Old 06-13-2012, 04:50 PM   #1201
silviamex92
silviamex92 is an unknown quantity at this point
Originally Posted by JasianBlazin View Post
yeshh. switch it up though 18x8.5 in the fronts, 18x9.5 in the rears. Your car shouldn't be that low on that setup so i don't think you'll need to roll the fenders.
thanks
in your opinion is a good offset?
silviamex92 is offline   Reply With Quote
Old 06-13-2012, 05:03 PM   #1202
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
Originally Posted by silviamex92 View Post
thanks
s13?
the rears should be fine, the fronts are a little weak though.
JasianBlazin is offline   Reply With Quote
Old 06-13-2012, 05:05 PM   #1203
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
thanks
High teens low twenties
Te37 is offline   Reply With Quote
Old 06-13-2012, 05:19 PM   #1204
silviamex92
[QUOTE=JasianBlazin;4745887]s13?
the rears should be fine, the fronts are a little weak though.[/QUOTthanks for
the comment I will consider all
Old 06-13-2012, 06:26 PM   #1205
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by Johannes View Post
Heya. I would like to know if Varrstoen 2.2.0 in 17x9.0 +12 will clear both front and rear Z32 brakes without spacers?
Offset has nothing to do with brake clearance. But looking at they are and face design (how concave the face is) I dont see why they wont clear Z32/R32 brakes.
CLICK HERE!!!
Old 06-14-2012, 12:43 AM   #1206
korrespondent
korrespondent's Avatar
korrespondent is an unknown quantity at this point
sorry, if that's a wrong thread, but i need answer to that question:
I've got 3 piece 17/18 SSR Gartmaiers, and i want to put in a new wider 30 hole outer lips.
Can i take em from Vienna's, Koenig's or other 30 hole SSR's??.. They are also 30 hole flat lips. But i don't know if they are the same size (diameter).
www.s13club.ru
www.nismo.by
korrespondent is offline   Reply With Quote
Old 06-14-2012, 07:47 PM   #1207
fliprayzin240sx
I'd ask that here...
http://zilvia.net/f/chat/327620-wide...ls-thread.html
CLICK HERE!!!
Old 06-14-2012, 08:33 PM   #1208
KA-Life86
KA-Life86 is an unknown quantity at this point
18x10 +22 w 265/35/18 Bridgestone potenza re760s out back on an s14. Could I get away with running less than 3 degrees of rear camber, roll/and pull required obviously. I know this isn't extreme fitment, I just really don't wanna kill these tires in 5k miles with ridiculous camber. I will probably step down to a narrower tire after these wear out...unless someone wants to buy them from me?
KA-Life86 is offline   Reply With Quote
Old 06-14-2012, 09:56 PM   #1209
fckillerbee
fckillerbee's Avatar
I personally would search around in the max tire thread. check dudes offsets, and tire sizes...they run some pretty big stuff out back.
Old 06-15-2012, 01:55 AM   #1210
korrespondent
fliprayzin240sx, thanx, man!
www.s13club.ru
www.nismo.by
Old 06-16-2012, 02:13 AM   #1211
One_love_silvia
One_love_silvia's Avatar
Trader Rating: (38)
Feedback Score: 38 reviews
ordered myself some work cr kai's in 18x9.5 +12 all around. planning to wrap them in federal 595s probably 235/40/18.
currently, im running -2 camber up front and -.5 in the rear.
anyone know how well that is gunna fit? i know i'm probably going to need a pull (a roll for sure), i just don't know how much of a pull. also, i'm not very low atm. i'm at "legal" height. so basically just low enough to get rid of nasty fender gap. if i get a new job this summer, i'll probably lower her back down a bit for fun.
2016 Nissan 370z
Old 06-16-2012, 10:41 AM   #1212
TunanS14
TunanS14's Avatar
TunanS14 is an unknown quantity at this point
Im looking to run 18x11 +6 fronts on a Kouki s14. Would it rub/ hit anything on the inside of the wheel well? I know I'd need to get extended brackets for my Megan tracks but other than that I think with a pull it should fit nicely with some camber. What do you guys think?
TunanS14 is offline   Reply With Quote
Old 06-16-2012, 10:51 AM   #1213
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
You should be fine, Karlitos car is not that low and he used to run 245/45 on his s14 with aero iirc.
You're going to rub and will need to hammer a lot when you're at full-lock. I would consider up front no more than 10" and I am sure, more owners will chime in that have ran sizes like that up front. I am going by personal experience with 9.5/10.
instagram
1on1 is offline   Reply With Quote
Old 06-16-2012, 11:18 PM   #1214
fliprayzin240sx
^^^Yup, largest I'd run is 10j. Anything larger than that, itll be a pain in the ass to fit and run low at the same time. Wider the rims, harder it is to run smaller tires. Wider/bigger tires will make your clearance worst than it already is.
You can run 11s, as low as you dont turn...
CLICK HERE!!!
Old 06-17-2012, 05:44 PM   #1215
KA-Life86
FWIW I got them to fit w -2.1 camber and a completely flat roll, shit looks badass, credit card fitment. I'll post pics tomorrow from work
Old 06-17-2012, 10:26 PM   #1216
240sx with rb26=BEAST!!!!
240sx with rb26=BEAST!!!! is an unknown quantity at this point
Will 18x10.5 +20 fit under 50mm origin overfenders with stock brakes and coilovers and will 18x9.5 +20 fit under 20mm front fenders.
240sx with rb26=BEAST!!!! is offline   Reply With Quote
Old 06-17-2012, 10:29 PM   #1217
JasianBlazin
Trader Rating: (24)
it will fit, but be sunken in like hell.
Old 06-17-2012, 11:20 PM   #1218
Kevin920415
Kevin920415's Avatar
Kevin920415 is an unknown quantity at this point
I was thinking about purchasing these wheels for my type x..
http://zilvia.net/f/wheels-tires/449...37-norcal.html
would i need some 25mm spacers to get the clean look?
You drive DA 2 fo tay?
Kevin920415 is offline   Reply With Quote
Old 06-17-2012, 11:42 PM   #1219
do you know how big of a spacer ill need?, but thanks.
Old 06-17-2012, 11:44 PM   #1220
correction 18x9 +35
Old 06-17-2012, 11:56 PM   #1221
fliprayzin240sx
correction 18x9 +35
So do you already have the fenders and you're trying to put on these wheels? My best advice to you either way is get better wheels.
But if you insist, put the wheels, measure how sunk the wheels are and get spacers with the same measurement.
To give you an idea, 10.5 +20 can fit under the stock fenders. You slapped 50mm fenders on top of that, 50mm equates to rougly 2 inches. So you'd need in the ball park of that much spacers in the rear. 9j +35 is sunk as shit on stock fenders, worst than your rears. 9j +0 fits under the stock fenders. So just to get it there, 35mm spacers. You got 20mm wider fenders, so thats a total of 55mm spacers up front. 2 inch spacers all around are absolutely fucking retarded.
CLICK HERE!!!
Old 06-18-2012, 12:02 AM   #1222
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
Just got my wheels in, mustang reps. 17x10.5 +20 with a 225/45/17 achilles. I have a stock body s13 coupe, and am about to go on a fender rolling/pulling venture. I really don't want to pull my fenders more then I have to (I'm scare of the oil can qp dent) but I also don't want to run 10* of rear camber. Did I order more wheel then I should have? lol or can I get these to fit..
pacotaco345 is offline   Reply With Quote
Old 06-18-2012, 12:13 AM   #1223
Alright thanks man i just had a choice for a good deal on some and i appreciate the help first person to explain it.
Old 06-18-2012, 12:24 AM   #1224
JasianBlazin
Trader Rating: (24)
put your front wheels on, does it clear your coilover? if not add spacer accordingly.
your rears will fit just fine with like 3° of camber no pull needed.
Old 06-18-2012, 12:25 AM   #1225
JasianBlazin
Trader Rating: (24)
yeah what fliprayzin said. do you already have the overfenders installed? if NOT, then go ahead with those specs. If you have them installed already get more aggressive wheels.
Old 06-18-2012, 01:37 AM   #1226
yea already have them on there, found some Varrstoen 18x10.5 +0, will i need a big spacer?
Old 06-18-2012, 08:40 AM   #1227
fliprayzin240sx
For the rears, its not a bad start. You might still need 15-20mm spacers but it wont be bad. Beauty of a setup like this on rears with overfenders, you have a lot of space to run wide ass tires.
What chassis is this going on? S13 or S14? Depending on the chassis will dictate how aggressive you can run up front. S13s suck for clearing wide rims up front.
CLICK HERE!!!
Old 06-18-2012, 11:53 AM   #1228
silviamex92
what would be the correct size tire for wheel setup
front and 18x9.5 +25 18x8.5 +35 rear* with KYB shock absorber setup suspencion gr-2 and H tein springs
Old 06-18-2012, 03:28 PM   #1229
fliprayzin240sx
I like stock diameter wheels, 225/40-18 for the 8.5j and 245/40-18 for the 9.5.
But the correct wheel setup is sell those junk and buy something better than that 8.5 +35. I've seen Hondas run more aggressive setup than that...
CLICK HERE!!!
Old 06-18-2012, 06:55 PM   #1230
lvlanolin
lvlanolin is an unknown quantity at this point
Hey guys I wanted to see if I run 18x9.5 +30 front and 18x10.5 +22 rear would I have to camber alot or will I be okay? I have stock fender which I'm gonna roll soon. Thanks in advance for the help
lvlanolin is offline   Reply With Quote
