12-16-2009, 11:51 PM | #1 |
Trader Rating: (29)
Feedback Score: 29 reviews
sr20det ROD KNOCK QUESTION AND HELP??????
I have a red top sr20det and i just got it running today, the main reason why i am worried is when i rev the engine up to 3 or 4 rpm i hear a knock but not at high rpms and not at idle can it be a rod knock? Or just a lifter? I don't know, i am pretty bummed out, i think its a rod knock i will get a video up tomorrow, ima go out for a drive on my daily so i can keep my mind off it, dammm
I GUESS WHAT I AM TRYING TO ASK IS; IF IT WAS A ROD KNOCK WILL IT BE KNOCKING ALL THE TIME? CLICK LINK BELOW FOR VIDEO IT DOESN'T SOUND GOOD YouTube - S7303323.AVI Last edited by sidedrifts13; 12-17-2009 at 02:40 PM.. Reason: VIDEO |
12-17-2009, 12:32 AM | #3 |
Yes it will quietly knock at idle and sound will get fast and louder as RPM's increase.
Is it a "Knock" or a "Tick" Post a vid if possible
12-17-2009, 08:39 AM | #5 |
pull the oilpan and inspect for chunks of bearing...
TW: http://zilvia.net/f/cars-sale/390459...d9s-coils.html |
12-17-2009, 09:04 PM | #9 |
Trader Rating: (58)
Feedback Score: 58 reviews
RIP SR20
That's rodknock. I've heard this 100 times you've got two options 1backyard hope for you life 100 dollar gamble)...roll a new set of rod bearings in, one size over, hope for the best 2: Get a new long block. Hope she treated you well, there's no mistaking that sound.
12-18-2009, 05:25 AM | #10 | |
Trader Rating: (29)
I figured it was a rod knock this motor was definately a pain in the butt I was pretty bumep, but now i just got to move forward and figure out what i'm going to do, i just did a t28 turbo upgrade damm o well everything has a solution except for death really.... my 240 will be out of comission for a while but i cant wait to drift the f*** out of it
12-18-2009, 01:30 PM | #11 | |
Trader Rating: (58)
12-18-2009, 02:09 PM | #12 |
Trader Rating: (29)
sounds like a plan im gonna get it fixed asap anybody know a good place where i can take it to? any local mechanics or mobile mechanics that would do the work?
12-18-2009, 02:51 PM | #13 |
Trader Rating: (58)
Are you in NJ?
12-18-2009, 07:19 PM | #15 |
Man w/ CTSV & a Car Seat
Yup, thats definitely rod knock. Only other time that I head a knock like that and it turned out not to be rod knock was with Hypnotik. His shit wasnt rod knock, it was piston slap. His #3 cylinder somehow was shaped like an egg and the piston was slapping on the the side of the cylinder.
12-19-2009, 05:51 AM | #16 |
if you are changing out the little things, you could also take this time to beef up the head, rocker arm stoppers, cams, and maybe different pistons and rods on the bottom if you wanted to go hardcore.
KA-T ORG-Function over Flush |
12-19-2009, 10:26 AM | #18 |
yes my sr makes the same noise as yours at the exact rpm range no noise below or above that rpm range, my motor has been making that noise for 4 almost 5 years now ever since it was rebuilt. the noise has not got any worse overtime.i have pulled the oil pan many times and it been clean every time. my car is daily driven every day to and from work.i don't know what the noise is there have been other people with same noise at the same rpm range.
12-20-2009, 02:58 AM | #19 |
If you can get down to LB tomorrow I will give you a couple hours of my time to check it out and give you a final answer. If it's what I think it is (other than rod knock) I may be able to fix it on the spot
Like Me on FaceBook ! |
12-21-2009, 11:44 PM | #21 |
checked out the car today in person.
This should go as a lesson to swap shops and other DIY'er to make sure to pull the oil pan and check the oil pick up condition as well as hammer out the oil pan or use an upgraded one right off the bat. These motor's are seriously sensitive to oil starvation of any kind. I have suggested that he pull the oil pan, check for copper filings from any possible bearing wear and replace the oil pick up if it's broken. If the oil pressure is just started to fail then you can catch it, get the oil pressure back up to where it needs to be and eliminate the little amount of metal on metal knock you are having with your motor. Saving it. But it will be a close one.
01-13-2010, 03:23 AM | #22 |
Trader Rating: (29)
Okay guys so I finally droped my oil pan and i found some brass shavings in the oil and also a thicker piece of brass which i am trying to figure out where it came from because it is thicker than a rod bearing and its brass on the inside and outside any ideas???????? i will have pics in a bit
01-13-2010, 03:41 AM | #23 |
Trader Rating: (29)
The small piece looks to be like a brass material anyone know where it could have shaved off from? thanks for the help and sorry for the crappy cell pics |
01-13-2010, 07:17 AM | #24 |
Trader Rating: (58)
brass could be from a thrust bearing? hard to really tell
01-13-2010, 09:50 PM | #26 |
at least your bearing didnt look like this lol...
This is what my oilpan looked like when i bought my motor... I hope all goes well with repairing your motor... i honestly would rebuild that motor...
01-14-2010, 12:38 AM | #27 |
Trader Rating: (29)
yeah mine wasn't that bad but still need to find out what that bigger brass piece is from i wonder if its from the trust bearing, or even the timing chain tensioner
01-14-2010, 09:58 AM | #28 |
Trader Rating: (58)
Tensioner would either be plastic or metal
