Group Buys Dedicated Forum for Group Buys. |
04-04-2006, 06:08 PM | #1 |
Alcohol Injection kits (Free shipping)
Here's something I don't see being offered on this board very often...Anybody on here interested in water/alcohol injection kits from Coolingmist.com at all?
Basically what it does is cool the air down allowing you to raise your boost level without detonating. Very popular with the GN, DSM, Evo crowds. Denatured alcohol can usually be bought in large cans at a home depot type store for $7/can. Depending on how you set yours up and how heavy a foot you've got a 2.0 quart can last quite a while. Deluxe 150psi injection kit Features: Methanol Safe 150 PSI Pump 15 Feet of Hose Boost Activated 1-25 PSI 90 Day Warranty Complete Kit This is our DELUXE 150 psi Methanol/Water Injection kit. It comes with everything you need. This comes with our 150 psi pump, brass water filter, 2.0 quart water tank , water tank taping kit and all the wiring, injectors and other things you need. This also ships with our outstanding brass checkvalve. This is a great deal. The boost switch is adjustable from 1-25 psi. Its a great kit at a great price. choose single nozzle or dual nozzle setup from the drop down box. If you have more than 500 HP or if you have twin carbs/throttlebodies we recommend the dual nozzle setup. $299SHIPPED! Deluxe Single Stage kit Performance Package Features: Base Kit Configuration + Arm/Disarm Switch LED Clog Nozzle Detector 52 MM Digital Air Intake Temp Gauge 2.0 Quart Tank Brass Water Filter The single stage Performance package is designed for those that want a complete kit and are want every tool to make sure that things are working properly. This kit includes a Single stage kit with a solenoid, Brass water filter, single stage clog nozzle detectors and a digital air intake temp gauge with sender. This ships with our 1-25 psi adjustable boost switch and our Amazing Brass Checkvalve. 2.0 quart tank and taping kit and 150 psi pump. Choose your options from the dropdown box. $399SHIPPED! Vari-cool controller kit Features : Coolingmist Controller Based 1-30 psi starting boost 1-30 PSI Full Pressure Up to 60 psi Pressure Includes Software Brass water filter Complete kit 0-5 V input for MAF, TPS, etc Our Stage I controller kit is a fantastic value. You recieve our high pressure pump, vari-cool tuning controller, a 2.0 quart tank and everything else you need. The controller has a starting point for boost, a maximum point for boost and a tuning knob. The tuning knob gives you 10 algorithms to choose from. For example, if you set the minimum knob at 1 and the max at 30 and have the tuning knob at 1 it will give you a linear feed from 1-30 psi. The higher you change the tuning knob the more agressive the curve. Because of this, you do not need to change injectors when you gain more HP. Our software suite allows you to change the variables in the controller so you can fine tune if you wish. Software requires windows 2000, NT, 2003, or XP +. The controller has a 0-5V input also, so if you prefer to inject the water based on the 0-5 instead of the boost, you can do that also. What else can this unit do? Lets say you want to run based on both 0-5V input and Boost...You can set the 0-5V as the primary input and the boost as secondary or you can set the boost as primary input and 0-5V as secondary. You must have the software configured to run that mode. $499.00SHIPPED! 1-gallon tank add $39.00 to any of the kits 10" x 8 1/2" x 4 1/4" for those that need a bigger tank. This tank has mounting tabs so you can fasten to your vehicle. This tank comes with a vented lid. This tank does not come with fasteners or screws, but does come with mounting tabs. This tank does not come pre-tapped, but is very thick and has a spot on the bottom or side to tap it. Please email or PM me with any questions you may have regarding these kits or water/alcohol injection in general! I need at least 5 people on board, doesn't matter which kit you go with. GB will end on Friday 4-14-06. $100 deposit expected at sign up and full payment by the end of the close of the GB. Deposits/Payment can be sent to [email protected] Please add your name to the list: 1. 2. 3. 4. 5. Last edited by zze86; 04-05-2006 at 01:40 AM.. |
04-04-2006, 08:39 PM | #2 |
Trader Rating: (40)
Feedback Score: 40 reviews
Any pictures installed on a 240?
What are the dimensions of the pump & reservoir so I can see where this will fit in my engine bay/wherever? Any better pictures of the products? Boost switch in particular, etc? Thanks |
04-05-2006, 01:35 AM | #3 |
Sorry, I do not have any pictures of this installed on a 240.
Dimensions of the 2qt tank are 6" x 8 1/2" x 4 1/2". PM'd your other ?'s |
