Old 07-22-2017, 08:07 PM   #1
Trav1s
Trav1s is an unknown quantity at this point
Weird issue 180SX CA18DET
Hi,
Got a bit of a weird issue, CA18DET, standalone ECU, no MAF (MAP sensor), yellowjacket coils. Do not get any spark on crank, but yet if we remove the CAS and spin it manually, it'll spark everytime. But as soon as we put the CAS back into the motor, no spark. Both moons are good (exhaust cam and CAS), have tried 3 different CAS sensors.
Any suggestions will be much appreciated.
Thanks,
Trav1s is offline   Reply With Quote
Old 07-23-2017, 08:20 PM   #2
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Check your wiring harness with a multimeter? If you tried that many Cam angle sensors I'd start with the connector section.
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
