08-11-2011, 05:36 PM | #1 |
Parts Shop MAX ~PRO MULTILINK~ Fresh stock arrivals ~ Live quotes & orders in thread!
We are very proud to present the first pieces of the 2011 Parts shop MAX PRO multilink. These new arms and rods are stronger than ever with thick reinforced structures, all Forged critical components, and more thread overlap than anyone else. MAX multilink has been the pioneer in getting more clearance for lowered cars than any other brand for years. You get the adjustability you need to dial in your cars maximum performance. They let you set your personal preferences on characteristics like turn in, grip, tire wear and drift initiation while eliminating OEM rubber bushings for a precision, predictable, tactile driving experience. The quality and design is unmatched by more expensive Japanese brands and the unique design features make them an unbeatable value. The PRO arms and rods feature FORGED Baja 1000 off road spec clamping rod end receivers, adjusters, nuts and even forged rod ends so that you can set it and forget it, constantly tightening your adjustments is a thing of the past. We also have you covered in the future with 4 year free bearing replacement and lifetime warranty. Don't get caught up buying cheaper arms twice, do it once and do it right. The MAX multilink can be complimented by using or famous Subframe Collars or Subframe Solid Risers, for a perfectly tuned suspension setup. You can buy stuff and get live shipping quotes right here in this thread! Simply click the blue add to cart link to check it out. VIEW CART MAX PRO RUCA ~ IN STOCK NOW!! ~ $250.00 ADD TO CART MAX PRO TOE ROD ~ Release is OCTOBER ~ Reserve yours by ordering today! $250.00 ADD TO CART PRO TRACTION ROD ~ Release is OCTOBER ~ Reserve yours by ordering today! $200.00 ADD TO CART PRO TENSION ROD ~ Release is OCTOBER ~ Reserve yours by ordering today! $220.00 ADD TO CART PRO FLCA/TENROD Combo ~ Reserve yours on Septembers shipment by ordering today! $550.00 ADD TO CART PRO RLCA ~ Reserve yours on the September shipment by ordering today! $550.00 ADD TO CART MAX SUBFRAME COLLARS - IN STOCK NOW $50.00 ADD TO CART SUBFRAME SOLID RISERS - IN STOCK NOW $100.00 ADD TO CART 2011 Parts shop MAX PRO multilink - TENSION ROD ~ lifetime manufacturers defect warranty ~ 4 Year free pillowball replacement ~ All steel tubular construction ~ Teflon lined spherical bearings ~ Forged Clamping lock nuts makes double sure your settings never come loose ~ Forged super long rod end and bracket threads have the most thread overlap and more adjustability than anything on the market ~ Adjuster on the opposite side of the subframe for easier adjustments ~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion ~ Super thick asymmetric mounting bracket ~ Copper and Gold plated finish 2011 Parts shop MAX PRO multilink - TRACTION ROD ~ lifetime manufacturers defect warranty ~ 4 Year free pillowball replacement ~ All steel tubular construction ~ Teflon lined spherical bearings ~ Forged Clamping rod end receiver ~ Forged Clamping lock nut makes double sure your settings never come loose ~ Forged super long adjuster threads have the most thread overlap and more adjustability than anything on the market ~ Adjuster on the opposite side of the subframe for easier adjustments ~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion ~ Laser cut mounting bracket ~ Copper and Gold plated finish 2011 Parts shop MAX PRO multilink - TOE ROD ~ lifetime manufacturers defect warranty ~ 4 Year free pillowball replacement ~ All steel tubular construction ~ Teflon lined spherical bearings ~ Forged Clamping rod end receiver ~ Forged Clamping lock nut makes double sure your settings never come loose ~ Forged super long adjuster threads have the most thread overlap and more adjustability than anything on the market ~ Adjuster on the opposite side of the subframe for easier adjustments ~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion ~ Laser cut reinforced mounting bracket ~ Copper and Gold plated finish 2011 Parts shop MAX PRO multilink - RUCA - Rear Upper Control Arms (camber) ~ lifetime manufacturers defect warranty ~ 4 Year free pillowball replacement ~ All steel tubular construction ~ Teflon lined spherical bearings ~ Forged Clamping rod end receiver ~ Forged Clamping adjuster ~ Jam nuts make double sure your settings never come loose ~ Forged super long rod end has the most thread overlap and more adjustability than anything on the market ~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion ~ Laser cut 5mm thick mounting bracket ~ Copper and Gold plated finish 2011 Parts shop MAX PRO multilink - FLCA - Front Lower Control Arms With Tension Rod Set ~ lifetime manufacturers defect warranty ~ 4 Year free pillowball replacement ~ Thick all steel tubular arm/rod ~ Teflon lined spherical bearings in all 6 joints ~ Forged Clamping rod end receiver ~ Forged Clamping lock nuts make double sure your settings never come loose ~ Forged super long rod ends have the most thread overlap and more adjustability than anything on the market ~ CrMo adjustable taper rod so you can tune/eliminate any remaining bump steer ~ Integrated tension and lower control arm for much more strength than the OEM style 2 bolt flat bracket connection ~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion ~ Taper wall bearing housing for max misalignment ~ Laser cut double position sway bar bracket & gusseted heavy duty tension rod bracket ~ Copper and Gold plated finish 2011 Parts shop MAX PRO multilink - RLCA - Rear Lower Control Arms ~ lifetime manufacturers defect warranty ~ 4 Year free pillowball replacement ~ All steel tubular construction ~ Teflon lined spherical bearings in all 6 joints ~ Forged Clamping rod end receiver ~ Forged Clamping lock nut makes double sure your settings never come loose ~ Forged super long rod end has the most thread overlap and more adjustability than anything on the market ~ CrMo taper rod is available in custom lengths so you can control your camber gain ~ Low profile perimeter allows for wider wheels than the stock RLCA ~ Bell shaped high surface area pillowball side spacers reinforce subframe mount & give freedom of PB motion ~ Taper wall bearing housing for max misalignment ~ Laser cut sway bar bracket ~ Dimple die gusset panel ~ Copper and Gold plated finish MAX Subframe Collars ~CNC 6061 Aluminum ~Stiffens OEM bushing to eliminate wheel hop after clutch kick ~C shaped upper collars for easy installation ~Gold hard annodized finish *Can be installed independant of any other parts MAX Subframe Solid Riser ~Completely replaces OEM Subframe Bushing ~Raises Subframe a half inch for lowered suspension geometry correction ~Makes more clearance to raise exhaust ~Slip fit, epoxy-it-in installation (no press needed) ~CNC 6061 Aluminum ~Gold hard annodized finish *Made specifically for low ride height vehicles to help fix roll center problem. *Please see our products forum for OEM bushing removal instructions *You must bend the E-brake cable bracket to reroute cable so it does not rub the driveshaft. VIEW CART
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 09-09-2011 at 02:16 PM.. |
08-11-2011, 05:59 PM | #3 |
Seriously pbm! Seriously? Fuck you guys! Just when I think Imma have extra money to do cool Shit.
You go and make more dope ass Shit that I HAVE to buy......FML MY ORDER WILL BE IN SOON.
08-11-2011, 09:16 PM | #6 | ||
The tension rod that's sold by itself will have the 2 bolt holes for the OEM FLCA. The MAX PRO FLCA comes with a completely different tesnsion rod that's shown above. Thanks for your business guys!
08-11-2011, 11:29 PM | #8 |
Will we make an adjustable FLCA for the regular tension rod? No, I don't have any plans to do that. The OEM FLCA setup is flawed because it is not designed for changes in caster. When you do change caster, it is only possible because of the oversize imprecise holes in the OEM FLCA. When there is a collision the weakest link is the two bolt hole connection, so in our MAX PRO FLCA that weak link and lack of adjustability has been eliminated. If you do use the OEM FLCA with the new MAX PRO tension rod, we have redesigned that rod with a large cross section at the two bolt connection and we have changed the material from aluminum to steel.
08-12-2011, 03:17 AM | #11 |
Yes sir !!! FLCA are ordered my s14 will be good to go soon !
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
08-12-2011, 12:15 PM | #13 |
Based on previous history with PBM stuff, it's awesome.
08-12-2011, 05:10 PM | #15 |
we no longer have the toyota collars.
08-15-2011, 10:07 AM | #18 | |
Flca and rlca order made, waiting on any new info for the sak with these lower control arms. Payment ready to send so lmk.
08-15-2011, 04:15 PM | #20 | ||
you can order from the forum here on the blue links or from our site and you get the price as posted.
08-15-2011, 08:24 PM | #22 |
not sold out, there is a pretty low quantity though. try again if thats what the cart told you earlier.
08-23-2011, 04:07 AM | #25 |
Dan I'm a customer in San Diego and somehow when I choose ground shipping it says 21dlls but when I login to my paypal to actually pay it goes to 71 dlls Im ordering the s13 RUCA's, the s chassis subframe risers and the hood vent spacer kit thanks
08-24-2011, 08:00 PM | #27 |
if you are in san diego you need to come pay cash / pick up in person.
No, the toe rod wont be that soon.
