06-25-2011, 11:05 AM | #91 |
^^ I have that motor now. Same as posted above. Still changing minor things there. Nothing was changed on the motor internally just added a BC Stage 2 cams.
06-25-2011, 05:05 PM | #92 | |
Thanks A local shop made them for me. They are some crazy high pressure line. I just told them what lengths I wanted and which end fittings. Not mine, but a clean KA-T |
06-25-2011, 05:10 PM | #93 |
Trader Rating: (42)
Feedback Score: 42 reviews
Just a random question. But how much power are you guys making? And does the oem distributor/spark give enough? When is it necissary to go to COP? When does the distibutoor become insuficient
06-25-2011, 06:09 PM | #96 |
Wow some of those setups up there are mind blowing.
Here's my simple daily sleeper setup: When I first finished it: Removed a few things, painted the valve cover and put in a modified SR manifold, still looking for an SR heatshield: I still want to clean it up a lot more. Stock internals, S15 T28, 370cc injectors, 8 psi. Fun daily driving setup, but I might buy some larger injectors later on and increase the boost. |
06-25-2011, 06:12 PM | #97 |
*I run z32 rims all around, the starion rims where loaned to me to get me home from a drift event, thanks chris old set up: GTi-R t28 (17/18psi) STI 550cc AMS Street Rods CP 9.1:1 Pistons Emance Tune New set up: Holset HE351cw (20psi) DW 850cc Enthalpy Tune
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
06-25-2011, 06:30 PM | #98 |
love this thread. im still piecing together my kit, im debating between the t25 i have and a t28) to run with 550cc. should be ready soon and on a dyno with juan @Bardabe Performance
06-25-2011, 07:51 PM | #100 |
that shouldn't even be a question, haha...KA's run out of steam pretty quick with t25's. Even a t28 is really really mild on a KA
06-25-2011, 10:39 PM | #102 | |
06-25-2011, 10:46 PM | #103 |
I will get a pic of my setup here soon. Right now I am on a GT28R bottom mount setup. I have a Holset HX35, the thing that is stopping me from changing my setup is not being able to find a mani/dp combination that is known to work in an S13 as far as hood clearance. My hood is spaced.
I have been running on an EFI Specialist tuned ECU and last year I swapped out the chips to support some 550cc injectors and Z32 MAF that I installed last year. Trying to get prepared to run the Holset. I even have the factory compressor outlet with v band clamp off of a Dodge Cummins truck. Also I got a turbine discharge flange that I will use to replace the 4/5 bolt Garret flange with on whatever downpipe I get. ATLSpeed, I see that you are running a Holset in your pics above. Looks to me like you are running a bottom mount tubular mani flipped upside down. Did you chop off the T2 flange and weld on a T3 flange, or did you use an adapter. I would think an adapter would create even less space for hood clearance. How many of you guys know of a mani/dp combo that works well with a Holset?
BOOYAH! |
06-26-2011, 12:49 AM | #105 | |
Thanks, that overflow has been replaced by a circuit sport tank
06-26-2011, 10:36 AM | #106 | |
PM me if you are interested in me building another one. You can see some of my work in the fab thread. |
06-26-2011, 09:43 PM | #107 |
Here is mine. Its daily driven and stays a little dirty. Nothing is shiny or hidden, lots of zipties.
EFI Specialist tune Denso 555cc Z32 maf Garrett GT28R Wiseco 9:1 Cometic HG stock rods Clevite bearings ARP main bolts and head studs
BOOYAH! |
07-01-2011, 01:16 PM | #110 |
This was mine that i built, sold her a few months ago. ka-t sohc bored .20 over areies 8.8-1 pistons 550cc injectors n62 maf enthalpy tune clevite bearings garrett t3/t04e 50 trim turbo with 360 thrust bearings tial 38mm wastegate jgs tool manifold 246whp 286fpt at 12psi |
07-02-2011, 09:07 PM | #112 |
my dirty engine bay.
07-04-2011, 03:16 PM | #113 |
When i first bought the engine from futuregohan... Nasty filthy Starting the clean up and tear down Picture is a little blury, but, coming together.
07-04-2011, 11:48 PM | #115 |
hey does anyone know a good place to get (or know someone with whos willing to sell) the oil sensor T-fitting to run a oil feedline, feed line, and t25 fittings as a set?
07-04-2011, 11:56 PM | #116 |
07-05-2011, 08:03 PM | #117 |
Can't remember, but does anyone know of or if there is a Greddy/Freddy style intake manifold for the KA24de? I see alot of nice ones here, but they are all one off custom pieces right?
LMK |
