02-06-2009, 08:40 AM | #33 |
This actually works? I have R33 GTST's and 32mm rotors are alot easier to source from the GTR.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
02-12-2009, 11:25 AM | #35 |
Almost anything Endless is super expensive.
02-12-2009, 11:26 AM | #36 |
anyone have an answer to if the R32 GTR 296x32mm rotors are compatible with R33 GTST calipers that normally used a 296x30mm rotor?
Just bolt on or something else needed?
02-12-2009, 02:10 PM | #37 |
u can just save 1mm off each side of the rotor
search around on the Aussie forums. I just bought some gtst rotors off skyline Australia
02-12-2009, 02:55 PM | #38 | |
Sourcing used is always an option but getting someone to ship internationally is a bit difficult.
02-12-2009, 03:50 PM | #40 |
post the link so anyone can order.
Chances are you found 1 dude willing to chance and know how to ship to the US, then got lucky he didn't send out of spec rotors.
02-12-2009, 09:58 PM | #42 |
Anyone know offhand if an r33 GTS-T setup will clear 18x9/10 +20 Work XD-9s? I know this question is random and I will have to measure it to know for sure, but if someone knows off the top of their head for sure, that would be super.
02-13-2009, 03:22 PM | #45 |
okey guys i just did the Lexus gs rotors on the r33 gtst caliper. you will need to make the center hole bigger (should be like 72mm or take it to a machine shop and ask them to make the hole 68mm with the inside slanted like this / \) in order to fit and add a 1/8 in. washer to the caliper for the correct offset. and like i mention before the 32mm thickness is not a problem just make sure your pistons are pushed in all the way in. ill post pics later when it stops raining.
02-13-2009, 06:37 PM | #47 |
correct, and when you need to have them turned you'd be ass out.
06-24-2009, 03:36 PM | #48 | |
where are the pics? im curious to know if can do this for my GT-ST brakes. |
06-24-2009, 03:56 PM | #49 |
brembo makes R32 GTR blanks right? If 32mm works with R33 GTST 30mm calipers I am going for that route.
06-24-2009, 03:58 PM | #50 |
can anyone confirm? that seems wayyyy easier to do.
