Old 09-20-2010, 05:47 PM   #2821
bnadeau73
bnadeau73's Avatar
bnadeau73 is an unknown quantity at this point
anyone think this set up is safe?
s15 T28 @ 14psi(too much for stock headgasket?) or should i do 12-13psi?
stock redtop
480cc injectors
n60 maf
fmic
electric cutout at downpipe
getting dyno tuned by EMANCE
HALP!!
Today 09:56 AM
I have a HKS 2530 and am running around 1 bar of boost which is about 14.5 psi. I knew a guy in Japan that was running the same turbo (on a stock head gasket) at ~1.1 to 1.2 bar or about 15.95 to 17.4. He worked at a shop so he did not care if he blew the head gasket. While running that setting he attended most of the drag events in the Tokyo area and had been doing so for over a year. Personally, I boosted the car at 1 bar for about a year without any problems.
-Brandon
bnadeau73 is offline   Reply With Quote
Old 09-20-2010, 08:03 PM   #2822
chiboy002
chiboy002 is an unknown quantity at this point
does NGK/Nardi quick release 3.0 (or any other variants) still allow the turn signal cancellation?? I need a hub and i wanna still have the pleasure of it automatically doing it
street dancer.
GLEAM
Old 09-20-2010, 08:43 PM   #2823
nathanong87
nathanong87's Avatar
does adding negative camber to the front wheels change the toe like in the rear on an s-chassis. i jus went from like -0.5 to -3.5 and will probably need an alignment no?
natelife.tumblr.com
Old 09-20-2010, 09:40 PM   #2824
Mesarina
Mesarina's Avatar
Mesarina is an unknown quantity at this point
where do you think is best to mount a fire extinguisgher on a rhd s13? behind drivers feet above seat or on passenger side trans tunnel maybe???
Mesarina is offline   Reply With Quote
Old 09-20-2010, 09:43 PM   #2825
Mesarina
Mesarina's Avatar
It should allow the turn signal cancellation, i has nothing to do with the hub
Old 09-20-2010, 09:43 PM   #2826
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
It would affect it a tiny tiny bit. Not enough to kill your tires in a day but going from near 0 to near 4 I would get an alignment.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 09-21-2010, 06:45 AM   #2827
240sx123$
240sx123$ is an unknown quantity at this point
To add to this.. whats the deal with the cruise control buttons? Are there any aftermarket wheels that allow me to retain these? I use my cruise fairly regularly.
240sx123$ is offline   Reply With Quote
Old 09-21-2010, 06:47 AM   #2828
obsolete
obsolete is an unknown quantity at this point
What's the size of the two wires coming off the fuse box to (+) batt in s14?
obsolete is offline   Reply With Quote
Old 09-21-2010, 11:29 AM   #2829
axiomatik
axiomatik's Avatar
I've seen some people relocate the buttons to somewhere else.
Old 09-21-2010, 05:04 PM   #2830
Dominic Axelson
Dominic Axelson's Avatar
Dominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfection
Send a message via AIM to Dominic Axelson
Where can I get an sr20 o2 sensor new or used for cheap? any part numbers? I have a red top but have a full after market exhaust. Please and thank, you!
Dominic Axelson is offline   Reply With Quote
Old 09-21-2010, 05:16 PM   #2831
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
skinny type? i think you can use a z31 300zx one.
R@ddy is offline   Reply With Quote
Old 09-21-2010, 05:35 PM   #2832
Dominic Axelson
Yea I'm 98% sure I need the "fat" one because of the aftermarket exhaust.
EDIT: Just measured it and its about 3/4 of an inch.
EDIT AGAIN: I found a new one on ebay and bought that one. Thanks
Old 09-21-2010, 10:04 PM   #2833
chiboy002
i thought some didn't have space for the blue ring or something, idk i was confused.
None, to my knowledge, allow it to be mounted to the wheel still, but you can always set it up to that "free spot" on the dash near the rear wiper button. I personally don't care for cruise control, it would be nice to keep but most likely removing it as i swap steering wheels.
street dancer.
GLEAM
Old 09-22-2010, 03:09 PM   #2834
endlessboost
endlessboost is an unknown quantity at this point
How many degrees of steering angle does a stock s14 have?
endlessboost is offline   Reply With Quote
Old 09-22-2010, 05:55 PM   #2835
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
for a stock car it's in the FSM. It's in the FA section, for both S13 and S14. It's 39-43* inside wheel, 33* outside wheel.
taken from google
Originally Posted by rat240 View Post
sick bro .... hella jdm foshow i love haters
heavenboundkevin is offline   Reply With Quote
Old 09-22-2010, 06:42 PM   #2836
Wake
Wake's Avatar
Are KADE head bolts reusable?
I dont know why I cant find a straight answer, or an answer in the FSM.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 09-22-2010, 09:55 PM   #2837
uLmighty
uLmighty's Avatar
uLmighty is an unknown quantity at this point
Send a message via AIM to uLmighty
quick Question! how do i post pics on here w/o givin a link or anything?
uLmighty is offline   Reply With Quote
Old 09-22-2010, 11:13 PM   #2838
foggygoogleso.O
foggygoogleso.O's Avatar
Trader Rating: (18)
foggygoogleso.O is an unknown quantity at this point
Feedback Score: 18 reviews
Im doing a 5spd swap and was wondering if i need to get a 5spd bezel because I don't know if the auto bezel will work.
Thanks.
foggygoogleso.O is offline   Reply With Quote
Old 09-22-2010, 11:16 PM   #2839
younghatchowner
younghatchowner is an unknown quantity at this point
my friend says that you can run power steering fluid through heater hose..i thought that it will eat through the hose..who is right???
younghatchowner is offline   Reply With Quote
Old 09-23-2010, 08:56 AM   #2840
bnadeau73
bnadeau73's Avatar
s14 fsm and 200sx fsm
From what I have read, in order to get a FSM in English for a 180SX, I need to obtain a s14 FSM with the SR20DET and a 200sx FSM with the CA18. I have been searching for several hours on Google and many vehicle specific sites such as Zilvia and every link I have followed has been dead.
Does anyone have full copies of either of these manuals that they could provide.
Thanks,
Brandon
Old 09-23-2010, 11:14 AM   #2841
axiomatik
axiomatik's Avatar
I suggest uploading the picture to photobucket or imageshack and using the [IMG] tags and the image's URL to post it. Zilvia allows you to upload a very limited amount of pictures, but I don't know how, never done it.
Old 09-23-2010, 12:15 PM   #2842
UGLYLOWLIFE
UGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymore
Everytime i accelerate i hear this raspy sound from the engine bay. It doesnt make this sound when i brake or when im coasting. The higher the rpm the louder the raspy noise, why does my s14 make this noise?
UGLYLOWLIFE is offline   Reply With Quote
Old 09-23-2010, 01:08 PM   #2843
Wake
Wake's Avatar
Dont, Use photobucket or tinypic.
Thanks.
If your talking about your shifter trim then no you dont need a new one, you just need to get a shift boot, remove your trim, flip it over, unscrew the bracket and install the new shift boot, reinstall trim. Done.
Why would you want to do that do begin with?
Thanks,
Brandon
http://lib.store.yahoo.net/lib/phase...s14sr20det.pdf
Now does anyone know if I can re use stock KA head bolts?
S.P.P.S. Member #00
Old 09-23-2010, 01:10 PM   #2844
240sx123$
Subaru guys reuse theirs all the time, but as far as I know theyre the only ones that unanimously agree that its ok to do. Every other motor ive worked on has strongly recommended replacing them.
ARP's are $100.. its worth the cheap insurance.
Old 09-23-2010, 01:18 PM   #2845
TUnity2
TUnity2's Avatar
TUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of lightTUnity2 is a glorious beacon of light
You shouldnt be using power steering fluid in a 240. they use automatic transmission fluid in their powersteering systems. And heater hose will work fine for that.
Thanks.
Nope, the gauges are the same.
TUnity2 is offline   Reply With Quote
Old 09-23-2010, 03:09 PM   #2846
axiomatik
axiomatik's Avatar
Is it a pulsing noise? could be your exhaust manifold gasket.
Old 09-23-2010, 03:34 PM   #2847
foggygoogleso.O
Trader Rating: (18)
thanks man.
all i need now is the clutch and im all done.
and of course do the swap. :O
Old 09-23-2010, 07:25 PM   #2848
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
you have to add [img]link inside[/img]
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 09-24-2010, 02:57 AM   #2849
driftnuts
In time-out for misbehaving.
driftnuts is an unknown quantity at this point
hey guys i need help here i did a clutch master and clutch slave on a friends car. He still has barely any pressure at all. Know what it could be? I tightened everything even the bleeder valve on the slave cylinder is tight. OH and its really hard to put in gear!
driftnuts is offline   Reply With Quote
Old 09-24-2010, 08:32 AM   #2850
thenooblet
thenooblet's Avatar
thenooblet is an unknown quantity at this point
Are runflat tires harder to stretch than regular tires?
Originally Posted by towlie View Post
Texas does LS's hard
thenooblet is offline   Reply With Quote
