Old 12-09-2011, 02:53 AM   #2131
spray2020
spray2020's Avatar
spray2020 is an unknown quantity at this point
Originally Posted by SicBastard View Post
Straight up.... 16s are dead. That being said:
You can run toyo RA1s in a 255/50 that is approved from 7-9"
PROXES RA1 | Toyo Tires
And I think kumho is making a 265. But they will cost you a pretty penny. If you puss out and run a 245 please don't bother posting back up in the Max tire thread.
Really 255's on a 7" wide wheel? Do you have an example of this?
Im open to anything possible, as long as it is functional and safe.
spray2020 is offline   Reply With Quote
Old 12-09-2011, 10:34 AM   #2132
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
Yeah I have an example, it's called the engineering specs and reccomended wheel widths reported by toyo in the link I already provided.
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 12-09-2011, 10:48 AM   #2133
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
For conversation sake.
Epsilon mesh wheel. 15x7 0 offset.
225/50/15 BFG G-Force T/a Drag Radial.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 12-09-2011, 12:55 PM   #2134
SicBastard
SicBastard's Avatar
Here's the 225 Hoosiers RS305s that I used to run on my 14x7 team dynamics. If you actually measure the width of the slicks they were much closer to a street tire that's 235 or even 245. Going to a taller wheel will make this even easier. Just follow the tire manufacturers reccomended wheel widths and you can't go wrong. The 255 RA1s are also 50 series, so that extra sidewall allows you to go a little more extreme with narrow wheel pairings.
Old 12-09-2011, 01:13 PM   #2135
donabeast
donabeast's Avatar
donabeast is an unknown quantity at this point
Ive got 18X9.5 +15 with 265/35/18s front and back and its a little lower than this
donabeast is offline   Reply With Quote
Old 12-09-2011, 01:45 PM   #2136
Yellow4g63
Do rub in the front when u lock the wheel?
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 12-09-2011, 01:51 PM   #2137
donabeast
donabeast's Avatar
no sir but that is due to my handy dandy tubs
Old 12-09-2011, 06:25 PM   #2138
ka-titties
ka-titties is an unknown quantity at this point
what kind of power do you make? do you hook on the street in first?
ka-titties is offline   Reply With Quote
Old 12-09-2011, 07:06 PM   #2139
Yellow4g63
Nice didn't notice that.
91 Nx2000 VVL yo
Old 12-09-2011, 11:01 PM   #2140
Flicktitty
Flicktitty's Avatar
410whp 385Tq
2JZGTE 6265
15psi pump gas
automatic
untuned. no traction issues unless the weather is sub 35-40 degrees. haven't launched the car, we will see how the newer 3500 stall and AEM EMS and what not does to the car next season.
Old 12-10-2011, 03:25 AM   #2141
spray2020
spray2020's Avatar
is it considered a "no no" to run very wide tires if your vehicle doesn't have enough power to turn them over?
What are the negative effects of running to big/wide of a tire if the power isn't there?
Damage to the gearbox?
Old 12-10-2011, 08:53 AM   #2142
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
I have a 275 on a stock auto ka. It doesn't Matter if you drive normal. Granted I have a mid frame 1jz vvti going in w/ r154.
SW Fab
shiftdrift is offline   Reply With Quote
Old 12-10-2011, 11:15 AM   #2143
SicBastard
SicBastard's Avatar
Big wheels can get heavy! The relativly light 17x10.5 Halibrands I have weigh ~22 lbs. And the 275/17 falken tire I have on 'em weigh 28 pounds. That's 50 f*@%'n pounds per corner!
Compare that to the 225/15s I ran on the street in my miata. Not only are they almost 3" shorter (free lower CG without messing up your roll center) the 15x9 wheels weighed 12.8 lbs, and the tires only 22 for a total per corner of <35 lbs. Considering you have to run four of them you save 60 pounds [4x(50-35)=60] with the smaller wheel/tires per car. Oh and the 225 rubber cost almost half of what the 275s do!
Even if you just took a 60 pound brick out the back yo trunk, your 1/4 mile time should drop 0.06 seconds. But taking that same weight off of something that's recipricating (flywhee/crank/driveshaft/wheel/tire/etc.) and supposedly you can get 10 times the benefit! That's 0.6 seconds in the quarter mile. Huge! Even if you'r not a drag racer, everyone is into improved acceleration.
Lighter wheel/tires also can be accelerated up/down faster, letting dampers work more efficiently, thereby improving handling and traction.
So now that I'm done bashing big/heavy wheel/tires...
Talk to almost any experienced autocrosser or road race guy and a wider tire at one end of the car equals more grip at that end of the car, and that means lower lap times. Even the NA powered CSP autocross miatas are running 275s or wider now.
A good friend of mine had a Kouki with a bolt-on KA and two sets of wheels. A set of stock Mazda FD 16x8s (which are freakishly light) with sticky tires, and a baller set of hardparkin 18x10s. The car feels so much more sluggish with the good lookin wheels it's not even funny. Not only are the 16s lighter than the 18s, they are also shorter, which means you're getting a (free) gearing advantage. Putting on the 16s is like swapping in 4.33s for free!
So you have to balance the power you're making, the handling benefit you're actually going to utilize (even a set of sticky 225s will raise the handling limit of most cars beyond what can/should be exploited on the street), and the trade off in straight line acceleration for handling and braking with wider tires.
Unless it's a dedicated off-road race car, wider isn't always better. And if the car is underpowered that becomes even more true.
Old 12-10-2011, 11:31 AM   #2144
SicBastard
SicBastard's Avatar
Check the tire manufacturers data sheets
People are always asking, "will XYZ tire fit on a --- wide wheel?" to which I usually post a link to the tire manufacturers web sites which generally have reccomended wheel width ranges posted for every performance tire they make.
But there's is a second good reason to check out those data sheets. Some manufacturers list the tires weights. And often the same size tire will vary by 2 pounds or more between manufacturers. Would you buy a 19 pound wheel over a similar 21 pound wheel? Of course you would!
Sometimes saving 2 pounds on a wheel will cost you $300/corner. It's free if you choose your tires carefully!
Old 12-10-2011, 03:00 PM   #2145
spray2020
spray2020's Avatar
yeah I noticed on the data sheet for the toyo RA1's how the 225/50/r16's weigh 23 lbs, and the 255/50/r16's weigh 27 lbs.
I'm already thinking of using a heavy wheel (those 2 piece super advans I posted im guessing aren't very light) and I am wondering going from a 23lb tire to a 27 lb tire will be much of a difference? That is if I go with a toyo ra1. My silvia has the stock 1.8L ca18det in it, and is only being used as a street car at the moment.
Flicktitty's s13 that he posted, gives me some good thought as to ride height and tire size- but I am curious if that car has any issues with rubbing on the inner wheel wells? Which makes me wonder if running a similar size (225/50) or larger on a 16" will have rubbing issues. Then again comparing a stock ca18det to his motor/power setup is a big difference lol.
Old 12-10-2011, 06:24 PM   #2146
Flicktitty
Flicktitty's Avatar
no inner tire rubbing on Megan coilovers. The car has 100% stock rear fenders, NO ROLL NO PULL on them. i'll take a few pics tomorrow of the coil/wheel spacing. and some more of the fitment.
Old 12-11-2011, 08:45 PM   #2147
Flicktitty
Flicktitty's Avatar
here are the pics i promised.... the lighting wasn't on my side.
Old 12-11-2011, 10:32 PM   #2148
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Looks like you have a very slight rubbing issue with the outer part of the tire. Its crazy the rear end doesn't squat more.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 12-12-2011, 08:46 AM   #2149
Flicktitty
Flicktitty's Avatar
it does rub VERY slightly, and i honestly think it rubs going through the corners and no so much on the straight pulls. Also i usually have a bunch of tools and extra stuff in the trunk so there is more weight over the rear. Car is aligned to stock specs. and the coils are set to full soft.
Old 12-14-2011, 05:09 PM   #2150
|BOOST|
|BOOST| is an unknown quantity at this point
nevermind...
|BOOST| is offline   Reply With Quote
Old 12-21-2011, 08:55 PM   #2151
Flicktitty
Flicktitty's Avatar
Looking and changing wheels, found some 17x10 + 22. Without a pull there is no real way to run a 275/40/17 is there? (with close to stock camber)
Old 12-21-2011, 11:12 PM   #2152
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Not even close... unless you are in 4x4 mode. I ran the same exact specs as you desire... no pull, stock camber, 275/35-18... but on a 18x10 +44. And it still rubbed if I lowered it too much. You would be poking out almost an inch more over what I had. This is as low as I could go with the above setup:
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 12-21-2011, 11:30 PM   #2153
Dub's
Dub's's Avatar
Dub's is an unknown quantity at this point
What those are +44 offset? OMG Then I can fit a 18x10 +35 with a 305 tire then?
98 Kouki / ID2000's / 6266 / Full Z32&Q45 drivetrain
Dub's is offline   Reply With Quote
Old 12-22-2011, 02:50 AM   #2154
Broadfield
Broadfield's Avatar
Uhhh, no, not even close on stock sheet metal. Unless of course you are mega 4x4.
My Portfolio
Please Share
Check Out My Builds
Old 12-22-2011, 10:57 AM   #2155
Flicktitty
Flicktitty's Avatar
yeah, i figured i'd need something in the low - mid 40's oh well I'll keep looking.
Old 12-29-2011, 01:02 PM   #2156
shaddix
shaddix is an unknown quantity at this point
Greetings. I have a 95 240sx.
I want to get 17x9 RPF1s, and put 235/40/17s on them. I have searched everywhere and I cannot find any good information on what offset I need to select. The options are +22 and +35, and +45 for 17" RPF1. I'm going to run koni 8611 fronts and 8610s in the rear with richard's housings. 7" springs track height
Does anyone know which offset wheel I need to get? I have read that 155mm is the maximum backspacing on the s14 front, so with the 35 offset I would be 1mm too far. But maybe that is just some BS? I don't know....
thanks for any help.
edit: hm maybe I was looking at the offset calculator wrong earlier, it's showing the 35 gives me 163mm backspace which would be way too much? And the +22 gives me 150mm backspace....... So the +22 would be best?
shaddix is offline   Reply With Quote
Old 12-29-2011, 04:51 PM   #2157
S14DB
AFC #1
S14DB's Avatar
Yes, 22 would be the best of those options.
Old 12-29-2011, 08:44 PM   #2158
shaddix
Ok! Thanks man, I will get me some of those asap then
Actually I think I might go for some Weds tc105n.... I think they look so much nicer, but nearly 2x the cost ; ;
Old 01-02-2012, 12:31 PM   #2159
mikerbike
mikerbike is an unknown quantity at this point
255/40/17x9.5 +12 ~-1* camber, super jacked quarters pulled ~1".
mikerbike is offline   Reply With Quote
Old 01-02-2012, 12:38 PM   #2160
Broadfield
Broadfield's Avatar
That would be more like "average" tire fitment, not maximum tire fitment.
My Portfolio
Please Share
Check Out My Builds
