06-13-2012, 06:57 PM | #1 |
rb25 cylinder 5 bad compression
I just decided to do a compression test and I saw that all cylinders were about 150 except number 5 , it was about 75psi. I dropped oil there and it went up. BUT before I call it the rings let me also say that its smoking whitidh blue quite a bit through exhaust but there is no mixing of oil and coolant in the engine or radiator?? There is oil coming from the back of the motor around the cylinder 5&6 area. I can't tell if its coming from directly between head and block but it does kinda looks like it. Could it still be a bad hg? Could putting oil in cylinder and making the compression go up be a sign of a bad hg? Or is that only for rings?
06-13-2012, 07:15 PM | #2 |
Man w/ CTSV & a Car Seat
If the compression jumped after dropping oil in there, its the rings. If you dropped oil and it didnt jump, then its something else like the HG or the valves.
06-13-2012, 07:20 PM | #3 |
[QUOTE=fliprayzin240sx;4746123]If the compression jumped after dropping oil in there, its the rings. If you dropped oil and it didnt jump, then its something else like the HG or the valves.[/QUO
The rings could also be the reason for the smoke? Oil getting past rings? |
06-13-2012, 09:34 PM | #5 |
06-13-2012, 09:48 PM | #6 |
Correcto...most of the time, if the cross hatching is still there, you dont have to re bore it. Just make sure theres no nick in the cylinder. But 75psi on 1 cylinder when everything else is at 150psi, it might even be a cracked ring land.
06-13-2012, 09:53 PM | #7 |
Well the thing is that it still runs good and pulls pretty hard so I'm gonna guess its just the rings and not the Piston or walls (hopefully). If the walls need reboring, that means I can't use the OEM pistons right? I would have to buy after market ones to match the bore size correct? Please correct me if I'm wrong man lol
06-14-2012, 10:51 AM | #9 |
OK guys this is weird and is really puzzling me. I just let it run for awhile to burn out the oil I poured into it and did another compression test, and now cyl 5 is between 150-175 like all the others? Hows that possible?
06-14-2012, 11:09 AM | #10 |
the oil has coated the top of the piston and the cylinder walls, new engine oil is very thick, not like depleted oil like in the engine and it has sealed the leaking area. give it a few drive cycles and it will go back down. best to take it easy on it until the problem is fixed. without the cylinder combusting with correct cylinder pressure can be harmful.
06-14-2012, 12:01 PM | #11 | |
06-14-2012, 12:21 PM | #16 |
06-14-2012, 12:26 PM | #18 |
Pistons.
Nissan A2010-21U72 OEM Engine Piston RB25DET 86.5mm Oversized R33 | eBay Rings. Nissan 12036-21U00 OEM Piston Rings RB25DET 86.5mm RB25 ECR33 R33 RB | eBay I considered chucking a set in my 25 but my pistons and bores are in awesome shape so I just got new stock rings instead. |
06-14-2012, 12:29 PM | #19 | |
06-15-2012, 08:32 AM | #22 |
06-15-2012, 09:50 AM | #25 |
Look up fsm crank specs, rent a mircometer/caliper only takes maybe. 20-30 minutes to go over it. Chances are its all original still and you need standard size.
06-15-2012, 11:11 AM | #26 |
ok so i can just buy all original main and rod bearings? im kinda stuck on how to check the clearance? and why do i need to if im going with all oem standard parts?
06-15-2012, 03:30 PM | #28 |
06-15-2012, 07:41 PM | #29 | |
You need to remove all oil from the bearing surfaces, grab a piece of plastigauge stick it on the bearing surface, tighten the bolts to correct tension(46-52nm for Crank bolts & 14-16nm plus an additional 60-65 degrees for rod bolts) DO NOT TURN THE MOTOR. Then unbolt and check the width of your plastiguage with the supplied card. You won't have clearances of .001(Thou or MM I'm not sure which you mean but either is a way smaller clearance than you need) Clearances are. Rods Standard 0.2-0.3mm Limit 0.4mm Mains. Standard 0.05-0.18mm Limit 0.3mm Yes you can just chuck ACL bearings in but during assembly you WILL need to measure again to ensure you have correct clearances. The standard bearings are all graded with the grade of each bearing in the engine stamped on the front most counterweight on the crank(Mains on the top, rods on the bottom, left to right = front to back) If you want to go stock bearings you'll need to order the right ones or go up in sizes depending on wear on the crankshaft itself. |
06-15-2012, 09:23 PM | #30 | |
