06-23-2012, 06:32 PM | #1 |
1UZ V8 Coupe POW! (Slow Build)
starting a new project and ill update as i go. been collecting parts for sometime now. trying to buy parts here and there, tried to gather what i needed then put together.
Started off with a 91 Coupe with a KA24DE Picked up a ls400 1uzfe motor from a dismantler in Rancho Cordova, CA And started taking things apart. First thing done was new timing belt Got the Bottom crank at TDC: L&R cams: Dont mind the belt marks New belt aligned: New gasket kit (i will only be using a few things from this) And here are all the parts i Have ready to go: I Knew i wanted to go with a KA trans bc of how easy they are to find, and the 5 speed gear box i think will be good with this motor. plus i dont need a new drive shaft or trans mount. So research led me to getting the following. 1uz to KA trans adapter plate w/ TOB spacer MR2turbo flywheel (Same spline count as KA trans) 300 zx Clutch Disk (Same surface area as flywheel) I gave Brett Collins a Call and ordered what i needed. BEEEFY! plate And TOB Spacer w/ other parts such as Injector seals PBM coolant temp sensor housing thing PBM shift Knob |
07-31-2012, 09:34 AM | #4 |
Trader Rating: (18)
Feedback Score: 18 reviews
did you need to get a new pivot ball? Also, did you get the trans machined to make up for the extra thickness of the adapter plate?
https://instagram.com/eck_matthew/ |
08-01-2012, 01:41 AM | #5 |
Trader Rating: (79)
Feedback Score: 79 reviews
1UZ FTW curious on the install
My Build: The "Coupe De Ville" 1JZ Build!! |
08-30-2012, 12:42 PM | #6 |
Had a chance to work on this thing.
Got You can see how i had the machinist mill around the center crank bolts to use the oem plate as a pressure plate to distribute the pressure evenly on the bolts Used ARP 4ag flywheel bolts. clutch and pressure plate mounted up I wanted to really feel this thing when i kicked the clutch, 2500lb pressure plate: Next i had to fix the starter clearence issure so i removed the stock starter bolts and added a spacer to the inside to push it back about 3mm. now it has enough room to engage and not rub when not. I than sat the engine the bay to start figuring out the motor mounts, This is where i left off but you can see what need to be done. That hump is the Xmember. And this is the room i have |
08-31-2012, 12:51 AM | #9 |
For mounts I was going to make my own but we just
Moved into a new house and to keep the cutting and grinding noise Down until I get to know the neighbors i ordered them from enjuki (sp) Now as far as wiring that's something I don't want to mess with so I'm trailering the car to Livermore, Ca where I found a guy that can wire it. He's done a lot of 1uz swaps and even bar'd theM But I'm not doing all that since I took off all egr and headers Are beyond oem. I'll make a wiring guide once I get to that point to help you all out. |
09-05-2012, 05:35 AM | #11 |
Cool build bro! If I wasn't going 1J I'd be all over this! Honestly at times I thought about selling it and doing the 1UZ. But I've got mounts wiring etc. already... maybe one day.
10-28-2012, 12:50 PM | #13 |
It's good to see another person venturing with this swap. The 1UZ is a great motor and they are dirt cheap! You going to keep it stock/NA or what are your goals with it?
11-14-2012, 08:16 PM | #16 |
hey u think i can get the guy that's doing ur wiring done? i just to know how much he would charge. i cant decide whether or not to go 302 or 1uz. i dont care jus want a legit v8 job done.
