06-30-2012, 07:00 PM | #1 |
Hud Harness More troubles
I buy a HUD, the seller says "Plug and play" and dont give to me the harness...
i buy the harness, today i remove the complete dash, and see this the original Harness dont have any plug!! I dont know how connect now S: PD the original cluster Harness is the one over the steering wheel Please |
06-30-2012, 07:08 PM | #2 |
Why did you remove the whole dash? You disconnect the analog harness from the cluster. Then follow the harness to where there is another plug. Then disconnect the analog harness all together and remove. Now connect the digital harness with the correct side of the plugs to where you disconnected the other harness.
06-30-2012, 07:13 PM | #3 |
06-30-2012, 07:33 PM | #7 |
07-01-2012, 10:13 AM | #11 |
Easy fix. Go to a parts yard. Find a 240 cut the two plugs off the harness (on the dash side). Match up the colors between your cut harness and the new pig tails conect, solder, heat shrink. Then it is again plug and play
07-01-2012, 11:30 AM | #12 | |
The pinout, is by wire color? becouse i can re-pin in this case |
07-02-2012, 07:03 PM | #14 |
07-21-2012, 08:48 PM | #15 |
Well, i finally get the pinout!!
http://gary.purplepixie.org/sxoc/Digidash.pdf Ill do everithing like that says, its easy becouse is always color match wires!! But the troubles comes again, all aux light ( handbrake, oil, battery, door, etc) works fine, but i dont have backlight and dont work any Digi Speedo ( dash and windshield) do you know what possible is? i Check all "lines" with a voltimeter and work fine :S he's drive me crazy look the mess!! jaja |
07-22-2012, 08:03 PM | #16 |
After a few hours to re check... ill found something..
The red are (+) Illumination The Black Are Ground to Ilumination Blue one is the Ground to illumination and HUD, and connect to... NO WHERE!!!!! i cant believe if really work thay way jajaja i try tomorrow rewelding :S |
07-30-2012, 04:24 PM | #17 |
Ok i re-weld the ground to another spot..
and this result the speedo isnt work I weld the new Capacitor ( 50v 1 Uf) and he work for a 30 second, and low bright, and then die |
07-30-2012, 06:16 PM | #20 |
does the tach and fuel and temp read fine? it may just be the digi brain part of it. ive had over 15 set ups in the past and not all have worked. i go to the j-yard frequently so when i see them i grab the main parts. i may have some parts for it still. dont know if any of it works though because i dont have my s13 anymore. i am into corollas now and actually have a oem digital cluster it that one.
here is a post of info i gathered back then that might be of some use to you. http://zilvia.net/f/tech-talk/160159...-your-hud.html
for sale: http://www.zilvia.net/f/showthread.php?t=193169 -1990 s13 hb w/all jdm 180sx goodies... gone to fresno -1985 ae86 gts turbo... going threw a heart transplant -1963 euro ragtop bug... asleep in the garage Luv 2 Build, Luv 2 Show, Luv 2 Cruise!.... |
07-30-2012, 10:50 PM | #21 |
You know man, a new dash harness would make your life so much easier... how much are you willing to pay for one? Im sure i have a harness for that digital cluster also if yours isnt correct.
07-31-2012, 05:52 PM | #22 |
I buy a new harness, but my car dosnt plug, becouse that i have to cut and re join all wires between new digital harness and the original of the car.
07-31-2012, 05:55 PM | #23 | |
Yeap, i put a new capacitor,and works for 30 segs, and died again The diodes are all ok. thnks mate,do you think any part more to check? The tach, fuel and Temp work fine! |
