428
Ekin_s13
Ekin_s13 is an unknown quantity at this point
can someone tell me why i can't visit this page
http://www.zilvia.net/f/showthread.php?t=137260
is it because im not a Premium Members?
Ekin_s13 is offline   Reply With Quote
Old 11-04-2011, 11:06 PM   #8429
dahrayyal
Trader Rating: (18)
dahrayyal is an unknown quantity at this point
Feedback Score: 18 reviews
So i tried making my side markers blink and looked up some tutorials, but when i wired up one side, all my side markers (front fenders and rear quarter panels) stopped working. my front turn signals and rear work, everything works except for the side markers. help?? i have checked my fuses that i have researched, everyone pretty much said the right column 3rd from the bottom, it was still good... idk now.
dahrayyal is offline   Reply With Quote
Old 11-04-2011, 11:28 PM   #8430
stance
stance is an unknown quantity at this point
Hey guys does anyone know the length of R33 ebrake cables.? If you have them off your car can you please give me a measurement? id appreciate it!
stance is offline   Reply With Quote
