Old 10-05-2013, 06:04 PM   #1
Rayez
Rayez is an unknown quantity at this point
Sr20det a/c problems
Alright so I just recently installed and sr20det into my 1990 Nissan 240sx and I am currently trying to hook up my ac I got all the lines fabricated and everything is hooked up lines condenser dryer belt etc I went and evaped the system and charged it the issue I am having now is the compressor is not turning on??? I went and looked down and only found 1 electrical connector that goes straight to the compressor and theres another wire spliced off that wire that I have no idea where it connects to when I turn on the car and try to turn the ac switch on it does not light up and I also went and checked the fuses those where fine as well, and before anyone jumps the gun and tells me to do my research I have I just have not been ables to find a DETAILED guide with PICTURES so please if anyone have any ideas lmk my friend has the same set up in his 240 but he doesn't have either of those connectors connected and his works perfectly fine any ideas??? would be much appreciated
Rayez is offline   Reply With Quote
Old 10-05-2013, 06:48 PM   #2
Rayez
bumppppppppppppp
Old 10-06-2013, 11:32 AM   #3
Rayez
Bummmmmpppp
Old 10-07-2013, 09:04 PM   #4
Rayez
Someone please help....
Old 10-08-2013, 03:44 PM   #5
ultimateirving
ultimateirving's Avatar
Ok I'll help. That wire is the 12v switch it turns the compressor on by sending a signal. I believe the compressor grounds itself through the mounts. If anything in the system is off it won't trigger the compress. So if the pressure sensor, which is in the drier I believe, doesn't see the right pressure it won't switch the compressor on. Also the climate control box could be malfunctioning I had to replace my original when I got my ac hooked up
Z32 with lq4 swap
Old 10-18-2013, 12:14 PM   #6
rswails
rswails is an unknown quantity at this point
I found one within 15seconds of google searching, however I'm decent at searching.
S14 SR20DET into S13 240sx Swap
Read and understand that whole article to make sure you have your wiring setup properly so that the A/C wiring discussed in the article works. Also be sure to look at these links that are at the bottom of the article.
My Wiring info, Download here —>http://mestiso.net/photogaller…3.doc
Decoded JDM Zenki S14 Sr20DET pinout, Download here —>http://mestiso.net/photogaller…d.xls
USDM S13 DOHC pinot, Download here —>http://mestiso.net/photogaller…t.xls
rswails is offline   Reply With Quote
Old 10-18-2013, 03:44 PM   #7
inopsey
do you have 12v at the compressor ?
Old 10-23-2013, 05:24 PM   #8
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Does the AC light turn on in the dash? If not, you don't have refrigerant or your pressure switch is fouled up.
