04-14-2015, 12:26 PM | #18121 |
^^ Thanks, anyone use the sr20det rebuild and install dvd advertised on this site? I know a few PEOPLE complained they never got a disc!
04-14-2015, 01:54 PM | #18122 |
Sweet! Why haven't 240 guys been doing this sooner?!? Rivets look like shit!
"Simplicity is the key to brilliance." - Bruce Lee |
04-14-2015, 02:51 PM | #18123 |
04-14-2015, 02:53 PM | #18124 |
04-15-2015, 10:31 AM | #18128 |
So random issue I am having, I have my car back together, basically rebuilt the whole front suspension, new inner/outer tie rods, new LCA's (new inner bushings and balljoints), adjustable tension rods.
When the car is stopped, and the wheel is turned in either direction, the steering wheel and wheels sort of shimmy, I don't recall this happening before, am I looking at a bad rack? I've never had to replace or diagnose a rack and pinion so I'm not sure if this is a typical symptom. Alignment is done, with the exception of having my caster angle adjusted (will be completed today), but I don't imagine this could cause my problem, could it? |
04-16-2015, 06:14 AM | #18130 | |
04-16-2015, 06:23 AM | #18131 | |
04-16-2015, 08:15 AM | #18132 |
04-16-2015, 08:27 AM | #18133 | |
04-16-2015, 12:01 PM | #18134 |
Just got my holset today but can't find any info from the numbers on the plate
Assy. 4035961 Serial. H050201466 Customer 2853198 Model hx35 It's a non wastegate t3 twin scroll flange, v-band downpipe 7blade cold side 12 blade hot side 19L4 cast into hotside |
04-16-2015, 01:47 PM | #18135 |
So for awhile now I keep getting a mix of ecu codes on my 1991 and its either 13 which is maf (im cleaning it today) or 34 which is my knocksensor.
While idling today, I change my safc view settings and displayed the knocksensor and It just stayed on 0, i just got the car and im not sure if he even hooked up the safc knock wire but is there any way to check my knocksensor? I multimeter tested the wire and got good numbers so next thing im guessing is get a new one for 30 bucks. Or go to a scrap yard and get one off another 240 or even an altima or 300zx |
04-16-2015, 02:04 PM | #18136 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
04-16-2015, 07:03 PM | #18137 | |
Capped of connector
I don't know if that helped but at least i validated that its not there Last edited by kashira kureijii; 04-16-2015 at 07:04 PM.. Reason: off was spelled wrong |
04-16-2015, 07:09 PM | #18138 | |
Trader Rating: (40)
Feedback Score: 40 reviews
65823-28e00 |
04-17-2015, 06:32 AM | #18140 |
Semper Fi, Devil Dog.
That's the same part number I just got from nissanpartszone.com
04-17-2015, 12:23 PM | #18141 |
Does anyone know of a company that makes a rep of a BN type 3 front bumper for a 180sx??
http://www.bn-sports.co.jp/2door/ima...x_t3_front.jpg |
04-18-2015, 08:59 AM | #18143 | |
04-18-2015, 10:49 AM | #18144 | |
Just trying to get my hands on a front bumper fast before paint but I cant seem to find any reps. |
04-18-2015, 07:20 PM | #18145 |
Can someone help me with a part number or where to find a replacement for the pin and clip that retains the clutch pedal to the clutch master cylinder? Or is it ok to use some hardware store part for that? Anyone have experience with finding what to use for it?
04-18-2015, 08:19 PM | #18147 | |
Hardware+2 http://www.courtesyparts.com/0092310...-p-137913.html
04-23-2015, 09:21 AM | #18148 |
1992 240sx with S14 SR20DET swap.
What's all wrong with this? I assume I'm missing a seal at that bearing? U joint also seems to be slinging grease. Anything else I'm missing? I also haven't checked/changed the trans oil yet but wouldn't be surprised if it was a 'little' low... |
04-23-2015, 09:32 AM | #18149 | |
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
