Archive and FAQs Archives and Frequently Asked Questions about the 240SX are in here. |
06-15-2003, 08:57 PM | #1 |
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
damn i cant remember what the actual price was... but this will tell you
here BTW: this link will tell you everything about anything 240 related amazingly
89 240 SR powered... ummm i promise its stock |
06-16-2003, 08:42 AM | #2 |
get in touch with Nissan if you need new parts
the custom hubs at Jspec are 450 and then you don't need all of the other parts call salvage yards in your area to find prices on knuckles and hubs as prices will be different everywhere ball joints i just ordered for 35.85 each and that was the best price i could find
I never knew you could do that with an eggplant |
06-16-2003, 09:37 AM | #3 |
WOW addicted
300-500 for the swap with used parts. usually doesn't include the s14 ball joints for the front control arms.
I bought GTO hubs from Jspec - 450 and 2 300zx na rear hubs from junkyard - $100 you could just buy 2 new s14 rotors all around - (nopi) - $120 total - $570
06-16-2003, 09:42 AM | #4 | |
WOW addicted
06-17-2003, 09:54 AM | #5 | |
WOW addicted
06-18-2003, 09:18 AM | #6 |
WOW addicted
They do not have the ABS sensor ring on the ones I bought.
I will try to get pics of them this afternoon. Also, I don't believe anyone makes aftermarket hubs for the REAR of the s13 b/c you can use either S14 5-lug rear hubs, OR Z32 NA rear hubs as a direct bolt on. I chose Z32 hubs b/c I plan to upgrade to the 300zx Aluminum uprights, and rear brakes one of these days. You get the front Aftermarket hubs b/c if you don't, you have to get S14 Knuckles S14 Spindles S14 5-lug hubs s14 Strut Mounting bolts (larger than s13) S14 Ball joint S14 Rotors (you'll need these either way, unless you go 300zx brakes.) Thne you have to get your new ball joint pressed into your s13 Control arms, and drill out the strut mounting bolt holes to accomodate the larger bolts. Bolt everything up and your ready to go.
06-19-2003, 09:38 AM | #11 | |||
WOW addicted
Check here for all the different 300zx calipers: http://www.princeton.edu/~asad/zbrakes/ Quote:
No you don't need any aftermarket rotors or calipers. Unless you install some other calipers you will need to use S14 5-lug rotors with your stock s13 calipers. This is really a different discussion all together. Quote:
06-18-2003, 11:03 PM | #13 |
With the aftermarket s13 front hubs, what rotors and callipers fit...z32 NA?, turbo? If not, which ones?
And about the rear hubs, tell me if i'm wrong, but it is possible to just bolt on the z32 rear hubs and then the z32 NA or turbo rear rotors and brakes. Or do i need aftermarket rotors and callipers as well? One more...is the only purpose for swapping in the z32 allminum uprights just for weight savings or are there more bennefits? Thanks! |
06-19-2003, 12:04 AM | #15 | |
BAD CHIMP BAD CHIMP! Knuckle=spindle! and the hub is already ON the damn thing! should be S14 SE Front spindle S14 SE or Z32 rear hub Get it right or pay the price! |
06-19-2003, 11:57 AM | #16 | |
06-16-2003, 09:42 AM | #17 |
yeah! good move sykikchimp! i got those hubs sitting in myr oom for the past month haha
good move!!!! cant wait to see the wheels on your car! |
06-16-2003, 04:22 PM | #18 | |
using z32 uprights, you use the s13/s14 (depending on your car model) suspension parts. fit perfectly fine. |
06-17-2003, 09:56 AM | #19 | |
06-17-2003, 10:50 AM | #20 | |
its not cheap...i guess i cant say but i think its worth. for me i will probably sell my coilovers or a friend (more likely) will be using mine when i upgrade. i dontw atn to redrill my coilover to fit the s14 busienss. also i want aftermarket FLCA, dont want to worry about ball joint business for the average joe, go w/ the s14 fronts for someone who's going balls out and changing A LOT of stuff, i'd get the type Jspec sells. the 5 lug front hubs. its all about $$ and what you want to do with your car. |
06-18-2003, 09:22 AM | #21 |
sykikchimp
your going to sh!t a brick now i saw the new attain hubs its 4 AND 5 lug aftermarket its drilled for 4 and 5 the studs you get have a opening at top for allen wrench so you can move them to a 4 lug or a 5 lgu pattern when i saw that, i look at the gto ones...damn that's perfect for the track if you need to borrow someone's wheels OR your a wheel whore like me who love many 4 and many 5 lug wheels damn, i want those attain ones now!! i will scan itup later yeah aftermarket is easier. that's why i did it. |
06-18-2003, 09:59 AM | #22 |
oh, it is available in front AND rear!
they retail at...i THINK it is 39,800 front (335 USD), 63,000 rear (531 USD), studs are 16,000 for a set???? (135 USD) dont know if included w/ the hubs.. but im not 100% sure..ill scan it up tonight...if i have a chance, pretty crazy night. this is from the june 03 drift tengoku, page 136/7 front: (R)(P)s13, C33, A31 rear: (R)(P)s13, s14, s15, c33, a31, hcr32 article also says "KSP" so they might sell it/manufacture it..i dont know....no clue just super cool!! |
06-15-2003, 10:01 PM | #23 | |
Team Mullet - Its not just a hair style its a lifestyle |
06-16-2003, 09:56 PM | #24 | |
06-17-2003, 07:42 PM | #25 | |
GTO hubs
06-16-2003, 04:15 PM | #26 |
all s13 components should work with s14/z32 knuckles right? with the exception of rear shocks w/ the z32 knuckle/upright since they use fork style. but how bout t/c rods, rear traction toerods, etc..
06-15-2003, 06:47 PM | #27 |
What can I expect to pay for S13 -> S14 5Lug hubs/spindles/knuckles
I find plenty of threads telling me which parts are needed to do the 5 lug swap on my 240, but not many threads with detailed pricing. I have a guy that has most of the stuff I'll need but I'm not sure what kind of price to ask for this stuff. How much would I expect to pay for:
S14 front hubs, knuckles, and ball joints S14 rear hubs Please correct me if you know I will be missing some parts for the swap, I'm doing the 300zx front brake upgrade as well. Will all of this stuff clear stock rear brakes when I buy my 9.5 inch rear wheels with +35 offset? Or do I need to go down to the 8.5 inch rear wheels wiht +35 offset because the wheels I want don't come in just 9 inch. I know it is a lot of questions but I really appreciate any help you can give.
04 GTO 00 S4 00 S4 1995 240sx S14.5 SR20 Freshly Built Motor, T3/T4, S15 Front 1990 S13 Hatch SR20 @ 400+ whp SOLD |
06-15-2003, 10:11 PM | #28 | |
06-17-2003, 05:10 PM | #29 |
:hammer: The more I get responses, the more I don't understand wtf I need, lol.
So if I don't want to buy these hubs from JSpec right now I can go out and buy: S14 front hubs, front ball joints, knuckles, and do I need front control arms as well? And for the rear I just need to buy some rear hubs off of a NA Z32? I spend all my time learning the components of the motor like the back of my hand but never spent really any time with the suspension game yet. Guess I have a lot more to learn. Thanks for the good info so far though guys!
06-18-2003, 04:40 PM | #30 | |
That is what I'm talking about there man, straight to the point, this is what I've been looking for for ages now. Someone put this in the FAQ because it lists prices an a lot of information about the hub adaptors that isn't in any other of the lug conversion threads, thanks guys!
