Old 04-27-2016, 12:00 AM   #10741
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Originally Posted by simmode1 View Post
The lone black guy covering his face in the pic with all his confederate friends. He's doing it the wrongest.
Def in the back....
Old 04-27-2016, 12:04 AM   #10742
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
Ok, I think I died a little on the inside.
lunchmeat is offline   Reply With Quote
Old 04-27-2016, 12:05 AM   #10743
rawgarage
Trader Rating: (75)
Originally Posted by TSL View Post
If I recall correctly some dude-bro found the pictures on that girls myspace and posted them on bodybuilding.com pretending it was his girlfriend for the lolz. This was back in the day when good trolls were more subtle and worked off self deprecating humour instead of being obnoxious retards.
Simpler times.
OT: Went on the local silvia forum which I haven't been on for 8 or 9 years now to see what sort of cars the kids are building these days. Was surprised actually most builds looked pretty clean. Then I worked out if I filtered the build threads using the word "drift" you get this sort of shit:
But here is the thing... not only does it look like ass but mechanically it's even worse. I don't know what's wrong with young people today but it seems like they don't have the attention span to finish anything. This kid has a 100+ page build thread just jumping from one thing to another without doing anything properly. Tries to wire shit up, has no idea where anything goes. Instead of using google to easily find the 15-20 years worth of information on these cars that is online he just randomly hooks shit up. Nothing works, wires melt, fuses blow. Oh well fuck it move on to something else. Vac and boost lines left unconnected because he doesn't know how to hook anything up and is too lazy to check. Intercooler pipes held together with tape because silicone couplers are too expensive. Engine doesn't run so just ignore that and start trying to fit wide wheels with stretched tires to his trailer. Missing all sorts of important bolts so goes to the hardware store and buys one of those packs of cheap shitty bolts to use in his driveshafts. Not only are they the wrong grade but they are the wrong size. Engine still doesn't run properly because the wiring is fucked and none of the hoses are connected and he is using the ecu from a completely different type of engine because the correct ecu is $75 and that is too expensive. So his conclusion to the engine problems is it must be either the temp sensor or the battery. Right? Ok but now lets worry about wheel spacers instead because a car that doesn't run needs hella offset. Fuel pump falls out of it's cradle because it was shittily held in with zip ties, hose from pump to filter melts because it isn't rated for fuel use. Every single fluid in the car leaks out of somewhere, oil, fuel, coolant, brake fluid, but YOLO right?
The worst part is all his dickhead friends cheering him on, "Looks sick bro". Ok I am not even making this up... he has a roll cage in it made from old street sign poles, but the cage doesn't fit because the legs are too short in places to meet the floor pan so he fucking put blocks of wood in to make up the gap. He gets mad when anyone tells him his shit is fucked up. Someone pointed out how jacked up his cage was and maybe he should not run it, the response... "still better than 95% of the shit on here, so fkn relax" because "Negative feed back is best not said some times" and "if you dont have anything positive to say f**k off."
"It's still probably better then no cage..."
"probably better then no cage..."
"better then no cage..."
That type of fuckery can't be explained
Old 04-27-2016, 01:08 AM   #10744
KAT-PWR
KAT-PWR's Avatar
Simpler times."
[Ihttp://i.imgur.com/Xal3nl.jpg[/IMG]
I tell you my "build" came the furthest the fastest when i simply said "I'm not spending anymore money on shit unless it directly improves the car as it currently sits." Spent a good bit on proper wiring, fittings, front end fitment, and Nick nacks that were all related to its current running condition. Like "I'm going to re-wire this haggard radio harness, properly route and wire these gauges, make DCC work properly" along with spending hours working and reworking things like the fusebox relocation so it fits nice and wires aren't going to get worn through and shorted, proper relays, accessory fuse boxes
People get too concerned with Moar Stuffz and less with "well does all this Shit actually serve a purpose or am I just making things worse"
And my trash was never even that bad
MRP Manufacturing
Old 04-27-2016, 03:03 AM   #10745
ixfxi
ixfxi's Avatar
ixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfectionixfxi is close to perfection
funny, thats very true about car builds. though, its a bit of balance because every time i go to do something it ends up requiring more... money. and time. and effort. so its a bit of everything.
with that said, that dude's build is FULL of doing it wrong. i give the kid effort, at least he is trying... but this:
winner winner, chicken dinner!
ixfxi is offline   Reply With Quote
Old 04-27-2016, 03:11 AM   #10746
ixfxi
ixfxi's Avatar
so good. SO GOOD.
Old 04-27-2016, 04:03 AM   #10747
TSL
TSL is an unknown quantity at this point
That's it, playing with cars always costs more than you think but that's just how it is. You gotta focus on one thing at a time and complete it properly before moving on. Don't get ahead of yourself and have a bit of discipline.
If your engine doesn't run don't go and buy cosmetic shit. Fix your engine. If you can't afford paint then don't buy body parts. Don't buy wheels that don't fit if you can't afford the money it takes to do proper body mods and paint. Don't do dumb shit for looks like this kid bought a high mount manifold to run the stock turbo on it meanwhile his fuel tank has a huge leak and is pissing out fuel everywhere. Can't afford a $75 ecu or a silicone coupler but buys 3 different sets of wheels and spacers to get mad offset.
An almost stock car with mild mods that actually runs properly is a more enjoyable car to own and drive than a permanently half-finished project. That's a fact. You wanna look baller? I'll show you 100 different cars with no body-kits, stock steel fenders with a neat roll/pull with nice wheels that fit with a sensible drop and alignment. Costs almost nothing to do and looks 3000% better than any mismatched painted ziptied knockoff bodykit.
So if you're one of the people who see this thread and get butthurt because your car is featured here or you think "aint care", "it's a track car" whatever bullshit excuse you use for doing it wrong well... This is my free easy life advice for today.
Peace.
TSL is offline   Reply With Quote
Old 04-27-2016, 04:09 AM   #10748
lunchmeat
lunchmeat's Avatar
"While I'm at its" will ruin a project car. I learned this the hard way with a 68 mustang I'm wanting to get rid of now. Started as a couple of small jobs, now it's a shell, and I don't have the time, money, skill, and patience to finish the damned thing. Should have sold that bitch years ago and kept my kouki.
Old 04-27-2016, 08:20 AM   #10749
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
It's idiotic younglings feeding idiotic younglings.
Meaning, not too long ago, anyone driving a car with those things done it it would have been laughed off the meeting area.
Now, these idiotic younglings are being cheered, congratulated, sometimes even envied.
That is why when I see a youngling trying to do it right, I try to help in any way I can.
SoundEfx is offline   Reply With Quote
Old 04-27-2016, 09:24 AM   #10750
LockOn!
LockOn!'s Avatar
LockOn! is making a name for him/her selfLockOn! is making a name for him/her selfLockOn! is making a name for him/her self
Whats the forum? I really, really, really, want to create an account to shit on this.
LockOn! is offline   Reply With Quote
Old 04-27-2016, 09:25 AM   #10751
MadMan88
MadMan88 is an unknown quantity at this point
This^ If my father wasn't by my side throughout my 280z build I would have quickly lost track, his knowledge and patience, is ultimately what keeps my young idiotic ass on the right track
MadMan88 is offline   Reply With Quote
Old 04-27-2016, 09:52 AM   #10752
STR8 H8N
STR8 H8N is an unknown quantity at this point
STR8 H8N is offline   Reply With Quote
Old 04-27-2016, 09:53 AM   #10753
STR8 H8N
Old 04-27-2016, 11:11 AM   #10754
Wmcleverly
Wmcleverly is an unknown quantity at this point
i just threw up twice looking at those girls....omg yuk
Wmcleverly is offline   Reply With Quote
Old 04-27-2016, 11:22 AM   #10755
Bluejayde
Bluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond repute
No body mentioned dudes NUTS hanging out the front of his fucking pants?!?!
When I noticed that on Facebook I literally hit the deck laughing.
I assumed that this was a reference to it-
Originally Posted by fatduece View Post
Is that the famous Texan belt buckle?
Bluejayde is offline   Reply With Quote
Old 04-27-2016, 11:47 AM   #10756
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
A little nit picky, and it's supposedly "in progress"... But the lack of monetary priorities and the lack of detail makes it fit here.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 04-27-2016, 11:53 AM   #10757
AKsamuraiS14
AKsamuraiS14's Avatar
AKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond reputeAKsamuraiS14 has a reputation beyond repute
that trans am bird tattoo on her ankle is so hottt
Aero-K Garage * Night Monkeys
IG - Shant_a_ganoosh
AKsamuraiS14 is offline   Reply With Quote
Old 04-27-2016, 11:59 AM   #10758
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
Idk about that retro hatch. If it was a coupe and his gauge wasnt hidden by the cupholder I'd tell you to choke on bill cosby
collegekid is offline   Reply With Quote
Old 04-27-2016, 12:07 PM   #10759
illvialuver
illvialuver's Avatar
Originally Posted by derass View Post
Hot off the press! Replica S14 Boss kits!
Seriously, fuck this guy. I loath him. Lazy fuck ruining a good thing. If I see anyone with this rep kit, dont be surprised if I just talk shit to your face for days. Not to mention I already see things that fit like shit compared to the real thing. I wonder how much the body work will cost to get this thing to fit as good as the real deal.
Originally Posted by STEEZxIT View Post
This cars demensions make me thing it looks liek a vw beetle.
Old 04-27-2016, 12:13 PM   #10760
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
The roof rack had that effect on me.
I feel like 85% of the American population is mentally feeble.
Sent from my HTC One M9 using Tapatalk
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 04-27-2016, 12:14 PM   #10761
illvialuver
Also that last hatch, I just dont understand spending money on all the wood interior and junction produce interior extras, but he still drives around in shitty stock s13 seats?
Old 04-27-2016, 12:14 PM   #10762
STR8 H8N
o really thats it???
Old 04-27-2016, 12:45 PM   #10763
LockOn!
LockOn!'s Avatar
With all the money in chintzy bullshit here, the guy would probably be able to afford a proper part. Like, set of wheels, coils, halfway to an engine swap.
This shit just screams highschooler to me. Can't bare to save up more then $200 at time without blowing it on some stupid garbage.
Old 04-27-2016, 03:11 PM   #10764
derek king
derek king's Avatar
derek king will become famous soon enoughderek king will become famous soon enoughderek king will become famous soon enoughderek king will become famous soon enough
good lord. Missed it by that much
IG DearDerekKing
derek king is offline   Reply With Quote
Old 04-27-2016, 03:56 PM   #10765
driftsucky
driftsucky's Avatar
driftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond repute
@be_henney kranstogram is full of nonsense and foolishness.
driftsucky is offline   Reply With Quote
Old 04-27-2016, 07:15 PM   #10766
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
One of my friends just reminded me about this ugly 302-powered piece of shit
...that became an even uglier piece of shit
...and then had its drivetrain cobbled into this arielatombutnotreally
...which reminded me of that other 302 Miata that looked beyond hideous
It's been a good evening.
jaysgottaredtop is offline   Reply With Quote
Old 04-27-2016, 07:36 PM   #10767
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
edit: sorry, giant pic.
https://scontent.fsnc1-1.fna.fbcdn.n...14205863_o.jpg
Old 04-27-2016, 08:00 PM   #10768
ixfxi
ixfxi's Avatar
Originally Posted by STR8 H8N View Post
daaaaaaaaaaaaaaaaaaaaaaaamn
Old 04-27-2016, 08:37 PM   #10769
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Sent from my iPhone
https://instagram.com/e_lemonation/: @e_lemonation
Old 04-27-2016, 08:42 PM   #10770
silviamang
silviamang's Avatar
silviamang is making a name for him/her selfsilviamang is making a name for him/her selfsilviamang is making a name for him/her self
God this thread just gets better and better. I love it.
silviamang is offline   Reply With Quote
