South Central States Arkansas, Kansas, Louisiana, Missouri, Oklahoma, and Texas. |
07-17-2012, 12:31 PM | #1 |
Austin, TX- Could use a helping hand
I'm trying to install some new fuel injectors and a z32 MAF. I got a s14 with sr20det. The phillips screws on the injector covers are tight and my #2 screw driver hasn't been successful yet b/c I don't want to strip the top of the screw.
And the z32 MAF, I'm just bad with wires I don't know which wires to connect and stuff. And I've also ordered a new intake and connector that will hopefully fit with it too. LMK if you can come help out. I'll buy you some beer or lunch or something. I live near riverside and congress. I can't drive my car b/c my ECU has been retuned for the injectors and MAF. PM for number. Thanks! David |
07-19-2012, 09:14 AM | #2 |
I would help ya but I work 6 days a week and I have my own car to get up and running. There is a guy named terrance that posts S13's and lives near you that is always fixing 240's and selling them. I want him to fix my harness wiring but it's kind of far for him to check out my car.I'll Pm you so you can get in touch with him.
07-19-2012, 12:31 PM | #3 |
dave, its simple. literally, you only need to change like two wires to install the z32 mafs. their is a write up on here. all you need is a soldering gun, dykes, and electrical tape. as far as the stripped screw. get a philips head that is a tight fit and tap it into the screw with a hammer. gently. apply a little torque and see if it budges, if not tap a little harder. worse comes to worse. remove the whole fuel rail and drill it out. the mafs and screw should take an hour or two tops.
07-19-2012, 04:42 PM | #4 |
@ghost_silvia: Thanks I texted terrance.
@sideways: Sweet, I'll look for the write-up, sounds simple enough. Dude so today I actually got 6/8 screws off the fuel injector covers. But there are two that I can't get off b/c the top of them is both slightly worn out from my screw driver. I might try to get a bigger phillips and see if that does it. How do the fuel injectors come out? I guess they just pull out, but they seem tight and I don't want to use a wrench b/c they're plastic or w/e. |
07-19-2012, 06:31 PM | #5 | |
