Old 01-04-2017, 08:18 PM   #1
muerte13
muerte13 is an unknown quantity at this point
Rb25det neo 2
So I got a 240sx with a rb25det neo 2 and I need help with the after market manifold Intake I install, I cant get the idle to work proper it shots off when i try to drive the car the idle goes down and car shots off, any body that can help me i appreciate...
muerte13 is offline   Reply With Quote
Old 01-06-2017, 03:38 PM   #2
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
how about some English first please???
supersayianjim is offline   Reply With Quote
Old 01-12-2017, 11:16 AM   #3
ADIDASilvias
ADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the roughADIDASilvias is a jewel in the rough
LOL
Which manifold, the Greddy knockoff? It will use a RB25det Series 2 Idle Air Control Valve (IACV), which will be necessary for cold start idle and idle under deceleration. The IACV allows air to bypass the closed throttle body butterfly so the air/fuel ratio remains appropriate for combustion.
Are you positive your engine is a NEO? There is no NEO 2 version of the RB25det. There is a series 1, series 2, and NEO RB25det. If it is a Series 2 and not a NEO, then you should have the right IACV valve for the Greddy type intake manifold, if you are replacing the stock manifold.
If you have a NEO, then the stock IACV will not fit the cut-out and mounting location on the underside of the Greddy manifold. I would then suggest purchasing a B13 Sentra IACV, from the 1.6 liter, which is the same IACV as the RB25 Series 2, minus the T on the air inlet (not really needed). It is a lot cheaper than buying the S2 IACV.
What do you have for tuning? The IACV can be blocked off, though I would not suggest it, if your tuning can compensate for the lack of air with no throttle input.
ADIDASilvias is offline   Reply With Quote
