09-22-2012, 01:32 AM | #1 |
1995 240sx 5spd
1995 240sx s14
Clean title 235,000k, good compression runs great Recently did front main, alternator, engine and trans mounts (high performance urethane), all fluids replaces with synthetics. New dizzy and rotor, plugs ,wires SE with leather, V-LSD, and A/C -- no sunroof Tein sway master C/O God speed tension rod, toe arms, ruca, traction arms. . .. . .everything but lower control arms but will come with rear lower a arms God speed sway bars with new energy end links. Front and rear strut bars B&N style short shifter Sparco steering wheel Injien intake Pacesetter long tube headers with catt. Delete pipe. . .. . .will come with factory headers. Z32 turbo front brake upgrade Blitz Nur spec with apexi control valve , will also come Apxei style dual exhaust Will come with JIC j-force 7 wheels in 17x9 F and 17x10 R (i have stock wheels available as well) CX racing aluminum Radiator New sony head unit with aux and Bluetooth body needs some TLC and the leather is torn on the bottom for the front seats and cracked at top of back. Engine light on due to header and ABS light on due to front passenger wheel bearing assembly being replaced with NON -- ABS unite (new one will cost you $80) Price - $4600 Call or txt 818-939-268 three |
