Old 04-09-2002, 11:42 PM   #1
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
Post informative offset links or quotes...
http://www.zilvia.net/forums/cgi-bin...m=2&topic=1471
http://www.tirerack.com/wheels/tech/offset.htm
(edit*)Courtesy Matt (mdsdm) from 240sx.org
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">
original wheel width = a (in inches)
original wheel offset = b (in mm)
new wheel width = c (in inches)
new wheel offset = d (in mm)
difference in clearance on the inside between original & new = f (in mm)
difference in amount the wheel sticks out bewtween original & new = g (in mm)
f = ((a*25.4)/2 + b)-((c*25.4)/2 + d)
g = ((a*25.4)/2 - b)-((c*25.4)/2 - d)
</td></tr></table><span id='postcolor'>
LanceS13 is offline
Old 04-10-2002, 12:24 PM   #2
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Here's more info:
-Offset is the distance from the front of the hub-mounting surface to the center of the wheel.
-Zero offset means that the hub mounting surface is even with the centerline of the wheel.
-Positive offset means that the hub mounting surface is toward the street-side of the wheel.
-Negative means the opposite. (towards the axles).
Edit: Never mind, I just read Lance's link.
S13Grl is offline
