Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 03-31-2018, 08:42 PM   #1
Thedriftbadger
Thedriftbadger is an unknown quantity at this point
Z33 no spark, no injector pulse
Can't get my 05 g35 rev-up to start. Here's the backstory of the car; I bought it for next to nothing after the previous owner tried to change the head gaskets, failed, and gave up. So i tore the motor back apart, replaced everything the po did, entire top end. Everything done according to the fsm. Went together fine, has compression, timing is right. Will crank all day long with not even a hint of trying to start, no spark, no injector pulse.
Now, the thing is I've never seen the car run, so i'm really starting from nothing here. I don't know if it died while driving, or if the head gaskets were even bad to begin with. No codes either, so that's helpful.
Possible causes: crank angle sensor, flywheel installed wrong, bad ecu, security problem. Anything else?
I've read a million threads about security problems with these cars. Seems like it's very common. Everyone says the security light will stay on if it's a problem. Mine never comes on at all, so i don't even know if the light works. The car also has an aftermarket replacement key. So that whole situation is a mess in itself.
My question is, is there anyway to know for fact whether it's a security issue? I'd really hate to tow this thing to the dealer for them to tell me it's fine.
Thanks in advance
Thedriftbadger is offline   Reply With Quote
