Old 06-26-2012, 12:44 PM   #1
Jukebox
Jukebox is an unknown quantity at this point
96 240sx Sporadic idle, and bucking when warm
Problem started when i hit 100mph, then drove home. Not sure if that helps at all, but ever since then ive been having these problems.
PROBLEMS ONLY OCCUR when the car is warm (30min drive)
-Sporadic Idle, fluctuates from 100-800, completely random. One redlight it will act up the next it will idle perfect
-When pulling out it will bog down and if you dont rev it past 3k it will start bucking.
-When cruising the bucking will sometimes happen, and the rpms will drop a little when it happens (only seems to happen under 2.5k-3k rpms)
Any ideas?
Edit: Forgot to mention that no codes are being thrown.
Jukebox is offline   Reply With Quote
Old 06-28-2012, 01:53 PM   #2
Jukebox
Bump. Anyone?
Old 06-28-2012, 02:51 PM   #3
silviaks2nr
silviaks2nr's Avatar
You probably need to clean or replace your mafs or primary o2 sensor. Check for vacuum leaks too.
Old 07-01-2012, 04:03 PM   #4
Jukebox
Primary O2 sensor was just replaced earlier this year, maf is clean and no vacuum leaks. Still happening
