Group Buys Dedicated Forum for Group Buys. |
11-21-2007, 10:46 AM | #61 |
As i mentionned in my message>NO T25/T28 OR GARRET SS LINES WILL FIT TO THIS TURBO,the central "body" ( ? ) is an IHI style,so it will not work with Garrett's SS lines,it's a specific sizing
i don't how to explain that banjos gots different size..... you know what i mean?? |
11-26-2007, 01:48 PM | #63 |
i emailed forced performance about the lines and this is what they said
"I am not sure what size the stock lines are, but here are what the 20g uses: Water Lines - 14mm x 1.5mm Banjo Bolt Oil Feed Line - 10mm x 1.25mm Banjo Bolt Oil Drain - Stock" can anybody verify t25/28 ss lines fitting on here? |
12-04-2007, 11:32 PM | #65 | |
12-05-2007, 08:25 PM | #66 | |
Sieze the day or Die regreting the time you lost |
12-07-2007, 03:25 PM | #68 | |
Did you get the groupbuy price?
12-07-2007, 09:20 PM | #69 |
yeah..just mention that u saw it on ZILVIA.NET........
12-10-2007, 03:03 AM | #72 |
great turbo why?
1. last longer then ball bearing turbo 2. can hit higher boost then ball bearing turbo 3. bang for the buck hp now you just need to make a cast iron manifold for KA to use this turbo and you have a great kit. cheers, sam
Nissan Japan: "road to happiness has many curves" Jdmlivin: "Jdm is dead, the yen is crazy" |
12-11-2007, 08:52 PM | #73 |
it is oil cooled.....journal bearings....last longer like jspec sed and its has a great potential to unlock the torque and hp on the ka!....cheers mate!...
12-14-2007, 11:21 AM | #74 | |
12-17-2007, 12:50 PM | #76 |
we ran this turbo for the skyline r32 with an sr20det last D1GP in Irwindale event, last month.
Car ran really fast. clocked fastest entry on Sunday's World All Star match, unfortunately, an axle snapped during tandem with JR. Gittin during the tandem battle and it ended up in the wall. not too bad of a fix. will be back with wide body. i found some pics of the car with the 20G Turbo and "Sam Tiger". Daijiro Inada loves the power and Sam's crazy entries see you guys out there. |
12-19-2007, 01:40 PM | #77 |
There have been several questions regarding the group buy. This group is still active. You will need to contact myself or our other sales guy Aniel to place your order. Please mention you saw the group buy on this website and you will get the group buy price. To reach us, you can call these numbers:
Amber - 972-984-1800 ext. 100 Aniel - 972-984-1800 ext. 117 There is a bit of misinformation in this thread as the turbo that boyou2 and Papo240 have posted up are not our turbo. Our turbos do not have that blue tag on the front of the compressor housing. Also, our turbos do not use an IHI bearing housing. Our turbos are a Mitsubishi based turbocharger. As someone has already posted, you will need to purchase a stainless steel oil feed line as a stock SR20 oil feed line will not work. We sell the oil feed line for this turbo: Nissan 20g Oil Feed Line You reuse your 12mm banjo bolt where it fits to the block and you get a new 10mm x 1.25mm to fit our FP Nissan 20g turbocharger. The water lines and oil drain line should all bolt up the same as factory. If there are any other questions, please feel free to contact Aniel or myself. Thank you, Amber |
12-19-2007, 08:24 PM | #78 |
thanks amber for the info and clearing this up for us....i should get my oil line after the holidays....since im broke now!!!!!...hahaha
12-20-2007, 07:58 AM | #79 |
I was one of the first to purchase this turbo from this GB, and the had to install the turbo without any further assistance since you guys at FP left me hanging even after i sent you pics you requested. The water lines are the same fitting size, but only one oem hardline can be reused (the one that goes to the back of the block) but get all ss lines if possible. However, to reuse the oem line first you have to clock the turbo slightly by first drilling a new copressor housing pin hole and clocking so the center cartridge is perfectly vertical as it should be from the manufacturer. The oil feed is 10x1.25 to w/e AN adapt. your using. The t25 oil drain flange can be used but you have to modify the bolt holes and get smaller bolts, plus the tube hits the steering rack so you cut it and make a custom hose. The turbo pulls decent above 16psi, but my freinds car with the 2871r .86 and same tune pulls me by a little: both cars at 18psi and my car is lighter. Peace.
12-20-2007, 03:37 PM | #80 |
^^^ Normally I'd leave this alone, and I'm sorry that you feel you got "burned" by FP because they didn't hold your hand through what you imagined to be a bolt-on install, but the reasons you gave for this turbo not being perfect are pretty lame.
The info you posted is helpful to anyone, like yourself, that didn't research the swap first. But I have to ask, why would you try to re-use the shitty hardlines anyway? Lastly, the TD06-20G has WAY more headroom than the .86 2871R - if you and your buddy both have stock intake manifolds and cams, that might be what's limiting you both, but your turbo can do about another 80hp on top of that 2871.
12-20-2007, 03:50 PM | #81 |
ok im all sell with this turbo . im calling tomorrow to order it but first i want to make sure i have everything everything i need for my install so we dont get into troubles the day of installation . im ordering the TAKA lines for the SR and the oil feed line from FP , what else do i need to order
12-20-2007, 04:05 PM | #82 |
That should do it. You might have to play around with your intake/intercooler piping, because the FP turbo places them a little differently than a t25 or t28. Let us know how it goes, and post pics of the install!
12-20-2007, 04:29 PM | #83 | |
hoping to be on 380whp with more room on turbo for future engine upgrade |
12-24-2007, 05:10 AM | #87 |
12-27-2007, 11:30 AM | #88 | |
12-27-2007, 12:53 PM | #89 |
Hahaha, sadly, not gettin any play from anyone at FP. I don't even own one. But I was thinking this would be a great alternative to a top mount T3 50trim, because it has the same headroom and a much simpler (bottom mount) setup. My hat's off to you AntiVtec for completing the swap and coming back to comment
