09-10-2014, 05:00 PM | #1 |
CA Engine Swap
Don't know if I'm posting in the right forum, I'm fairly new. I got a '96 240sx, I'm looking to do an engine swap and was wondering what engines would fit in it and is still CA legal. Any suggestions
09-10-2014, 05:57 PM | #2 |
No engine swaps are legal in California
also, do research...you can find all of this information online, dmv, Google are all at your disposal. Have fun, good luck |
09-10-2014, 06:33 PM | #3 |
I have been reasearching all over its a pile of deep shyt in Cali -.-
Only one tht i have been reading upon is the " same year same make swap with all oem emission" but u still have to ref the car... On and on and on Good luck |
09-10-2014, 08:45 PM | #6 |
2jz can be legal, the engine your swapping needs to be the same year or newer than your car, you need to have all, and i mean ALL (if its obd2 you need obd2 everything, even gas tank) the smog equipment that was originally on the supra you took it from, that supra needs to be a california car and you need to go to the smog referee to get a BAR label. You can do this with any motor that was original to a car made for the states. Ls motors, 1uz's, VG30DETT's. Anything that was originally sold with a car in the states. A 1jz wouldnt be legal because no car was sold in the states with a 1jz installed.
The car will then be smogged as whatever engine that is, if its an 2jzgte from a supra, your car will be smogged as a supra, if its a ls, whatever you took the ls from. -Proof, Im interning for a CA referee and have smogged engine swapped vehicles and issued legal BAR labels. |
09-10-2014, 10:08 PM | #7 | |
09-10-2014, 11:21 PM | #8 |
Im not a supra expert so I dont know if theres a difference between a jdm supra engine and a usdm supra engine. If your planning on doing a 2jz my best advice is to find a totaled complete supra so you have every piece you need (including trans and fuel tank), and seeing that its a 96 your going to have alot of fun getting obd2 to work right.
09-20-2014, 08:38 PM | #10 |
people still swap in CAs? what is this 2003? i mean its not a bad engine but parts availability isnt as good as an sr and you will probably end up spending as much to swap a CA in as you would an SR. Both are Illegal so.
09-20-2014, 09:56 PM | #11 | |
Not the ca18det....
