10-28-2008, 06:38 PM | #1 |
clutch pedal sticking & disengaged engine
Last night, I drove 4 hours continuously without a hitch in my 1995 240sx. I then went to parallel park and my clutch pedal stuck to the floor. It did not stall my engine, so the clutch must have disengaged the engine from the transmission. I stuck my foot under the foot pedal and pulled it back up. I then was able to push the clutch back in and park my car. This morning, I started my engine up without a problem, and was able to put my car into gear. I then drove down the street and needed to stop, so I put my clutch in with the brake. At this point, the clutch engaged (engine disengaged from the transmission), but the clutch pedal did not come back up and the clutch pedal would not go back up when I pulled on it....
What do you guys think the problem is? I have looked around, and it seems to have symptoms of the master/slave cylinders failing, to the spring assist, to the throw out bearing. Thanks for the help in advance!! |
10-28-2008, 07:45 PM | #4 |
Probably clutch master
If it is, I'd change the slave same time assuming you've never replaced it since you owned it
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan Advertiser's Specials! Read / Give Feedback! Please Rate Us! |
10-28-2008, 07:59 PM | #5 |
Trader Rating: (25)
Feedback Score: 25 reviews
change your clutch master and slave .. because once the master cylinder goes out .. your slave is going right after it .. or vice versa .. change those two items and bleed your clutch system.
-Sellout |
10-28-2008, 08:11 PM | #6 |
Thank you all for your help. I checked the reservoir and it's empty, so there is definitely a leak in either the master or slave cylinder. I have never changed either one before. Between the master and the slave, there one that is more prominent in failing first?
It always seems that cars do that. When one part fails, it seems to stress the rest of the system, and other parts of that system seem to go bad... or is it just me that it happens to? |
10-29-2008, 12:24 AM | #7 |
that happened with my 240. i just filled the reservoir with brake fluid and it usually lasted me like 2 weeks before i would have to fill it again. but after awhile i would have to fill it twice a week so i got tired of doing that and i finally had my mechanic replace the clutch master and slave cylinders.
10-29-2008, 12:35 AM | #8 |
Check CLutch MAster Clylinder(CMC)
Check Slave Cylinder Look for fluid leakeage have someone pump the clutch while checking. Wrote alot but pressed back and lost it PM if you have any questions |
10-29-2008, 09:48 AM | #9 |
Frost415,
Thanks for the pics. The pics will make it much easier to find the Clutch Master and Slave cylinders. I poured some brake oil in the reservoir this morning and started pumping.... I got enough pressure built up to get the car started. I'm pretty sure there is air in the line, because when i press the clutch in, it feel like its a "wet noodle" now until the very end of the depression, where it finally engages the slip point. There isn't much of a tolerance for the slip point... Its almost at the bottom of the floor. |
10-29-2008, 10:45 AM | #12 |
One of your points in the system aka slave or master or both are going out. I personally would change both out, eliminate the dampener loop, get a speed bleeder for the slave and a stainless steel line, then bleed it, really easy with above parts and call it a day and enjoy your new pedal feel!!!!
10-29-2008, 10:49 AM | #13 |
What is a speed bleeder? Are the hydrualic lines running through the car stainless? I know they don't really rust, but I didn't think they were stainless.
I was thinking of getting some rubber tubing from Autozone to bleed the hydraulic line.... should I use something else? |
11-06-2008, 09:53 PM | #14 | |
Speed bleeder helps you bleed with just one person.
The stainless line he is talking about is braided stainless. You can use whatever tubing, but I like clear tubing because you can actually SEE the bubbles.
