08-21-2015, 05:06 AM | #1 |
FS: 2003 Chevy S10 – Manual V6 4x4 Extended Cab – 1 Owner!
I’ve owned this truck since it had 6 miles on the odometer. The truck has been meticulously maintained. I’m moving to DC and simply don’t have the time and place to keep this truck.
Truck: Extended cab Indigo Blue Metallic Graphite Gray interior Vortec 4.3L V6 5 Speed Manual 4x4 Locking rear differential Manual windows and door locks Factory privacy glass Factory GM bedliner Ice cold AC 164,xxx miles Plenty of life left in the tires Maintenance schedule: Timely oil changes with AC Delco PF52 oil filter and Mobil oil Tires rotated every 6,000 miles Regular cleaning of K&N air filter in stock factory air box. Spare under truck bed was never used but it was lowered once and year and kept properly inflated. Jack, wrench and wheel chocks in factory location and in good shape 55k miles: 4 new all season tires 70k-90k miles: Plugs and wires replaced. Rear differential fluid changed using OEM fluid 100k miles: Ac compressor replaced – system was properly vacuumed during install. Brake pads – OEM Rotors – Advance Auto. Rear most U-joint replaced on driveshaft Front passenger side upper ball joint replaced. Replaced manual transmission fluid – OEM GM fluid 105k-120k miles: New OEM clutch installed New rear main seal Resurfaced factory flywheel. Flushed coolant Flushed brake fluid Flushed power steering fluid Changed transfer case fluid - OEM GM fluid Changed front differential fluid – OEM GM fluid New AC Delco fuel pump 4 new replacement shocks New OEM rear brake pads New rotors Adjusted parking brakes 4 new all season tires 140k – 150k Miles: New radiator New AC Delco water pump New AC Delco thermostat New Water pump mounting hardware New coolant hoses New coolant New AC Delco radiator cap New AC Delco fan blade clutch assembly New AC Delco spark plug wires New AC Delco distributor cap New AC Delco ignition rotor Replaced the door hinge pins for both doors 4 new all season tires (around 150k miles on the odometer when this was done) New tailgate cables New third-door door handle installed. New remanufactured alternator New serpentine belt New battery New OEM center dash vent replacement New OEM speaker grills New OEM center dash trim (the trim around gauge cluster and stereo) 160k miles: Replaced all 3 O2 sensors with new AC Delco O2 sensors Replaced both U joints on the drive shaft with AC Delco Professional U-joints that can be re-greased New factory hardware for connecting driveshaft to the rear differential. New AC Delco ignition coil New AC Delco wire from ignition coil to distributor New hub/bearing installed on front driver side. Moog brand Recharged the AC system. New lines from factory remote oil filter to oil cooler Extras: Full custom stereo Kenwood headunit with iphone support and 6 channel 4V pre outs Rockford Fosgate 12” dual voice coil sub in custom fiberglass box in place of bench seat Alpine 4x6 component dash speakers Pioneer component door speakers Dynamat behind speakers in the door Dynamat behind 12” sub box and rear firewall of the cabin 4 channel amp powering 4 speakers (4x50) 2 channel amp powering 12” sub (300x1) Custom mounted amps on rear firewall 4 AWG power and ground cables to distributor blocks 8 AWG power and ground cables from distributor blocks to amps Factory jump seat included with sale and can be reinstalled if you decide to remove the stereo. All the mounting points are still accessible. Known issues: Driver side seat has a very minor tear on it. Driver side seat’s back adjustment plastic lever is broken. (Replacements are $20 online) There was a very minor fender bender a few years back where the rear bumper was hit. It is visible in the pictures on the driver side Conclusion and pricing: The graphite grey is a sought after interior color and there aren’t many manual trucks to be had. I’ve tried to detail how meticulously I’ve maintained the truck over the years. I’m not afraid to drive this truck cross country today if needed. Asking price is $6,800 OBO The truck is located in Charlottesville Virginia. I split my time between Charlottesville and DC. I will do my best to meet as quickly as possible with anyone interested in test driving it. Pictures: All pictures can be found here: http://www.bumnah.com/4sale/s10/ Exterior Wheels – No curb rash at all Rear bumper – Notice the rear bumper Front grill Interior – 3rd door open Seats Dash Extended cab Thanks for looking!
bumnah.com/trakpak |
