Old 01-06-2020, 11:15 AM   #1
spitefulcheerio
spitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura aboutspitefulcheerio has a spectacular aura about
180sx VLSD 5 Bolt Axle Help
Hey guys, need help figuring out what axle to run on my car
I've read that the J30 driver side axle is a beefier option that will work perfectly on my left side and the measurements I'm seeing confirm that. It's the right side that I'm seeing as an issue. The J30 axle is a half inch longer and I've read that it will cause binding issues or something like that. I saw someone mention that I could use a 300zx left side axle on my right but that axle is a half inch shorter and since I'm lowered idk if the axle will have issues with popping out or anything.
Anyone got some insight into a bolt up option for my car? Really appreciate any help I can get
spitefulcheerio is offline   Reply With Quote
Old 01-06-2020, 06:22 PM   #2
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
Do you just need 5 bolt axles? I have a set I pulled out of my Silvia.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille
e30gangsta is offline   Reply With Quote
Old 01-06-2020, 06:57 PM   #3
spitefulcheerio
Sent you a PM
Old 01-06-2020, 09:28 PM   #4
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
I have the z32 N/A driver side axle on my passenger side on my 240, the same thickness as the jdm axle and the right length
andisan is offline   Reply With Quote
Old 01-07-2020, 08:15 AM   #5
crash n' burn
crash n' burn's Avatar
crash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura aboutcrash n' burn has a spectacular aura about
I'm running J30 axles with no issues.
There isn't a risk of the inside joint popping out in the same way as there is with stock 240sx Tripod joints; J30, JDM S13, z32, etc etc (anything NOT 2x3 pattern) use rzeppa joints at both ends; which is also the main reason why they're stronger.
Key'd Performance
@jz_2tone
crash n' burn is offline   Reply With Quote
Old 01-07-2020, 10:19 AM   #6
duballstar37
duballstar37's Avatar
duballstar37 is on the path to ruinduballstar37 is on the path to ruinduballstar37 is on the path to ruin
This thread popped up yesterday right around the same time as your post. Check it out!
https://zilvia.net/f/showthread.php?t=555322
P.A.T.T.
duballstar37 is offline   Reply With Quote
Old 01-08-2020, 03:51 PM   #7
spitefulcheerio
You have an s13 with a 180sx VLSD?
Old 01-08-2020, 11:54 PM   #8
crash n' burn
n/a z32. Same r200 case, so yes.
Key'd Performance
@jz_2tone
Old 01-09-2020, 02:07 PM   #9
NashT
NashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choices
VLSD also came in the HICAS models from factory
NashT is offline   Reply With Quote
