12-27-2013, 01:36 AM | #15691 |
Besides trying to get a replacement part and installing it, would JB Weld best the best way to fix this?
12-27-2013, 02:24 AM | #15692 | |
AFC #1
12-27-2013, 08:27 AM | #15693 |
Any help is appreciated! http://zilvia.net/f/tech-talk/549118...e-problem.html
12-27-2013, 08:30 AM | #15694 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
If that doesn't work, see if the calipers compress back freely with the turn tool, and then check the cables to see if any are frozen/rusty/tore. Quote:
The only thing is before you install them in your engine, refill another container with good oil, and just push the plunger down again until no air bubbles come out. As soon as you do that, drop it in the head. If at any time you turn the head upside down though (if it's on an engine stand or what not) you will need to rebleed them again.
12-27-2013, 09:28 AM | #15695 |
sr20 redtop into 89 240sx
I will have my sr20det redtop rebuild finished in about a week, is there anything I should know or do in general to make the engine run correctly? I will be running stock boost with a stock sr20det maf, gauge cluster, and O2 sensor, and the sr has new pumps, pistons ,rods ,and bearings. will it run correctly like this? is there anything I should check or do? I wired it up into the using the fr sport wiring guide so the wiring should be fine. I guess I have noob anxiety or something but I was just worried something wouldn't work right because its the sohc chassis. What should I watch?
12-27-2013, 11:12 AM | #15697 | |
Anyways I tried your suggestion about putting some extra gas to free them and all I heard was grinding noise like it didn't want to move and I'm pretty sure the sound was coming from the front. Maybe the back which i'm really confused now I also found out I was leaking on my left side where the z32 conversion line connects to the brake line. Getting tired of this now...need my car for transportation. Any help is appreciated. *Edit* Oh also when I change my gear from park to drive/reverse/neutral I don't have hold my brakes for that which is weird because I have always had to hold my brake to change gears. |
12-27-2013, 12:13 PM | #15698 |
Bandwagon.
yes, you can also use a KA24DE pump, just change out the brackets.
12-27-2013, 12:18 PM | #15699 |
Thanks for the suggestions guys. Will be looking for a piece at the junkyard eventually.
12-27-2013, 02:48 PM | #15700 | |
12-27-2013, 03:15 PM | #15702 |
looks like you need to just replace the handle. No way super glue will hold...jb weld MAY hold for a little while but don't expect excellent results.
95 S14 se RB25DET 348whp |
12-27-2013, 09:20 PM | #15705 |
I bought a used s15 turbo never changed a turbo before, however all went well and I primed the turbo before starting let it idle for 15 minutes but there was a very small amount of white smoke. is that normal?
12-27-2013, 09:22 PM | #15706 | ||||
Trader Rating: (58)
As far as the brakes, pull the wheels and inspect. Metal to metal is no good, could have maybe put them in wrong or had a slider pop out too. Quote:
Use the search feature to see what others have sold for. I do that all the time with stuff I wanna sell.
12-28-2013, 08:41 AM | #15707 | |
If that interior door handle is common between most models as it appears to be(Sentra SER, 240SX to 98) I have what you need. I only need to remove it and send it. $40 Shipped USPS Priority. If you want more than the handle, like the button, cup and any interior attaching hardware, we can negotiate. I'm in upper mid TN currently rebuilding my 96. This is my parts car
12-28-2013, 12:15 PM | #15708 | |
12-28-2013, 12:24 PM | #15709 |
Anyone know if these are S13 OEM mudflaps, and not just from some other Nissan? I've just never seen any S13 mudflaps with the Nissan logo on them.
Judging from the little curve cut on the bottom left one, I'm assuming they are and that one is the one that goes on the rear left by the exhaust. But I just wanted to double check before I actually buy them. |
12-28-2013, 02:58 PM | #15710 | |
The space I'm talking about is where the guy is measuring at in the picture. The left side is actually grinding the rotor. I don't know if its on both side but I'll have to check tomarrow. Do you think thats why the car wont drive? Also check this other thread I have, hopefully you can help me out. It may be another problem that might of caused my car not to drive and make grinding noises. http://zilvia.net/f/tech-talk/549118...e-problem.html |
12-28-2013, 04:03 PM | #15711 |
Any kouki guys here? Looking for more information on these books in the trunk. Assuming they are from the factory.. I believe the books next to the nissan bag are the Owner's Manual and Warranty Information books if my eyes aren't deceiving me. More curious as to the book on the far right. I haven't seen this book before and was wondering what it was. Tried to ask the owner, but he hasn't replied yet. Thanks for the help |
12-29-2013, 01:50 PM | #15713 |
LOOKING FOR REVIEWS ON THIS TIMING CHAIN RPM MACHINE
KA24DE Rebuild Kit, Performance Parts Turbo Rated |
12-29-2013, 01:57 PM | #15714 |
yes but they both need to be the same type (ex. both s13 & s14 will need to be non abs) something about the s14 abs rotors are different i forgot what it was though. in general they should be interchangeable.
12-29-2013, 04:04 PM | #15715 |
I have to check my measurments on my z32 calipers most likely I bought the wrong rotor size 30mm which I think I need 26mm rotors because I'm hearing grinding.
Anyways if that happens does anyone want to buy 2 30mm drilled/slotted rotors for z32? I'll sell them for $70 PM me if you're interested. |
12-29-2013, 09:42 PM | #15716 | |
AFC #1
12-30-2013, 09:01 AM | #15717 |
Found out one of my calipers are 30mm aluminum while the other one is 26mm aluminum. And that's why my car was not moving, because I was using 30mm rotors on the 26mm caliper and it was stuck.
Is having 2 different caliper sizes bad for the car? As long as I have the right rotor for each caliper it wont do anything wrong would it? Thanks Last edited by acslater9; 12-30-2013 at 12:03 PM.. |
12-31-2013, 06:50 AM | #15718 | |
Rule #1: All corners must retain equal balance and force to handle and stop correctly Explanation: Each corner of the car must balance out on either side of the axle, and diagonally across it's length. This means that the brakes must be balanced on each side of the axle in weight, size, and performance level(on the diagonal, an average of 60% front biased force). Shocks and springs must be the same at all four corners To answer your question: You need to get either 2 30mm rotors, or 2 26mm rotors, and insure that the pads are equal on each brake and that each rotor is the same weight
12-31-2013, 04:23 PM | #15719 |
My window wont go back up on the driver side. The Nissan dealership told me its 380 to replace the motor.......anything I can do to fix it ? It could even be the switc, I have no clue why its not working.
12-31-2013, 06:55 PM | #15720 |
Hold the button pressed while you close the door somewhat hard. Works for me. I've been doing it that way for a year now haha
