01-05-2011, 04:59 PM | #3931 |
01-05-2011, 05:06 PM | #3932 |
i just bought my s13, and im getting a lot of extra road noise in the rear end of my s13, it gets MUCH MUCH MUCH quieter when i load the right rear...it sounds like a roar, ive slid under the rear end while its on the ground and didnt see anything visually and grabbed the drive axles and shook them and they didnt have any play, also the drive shaft looks like its newer, and in good condition...thoughts?
EDIT: also forgot to mention it gets louder with speed, does not seem to be gear related |
01-05-2011, 05:13 PM | #3933 |
Also can the diff output shafts (the 5 or 6 bolt connection that bolts the diff to the axles) be removed?
If they are removed out of the diff, can I use a set of output shafts from an open diff? S14 Open diff output shafts into a J30 diff.
01-05-2011, 07:46 PM | #3934 |
Does anyone wanna trade a zenki 180sx bumper (with smic vent) for a Q's silvia bumper?
Clarification: I have a silvia bumper, I want the 180sx bumper.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
01-05-2011, 10:33 PM | #3936 | |
Trader Rating: (58)
Feedback Score: 58 reviews
6 bolt must be in 6 bolt (5 in 5). VSLD shafts (one long one short) must go back with VLSD differentials. Open Shafts (both same size) must go back into an OPEN differential (you can't mix and match them) http://zilvia.net/f/chat/297481-smal...ml#post3806228 No. Search next time. Small Q thread doesn't mean 'dont' search and ask'
01-05-2011, 11:11 PM | #3937 |
Trader Rating: (81)
Feedback Score: 81 reviews
Can someone who has a 240sx hatchback with the wing off take measurements for me and tell me at what points the holes are at?
I'm trying to see if a kouki 180sx hatchback has the same mounting locations as the USA 240sx hatchback. Thank You!
01-06-2011, 09:26 AM | #3938 |
Im trying to figure out what turbo, injectors, and headgasket size to go with.
Heres my setup so far: freshly built cp pistons/ eagle rods arp headstuds Tomei 270 procams Tomei sold lifters 255 walbro
Jessefuckinwood Street Prowl |
01-06-2011, 09:32 AM | #3939 |
01-06-2011, 10:26 AM | #3940 |
Can't boost over .5bar. would it be better to run straight vacuum from the Intake manifold to the Boost controller? I turned the BC all the way open and can only hit .5 bar, then my hose came off my Intake tube how it's hooked up and hit 1bar. It's an s13 swapped rb25.
Also if I rev the car up and let the rpms drop it will shut all the way off unless is tap the gas to keep it alive. could this be lack of fuel? Right now I am running the stock s13 fuel pump, but I am going to be buying the 255. I was just curious if this is it?
01-06-2011, 12:18 PM | #3941 | ||
01-06-2011, 03:54 PM | #3944 |
if i have a greddy oil cooler/diff brand oil cooler/sandwhich plate and what blitz gauges, for example, would the thread size/pitch be the same? Are they universal or do i need adapters?
street dancer. GLEAM |
01-06-2011, 05:52 PM | #3945 |
I have an oil leak, but i cannot tell where it's coming from, please help!!
Here are more pics Pictures by roadster6909 - Photobucket |
01-06-2011, 06:46 PM | #3946 |
Yes I do. That makes sense. well it's a turbonetic's raptor and I don't have the bottom port hooked up so after I re run my BC and hook up that port on the BOV and i'll see if it helps! Thanks man!
01-06-2011, 07:01 PM | #3947 | |
01-06-2011, 09:52 PM | #3951 | |
Trader Rating: (58)
Looks like a generic parts company reselling chinese made copycat stuff.
01-07-2011, 12:46 AM | #3952 |
im trying to ditch the electrics fans im running right now and use oem shroud/fan and im not entirely sure where to start. ive searched and cant find what i exactly need other than the obvious fan/shroud/fan clutch..but which one do i need for the sr?
and where the heck do i get the fan clutch and fan? |
01-07-2011, 07:02 AM | #3953 | |
01-07-2011, 08:11 AM | #3954 |
01-07-2011, 08:31 AM | #3955 |
[QUOTE=codyace;3815797]Hard to say 100%, but do you have that dipstick tube in all the way? I usualyl use a screwdriver and hit it in all of the way.
I dont think the dip stick would be causing it to leak that much oil, but ill give it a try.. You just hit it in? Or do you screw it in? Or.. |
01-07-2011, 08:40 AM | #3956 |
Ok cool thank you. I've been searching for a picture or diagram for a week now as to see how to do it. Anyone know where I can find one? Or can explain how to recirculate it. I'm sorry I'm new to this.
01-07-2011, 11:25 AM | #3957 | |
http://turboneticsinc.com/forum/turb...ypassValve.pdf That is a link to the one I have but it should help explain how to recirculate it. It is down on page 2.
01-07-2011, 01:08 PM | #3959 |
Trader Rating: (58)
Totally not needed, in fact I think there was even a TSB on it. KA's don't need it either.
01-07-2011, 01:27 PM | #3960 |
this part of my proppeller is leaking is this an easy fix or i gotta buy a new proppeller? this is my first 240sx and rwd so i dont have any idea.
edit: is it the Transmission Rear Seal Driveshaft need to be replace? if not whice one? thanks Last edited by arj; 01-07-2011 at 02:10 PM.. |
