05-13-2014, 03:44 PM | #7531 |
Not sure if serious....
But take face plate off, unscrew 4 screws, pull out HVAC unit, unplug 2 block connectors from rear, extend wire harness to where you want to relocate, plug 2 block connectors back to HVAC, and enjoy. |
05-13-2014, 04:57 PM | #7533 | |
ACE マジック HEART |
05-13-2014, 07:40 PM | #7534 | |
Pretty much cut the harness and extend with same gauge wires. About 80ft of 18 gauge, 7ft of 16 gauge, 7ft of 8 gauge and 3.5ft of 12 gauge was used. Cut small holes in the bottom of the center console for the harness plugs and you're done. I posted some details in a recent battery relocation thread HERE but this is what it currently looks like with the amp hooked up. There's a ANL fuse for the battery and amp on brackets just behind the box. To put the battery here you'll need to level the trunk floor. I did this with high density foam and some sheet metal. The foam is rock solid and everything turned out great with no unexpected issues (this particular battery needed some spacers between the posts so the tie down would fit but that was an easy fix). I did end up using some washers when making the floor level so the rod wouldn't crush the foam. Here's one showing the battery fuse holder. |
05-14-2014, 08:36 PM | #7535 |
Trader Rating: (38)
Feedback Score: 38 reviews
Thanks AZ
I was curious to know about the slider knob for the C/H setting. After replacing the bulbs on my HVAC unit, it was hard to work with the wire that goes with it. For a while, the slider knob didn't fully go to full cold. |
05-22-2014, 11:58 PM | #7545 |
the office
http://90s-forever.tumblr.com |
05-24-2014, 06:26 AM | #7546 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
I miss this car.
06-07-2014, 06:12 PM | #7553 |
We're going to pull the interior out of the S13 and strip everything down and spray it a shade darker than the exterior. Some G-Corporation pieces like the carbon radio surround and shifter/knob will probably find their way in there as well.
www.gtr-garage.com |
06-12-2014, 06:07 PM | #7558 |
Corndrift Blog |
