05-04-2014, 10:41 AM | #31 |
Newer Buddy Club rails come with the more traditional L shape brackets in addition to those stupid brackets which are pictured.
Assuming your seat is regular width. Once you buy the L brackets your seat will be able to sit lower. But being as how the slider bar is on the bottom, your seat will only be able to go so low before you aren't able to lift the bar up in order to slide the seat forward/backward.
05-04-2014, 11:05 AM | #32 |
your rails suck. if you want to go low you need Nagisa or bride rails.
LOWMAX ftw! buddy club and the like can't go lower because the use the cheap design that requires the slider release to be located under the seat which keeps the design from being lower to the floor. Bride FG and Nagisa rails have them located on the top side so they can go low to the max =)
05-08-2014, 12:18 AM | #34 |
hey dude, i installed these same poorly designed brackets today. going to try to cut, bend, and redrill them. i'll post pics this weekend.
for anyone who reads this...save up for another week and go with the bride rails |
05-08-2014, 09:04 AM | #36 | |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
The side that didn't lock would shift around during braking and accelerating. Really annoying when you're doing city driving.
05-08-2014, 09:20 AM | #38 |
Also, some racing regulations require dual locking sliders iirc.
Well, the ones that even allow sliders, that is.
My S13 SR Street Mod Build |
05-08-2014, 10:40 AM | #39 |
I have buddy club rails, but i also have a buddy club seat. The combination sits pretty low. Im abot 5'9" and with my helmet i still have a couple inches from the stock headliner in my S14 (non sunroof). I have the old style brackets BTW.
05-08-2014, 01:55 PM | #44 |
You could also modify the bracket to work. Cut and shorten the door side as seen below. Either use a high grade bolt/nut, or weld it, depending on what you have access too. For the other side, you can simply re-drill a new hole to lower it the same amount you lowered the door side. That will drop the back of the seat without having to change anything else.
Of course custom brackets would be easier, but those are much more expensive. Also, make sure you make your modification symmetrically, or else your sliders won't be perfectly lined up, and it will be harder to slide back and forth. |
05-09-2014, 01:27 AM | #46 |
I have a Cobra Suzuka in my S13. I used to have som Chinese brackets untill I saw what the seat was bolted to. 4.8 grade M8 bolts that was hardly welded to the bracket! Zipties would have been safer...
Anyway. Beeing 5'7, totaly butchering the floor and custom brackets where the only way of getting the Cobra Suzuka properly low. |
05-09-2014, 07:31 AM | #47 |
you're using the wrong side mounting brackets. when you order it new it comes with the big bracket that you currently have bolted to the rail, but they also come with 4 other small L brackets in a bag marked "schassis and ae86 specific " and they look like those in the picture a couple posts up.
DODOlogic.ca |
05-09-2014, 09:20 AM | #48 | |
05-09-2014, 09:36 AM | #49 |
Even with the 'right' mounting brackets the buddy club rails are too high. I'm 5'11 and I can't wear a helmet in my sunroof s14 with the buddy club rails. My seat could not possibly go any lower in between the buddy club rails because it is sitting on the slider locking mechanism. The only way to get the buddy club rails (and hence the seat) to go lower would be to shorten the legs on the mounting bracket. My seat is a Recaro SPG.
05-09-2014, 11:12 AM | #50 | |
05-09-2014, 04:44 PM | #51 |
Can't you flip those brackets and run them under the rail? Would be the same as flipping the Nagisa brackets. You would just have to modify the bends a little bit. Should be able to put the seat on the floor after that. |
05-09-2014, 05:56 PM | #53 | |
http://i1157.photobucket.com/albums/...ps5defae94.jpg Read what PrimeDirective and I said in our previous posts. |
05-09-2014, 06:22 PM | #54 |
no need for discussion
if you want to go low. get the right seat rail/brackets Bride FG or Nagisa ultra low seat rails FTW 6' tall with helmet in a S14 and still have room on top (using bride FG)
05-09-2014, 07:59 PM | #55 |
Nagisa rails w/ flipped rear brackets = lowest possible setup.
ACE マジック HEART |
05-20-2014, 08:53 AM | #56 |
can u flip the rails on bride fg?
looks like u can, but the bolts and stuff will get in the way of the slider unless u bolt it to the NOW lowest positon (which is the highest position when its not flipped upside down) I ran into the additional problem that I have a status GT seat which is extra wide. I had to drill out the mounting holes to space out the rails to fit the seat. doesn't slide as nice now thou (I suspect the rails are now in a pizza shape instead of perfectly parallel to each other)
05-20-2014, 09:23 AM | #57 |
Just an FYI to those saying you can just flip NAMS brackets to go lower. IT all depends on your seat. Also on the center console side rail you need some really flush hardware if you want to keep any adjustment.
