04-03-2013, 09:31 AM | #31 |
Engine: S14 sr20det
WHP: 450whp and 400tq Rods + Pistons: wiseco 87mm and eagle rods Injectors: 740CC Compression: 8.5:1 Turbo: gt3071r twin scroll with full race gen1 manifold Intake Manifold: greddy with stock tb Boost: 23psi Cams: oem with stock vvt ECU: aem ems Gas: ms109 made 375whp at 18lbs on 93 octane.... maxxed out injectors on ms109 tuner thinks there was more power left..... |
04-03-2013, 06:46 PM | #32 |
Man w/ CTSV & a Car Seat
Engine: RB25DET S1
WHP: 420.03 whp/338 ft/lbs Rods + Pistons: Stock bottom end Injectors: 550CC Compression: Stock Turbo: Old Trust IHI RHC6 Turbo Manifold: Greddy Intake Manifold Boost: 15 Psi Cams: Stock ECU: PFC D-Jetro Gas: AAFES Base gas 93 Before, on my "I'm learning to tune" map, don't mind the 3rd pull, coupler popped off: After, on "I gave up on tuning cuz I suck so I had Ramey Built retune it" map: |
04-04-2013, 10:16 AM | #33 |
Engine: S13 SR20DET
WHP: 262.1 whp / 250.6 ft/lbs Rods + Pistons: Stock bottom end Injectors: 550CC STI Compression: Stock Turbo: GT28R Manifold: Stock Boost: ~17 Psi Cams: Stock ECU: PFC J-Jetro Gas: 93oct |
04-04-2013, 11:47 AM | #34 |
Trader Rating: (29)
Feedback Score: 29 reviews
Engine: S14 SR20DET
WHP: 350.1 whp / 343.2 ft/lbs Rods + Pistons: CP Pistons, Scat Rods Injectors: Tomei 740 Compression: 9:1 .20 over Turbo: Tomei Arms M7960 Manifold: Stock intake manifold Boost: ~19 Cams: Stock ECU: Nistune Gas: 93oct (Green runs are S14 PnP turbo/oem fuel/oem ecu(Only things we changed)) Old setup: Engine: S14 SR20DET WHP: 223 whp / 203 ft/lbs 255 whp / 255 ft/lbs Rods + Pistons: CP Pistons, Scat Rods Injectors: Stock Compression: 9:1 .20 over Turbo: Stock, ported/polished/ceramic coated Manifold: Stock intake manifold Boost: 8/11.5 Cams: Stock ECU: Stock Gas: 93oct 3.5 extra PSI ftw. We later left it at 14.5...but don't have a dyno chart for that
04-28-2013, 03:03 AM | #36 | ||
Trader Rating: (53)
Feedback Score: 53 reviews
What motor?? Quote:
Thread updated. I think maybe we should move this thread to a different section.... |
04-28-2013, 05:14 PM | #37 |
Engine: R32 RB20
WHP: 355 whp , 300 ft lbs. Injectors: 740CC Deatschwerks, 255lph DW fuel pump Turbo: Precision 3231E Intake Manifold: Custom made front facing Boost: 20psi Gas: 94
92' R32 GTS-T 355whp |
04-28-2013, 10:10 PM | #38 |
Engine: S13 SR20DET
WHP: 458 WHP 342 WTQ only spinning up to 7,400 even though we could have spun it past 8.5k easily Greddy Rods & pistons, Maxworks built & sleeved bottom end Injectors: Injector Dynamics 1000CC. Splitfire coil packs, NGK plugs Compression: 9:1, with Apexi HG Turbo: GTX3076R billet wheel .64AR single scroll with anti-surge housing, full race manifold & down pipe, 4" intake with 1200cfm AFE air filter Manifold: Greddy Intake Manifold, Era-1 billet Throttle body, Greddy R Spec intercooler with stainless fabricated piping, Tial 50mm BOV and 44mm MVR wastegate Boost: ~ 20 Psi Cams: HKS Step 3 272 with solid lifters ECU: Apexi Power FC MAP-based, with boost control Gas: 92 pump gas We had another .5 AFR+ to go, 1 or 2 more psi, a couple degrees more timig and 1k RPM more that we could have spun it up to. It was 7:30PM at night so we quit. We probably could have gotten past 500rwhp and we think we could have done it safely on pump gas. The car is daily driven, and the knock sensor hasn't shown any signs of knocking on 92 at full boost. I am convinced that there is much more in it, but the car barely gets traction in 3rd gear with 275s so pushing for 500 rwhp is impractical except for bragging rights, which I don't care about. The above printout wasnt the last run, but the final sheet wasn't much different (I don't have it on this laptop) This dyno sheet shows my new GTX3076R plot over my old GT2871R plot; same car same dyno.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
05-12-2013, 11:17 AM | #39 |
Engine: S15 SR20DET
WHP: 301 WHP 322 WTQ Rods + Pistons: Oem Injectors: oem 480`s Compression: Stock Turbo: stock Manifold: stock Boost: 17 Psi Cams: stock ECU: stock with RS Enthalpy tune Gas: 93
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 Last edited by Tom N; 06-05-2013 at 06:17 PM.. |
06-05-2013, 11:56 PM | #40 |
Engine: S13 SR20DET
WHP: 310 whp 300 tq Rods + Pistons: Oem Injectors: Nismo 555CC Compression: Stock Turbo: Megan manifold/S15 Manifold: Stock intake manifold Boost: 17 Psi Cams: Stock ECU: Nismotronic Gas: 93 Dyno: dyna pack Last edited by 1nasty240sx; 06-29-2013 at 08:56 AM.. |
06-06-2013, 12:21 PM | #42 |
Thanks. I can't take the credit though. Car was tuned by Martin ( RS Enthalpy ) Car hits hard down low and pulls strong to 7k.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
06-06-2013, 08:59 PM | #43 |
Engine: S13 KA24DE
WHP and WTQ Numbers: 366whp, 355wtq Turbo: Precision 5431, .48AR exhaust housing. Ebay exhaust manifold. Boost: 16 psi Internals: Wiseco 9:1 pistons, K1 rods, ARP hardware, ACL bearings Injectors: Delphi 1000cc Cams: Stock ECU: Megasquirt PNP Gas/Fuel Type Used: 93 octane |
06-06-2013, 09:17 PM | #44 | |
That is a really nice powerband.
Maybe add 256 or 264 cans to extend it past 7k abd you would have a insane powerband.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
06-07-2013, 10:31 AM | #45 | |
and ditch the 93, convert to ethanol!
06-09-2013, 09:57 PM | #46 | |
E85 would be sweet, there aren't many stations around me though. I drive to/from track days so it's nice being able to get fuel anywhere. |
