Old 04-15-2009, 01:18 AM   #1
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
Front Oil Cover Leak? Easy Fix? *PICTURES*
I have the SR motor pulled out and noticed some nasty grease around the front of the engline block. I checked around and like to know if you guys can confirm with me that these seem like the front oil cover has been leaking on this motor for a period of time.
The grease seems thick and appears to have been there for a quite long period of time. The wet spots are just some Mean Green that I sprayed on it planning to clean the greases off.
At first, I thought the head gasket was leaking, but after close examination, the grease seems appear around the front oil cover. It seems that it needs new RTV. Is it easy to remove it? Do I have to take off the head to have it removed?
Thanks. Much appreciated!
dongoesby is offline   Reply With Quote
Old 04-15-2009, 01:47 AM   #2
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
if you read the FSM you will clearly see that it is no easy task. you have to damn near disassemble the whole engine to take the front cover and pump off.
Old 04-15-2009, 02:01 AM   #3
dongoesby
dongoesby's Avatar
i've seen people done it without head off. pretty much crank pulley off, lower oil pan off and higher oil pan off.
I want to confirm if this seems leaking. thanks!
Old 04-15-2009, 02:06 AM   #4
aNskY
aNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfectionaNskY is close to perfection
Send a message via AIM to aNskY
head doesnt have to come off, but upper pan does. it's pretty easy when the motor is on a stand...
aNskY is offline   Reply With Quote
Old 04-15-2009, 02:59 AM   #5
Mister.E
Mister.E's Avatar
Trader Rating: (53)
my motor is doing the same thing and i have yet to figure out where its coming from.
Old 04-15-2009, 03:38 AM   #6
dongoesby
dongoesby's Avatar
how is your compression? mine is 145-140-145-150
Old 04-15-2009, 09:36 AM   #7
aNskY
Thats not terrible..
Old 04-15-2009, 09:47 AM   #8
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
mine is leaking at the same spot too but i dont lose any oil? or enough to make a difference on the dip stick
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 04-15-2009, 11:04 AM   #9
driver11324
driver11324's Avatar
driver11324 is an unknown quantity at this point
I had the same problem, I took the cover off and resealed it along with a new front seal, o-ring on the CAS and gasket on the chain tension thing. Hopefully it doesn't leak, I will be pissed.
driver11324 is offline   Reply With Quote
Old 04-15-2009, 11:40 AM   #10
dongoesby
dongoesby's Avatar
This cover uses RTV to seal only right? Please keep us updated!
Old 04-15-2009, 12:20 PM   #11
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
you can pull the case by dropping both oil pans and the crank pulley, honestly if you arent losing oil, clean it and check it later, its not worth the hassle to pull it if you arent losing oil through it
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 04-15-2009, 02:16 PM   #12
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
yeah, you basically have to take the whole head off to seal that sucker up properly
good chance to do head gasket and studs
Chrischeezer is offline   Reply With Quote
Old 04-15-2009, 02:34 PM   #13
smelly240
smelly240's Avatar
except the head doesnt have to come off... I've done a bunch of em without pulling the head. Kids dont have the $ to do headgasket and studs all the time - pull th elower pan - and u can do it - but try to prime the oil pump a little before u put it back on.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 04-15-2009, 03:06 PM   #14
Mister.E
Mister.E's Avatar
Trader Rating: (53)
my compression is like yours, its not totally bad. i cleaned the motor as best i could the other day and im just gonna wait and see what happens.
Old 04-15-2009, 03:31 PM   #15
dongoesby
dongoesby's Avatar
my engine is out on a stand. If I don't do it now, I couldn't figure out when would be a good time to hassle with it.
The problem right now is that I don't know it is leaking or not.
I researched about how hard it is to take out the head, and I don't really mind doing that. However, sending out the head to shop for deck and machine is another category. $$$...
Old 04-15-2009, 03:36 PM   #16
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
It's only like $50 dude...
JVD is offline   Reply With Quote
Old 04-15-2009, 03:44 PM   #17
dongoesby
dongoesby's Avatar
taking out the head while no money to update cams and other internal parts? what is the point with all the hard work and risk of breaking the vulnerable parts and readjusting timing chain, cas, etc?
plus, a good headgasket costs 200 + head studs... are all money. It would be nice to do them all at once IMO.
Old 04-15-2009, 03:53 PM   #18
JVD
Just drop the upper and lower oil pans then. Much easier, especially since your motor is already out.
Old 04-15-2009, 04:04 PM   #19
slider2828
slider2828's Avatar
I dunno it could be also the power steering pump as well.... But the front cover has the oil pump in it, so you might as well replace the oil pump while your at it. Its about $250 for the oil pump with front cover, you might as well do it.
Turn and Burn!
Old 04-15-2009, 04:31 PM   #20
dongoesby
dongoesby's Avatar
This one? If it is leaking, isn't it better to change the hose? It shouldn't be changed unless it stops from working I assume.
Old 04-15-2009, 05:44 PM   #21
Mister.E
Mister.E's Avatar
Trader Rating: (53)
i think my PS pump may be leaking too. is it possible to crack it in half and replace that gasket that you can see in the picture? if mine is leaking then thats gonna be the only place that its leaking. the hoses look fine and i replaced all the shitty factory clamps with better hose clamps.
Old 04-15-2009, 06:59 PM   #22
Def
The o-ring on the PS supply tends to compress over time and weep a bit. Mine was staying wet, all it took was replacing the o-ring and it stopped.
It doesn't really look like it's coming from the cover from those pics, but it's hard to tell with that much grime.
Old 04-16-2009, 02:01 PM   #23
Chrischeezer
i got a use HKS headgasket for sale if you wana do it, 50 bucks...
Old 04-17-2009, 10:40 AM   #24
240sxaddict
240sxaddict is making a name for him/her self240sxaddict is making a name for him/her self
Why has no one suggested the front main seal being the problem?
240sxaddict is offline   Reply With Quote
Old 04-17-2009, 02:29 PM   #25
aNskY
because the FMS is about 18" below where the leak appears to originate? i guess it's possible that the crank pulley is spraying it up there though...
Old 04-17-2009, 02:47 PM   #26
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
+1 for that.
That's EXACTLY what a bad front seal leak main looks like...the pulley throws a mist of oil all around, and grime sticks to it. A leaky timing cover will be wet and obviously oily...not caked up dirt like that.
You don't need a headgasket, you don't need a timing cover replacement, you don;t need any RTV to fix this...it's a $7 'donut' seal.
Remove the crank pulley, pry out the old seal...then tap the new one in. Done.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 04-17-2009, 03:25 PM   #27
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
There is no way that shit is from the PS pump/lines, it uses ATF and that's red, this gunk is black.
I would say since the motor is already out, take the 14 bolts or whatever it takes, take the pans out, pop ur valve cover off, and pop the front cover off, RTV it, and put it back together, it cost no money to do that, unless you don't already have RTV.
Only thing is, is time consuming, really not that hard man.
nrmskate is offline   Reply With Quote
Old 04-17-2009, 08:56 PM   #28
dongoesby
dongoesby's Avatar
Originally Posted by orion::S14 View Post
+1 for that.
- Brian
thanks! did you ever have the similar bad front main seal leak that happens to be just like this before?
This is what i'm thinking, better be safe than sorry later. I'd like to do all the seal all over again. Can you explain more about the red ATF that the PS pump is using?
Old 04-17-2009, 09:11 PM   #29
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
+1 for the front main seal i would preplace it clean up the motor, some lof like regular road grime and oil from the front main seal. what happens it flings off the pulley when the motor is running
georgesal is offline   Reply With Quote
Old 05-05-2009, 02:40 PM   #30
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
You have to remove the cam on Driverside as well, to access the 1 bolt through the top correct??
I started to remove my cover when I had it on a stand but saw all that was needed to get it off and decided I'll worry about the STUFF I know about 1st.
My Shit Is leaking the slightest bit now that I've finally installed it back in the car.
P/S pump is pouring and Freaking Oil Turbo line (on the block) is leaking also. DAMNIT!!Found a Toyota Double Banjo P/s hose washer that looks to be perfect for the turbo line.
I re-sealed the upper and lower pans after cleaning them and they seem wet after the motor ran for a few mins.I'm only using Regular Castrol oil too.I can only imagine w/ FUllSynth.
z-tERty-2
MrFairlady is offline   Reply With Quote
