06-25-2015, 11:15 AM | #1 |
S13/s14 front arms
sup, im looking into upgrading to pbm's setup, the reg one not the on that they have just out (that one is crazy) but i want to have the option to upgrade to that one later one (witch is for s14's)
I own a s13, i know about the thicker spinder of s14 and the balljoint also, question is; What do i need or what to combine to get the s14 setup, does the LCA+Rod fit on s13's? I need the s14 knuckle fo s14 tierod's right. Simple Q, no douchebags Y not go for an s14? I love the s13 body its Like carmen vs pam. |
06-25-2015, 11:21 AM | #2 |
Just buy S13 control arms. S14 tie rods fit S13 knuckles just fine, and 5-lug conversion hubs for S13's are the same price as new S14 hubs. There is literally no reason to buy S14 front knuckles for your car unless you get the dirt cheap.
Whalen's Speed R&D - IG - @MachinegunSquad - www.whalentuned.com |
06-25-2015, 11:44 AM | #3 |
Ok i already have s13 5lugs, my concern whas that pbm didnt and wont make the new angle upgrade for s13's only s14's. Thats why i asked if the s14lca would fit.
06-25-2015, 10:42 PM | #4 |
This is similar to what I have planned for my S13. I'm going to do the PBM S14 pro front knuckle, and i'm planning to combine it with their s14 FLCA setup. I'm trying to find out how much wider if any it is compared to the S13 FLCA/tension rod combo. If they reply to my email i'll post what they say. I'm also planning to run s13 steering rack,pbm rack bushings, and pbm inner tie rods and s14 moog outers. just FYI.
06-26-2015, 10:18 PM | #5 |
Here's PBM's response;
On Fri, Jun 26, 2015, 14:36 MAX USA <[email protected]> wrote: There is no difference in the S13/S14 arms that we sell except for the taper on the ball joints. |
06-26-2015, 11:01 PM | #6 | |
So basicly just buy kunckle,arm,tierod all s14 and bolt on my s13 |
06-26-2015, 11:24 PM | #7 |
Ya the only other caveat is the shock/coilovers mounting bolts to the knuckle. S14 is larger so you have to custom order coilovers setup that way or get those adapters to use s13 bolts on s14 knuckles.
Sent from my SM-G900V using Tapatalk |
